black mustang halo projector headlights-led
Somebody know anything about those?
They look great but they can be alligned,and they have good light? Somebody already have it? I want to buy but i want to be sure they are good! THANKS! |
Senor Tini
do you have a link?
Ginger with No Soul
2003 GT, 1995 GT vert
13.043@108.46
They are nice, install is a bit of work.
Dual Mustang Halo Projector Headlights - LED (1999-2004) - Installation Instructions at AmericanMuscle.com Lighting is good if you use something better than a stock bulb. As far as alligning, not needed from what I know of.
![]() http://www.youtube.com/watch?v=SLkmi9igM8g ^^^Let a Chic show you how to do a burnout!!^^^ Black Stang Crew Member #HOT STUFF |
yes,but i think allignement is a pain in the ass!!
i dont think the alignment on them is any harder than normal headlight housings, but im not 100%
White 2000 V6 Mustang|Black Saleens 18x9|Flowmaster 40s|AM CAI|8000K HIDs|SCT XCAL III/H&R SS
2005 Mustang V6
I also have the halo light kit, and I do need to aline them. Should not be any harder then with your stock headlights.
CAI, UDP, Eibach Pro Kit, Predator performance tune, C/C Plates, Ajustable Panhard Bar, 17 inch rims and tires, GT duals with Pypes X pipe. GT Rear Bumper. |
Any idea why I can't the the passenger side headlight to go back in. The drivers side replacement went right in..
2007 mustang v6
8.903 1/8 @74.96
i have the smoked angel halo led head lights. i never got mine quite right as far as adjusting them but, but if it wasn't for my fog lights, i couldn't see at night. the visability on mine suck. they look great, they just suck as far as lighting. i had no problen installing them though. i installed them the same time i installed the ss gen 1 kit, so i had the front bumper off anyways.
2006 Mustang V6
I just installed the same ones as the link up top and install isn't to bad getting to the bumper bolts is a bit of a pain with out nicer tools but my biggest problem was aligning them. I would get about 6 feet from a wall and then adjust them perfect but then switching to the high beams they would be way way off and vice versa so i just adjusted the driving lights perfect and from far away you cant really tell the highs are off. I also had to use washers and spacers behind the bolts because they wouldn't move enough with out being lose my car had repairs done to the front left tho so that may have a bigger effect. Also there instructions on taping into the wires is crap there is 3 for each wire harness on each side one side has black green and yellow the other side has white purple and black (this is an 06 others might be different) . black on both sides is ground and the + is the green and the white if i remember right if your not sure test with a volt meter if you need to do wiring at all that is, not sure how much different models differ but i love them and they look great and good light i might look into having them professionally adjusted or keep playing with them.
Guest
Posts: n/a
idk which kind you have ..but if u look in my signature area i have the newest halo lights and they were a bitch to install but the allignment what u need to do is get like a cardboard box and place it like maybe 5 feet away and allign both of them on the center of the box then keep moving the box a foot backwards and repeat till you get the desired allignment you want..when i put them on i didnt allign it right away and i had one facing up at the guys rearveiw mirror and one down on the road lmao lmao..
2006 Mustang V6
Ya same deal on myn install wasn't to bad except getting to the damn bumper bolts but getting them to line up is i pain in the ass it takes a good while to get it right but if you mess with it enough it will get there. and they will look sick !
Threads Similar to: black mustang halo projector headlights-led
| Dual Halo Projector Headlights pics. | MikeHP350 | 96-98 | 44 | November 29th, 2009 12:40 PM |
| Led projector headlights | RX Bandit | 2005 - 2010 | 2 | September 6th, 2009 08:46 PM |
| Dual Halo Projector Headlights with LEDs | dasoccerbomb | Visual | 4 | October 25th, 2007 11:29 PM |
| Dual Halo Projector Headlights | 97TunedMustang | Visual | 24 | November 16th, 2006 03:53 PM |
