Ball joint?
Go Back   Forums at Modded Mustangs > Mustang Forums > V6 Mustangs > 2005 - 2010 V6
Old January 25th, 2010, 04:42 PM   #1
stang05 is on a distinguished road
Ball joint?
I just bought a 4.0L 2005 stang, I was getting the car inspected and they found out that my lower ball joint has a deficiency, in his words "it has too much play." Now my question to you all is how hard is it to change out?
Old January 25th, 2010, 04:49 PM   #2
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
On a New Edge it's not hard at all, I don't see why it would be difficult on the 4.0 either. Wheel off, brake & spindle off, rent a ball joint press from local auto store, use that to remove old one and press new one in, re-install spindle/brakes/anything else you had to remove for clearance (not positive here for 05+ for what all needs to move) load up the ball joint with grease (has a grease fitting on bottom), get the wheel back on and you're drivin'.
Old January 25th, 2010, 04:55 PM   #3
stephen has a spectacular aura aboutstephen has a spectacular aura about
+1 on the previous post. You may want to remove the lower control arm and have a machine shop press the ball joint for you. Either way it can be done if you know how to take the suspension out.
Ford replaces the whole lower control arm but evidently that isn't necessary.
Old January 25th, 2010, 05:08 PM   #4
This shows how to do it with a ball joint press.
Old January 25th, 2010, 10:21 PM   #5
Man thanks for you help guys, that should save me a bit, the guy was freaking charging me 675.00 with parts and labor, I saw a ball joint online for 120.00 ill just change it this weekend
Threads Similar to: Ball joint?
x2 ball joint install PowerShiftz02GT 99-04 8 January 17th, 2012 12:08 AM
I think I have a bad ball joint.. RAGEman 99-04 5 February 25th, 2009 11:11 AM
Ball Joint repair. sixxxshoooter V6 Mustangs 14 July 28th, 2008 11:15 AM
lower ball joint 2003_GT General Tech 3 April 8th, 2008 11:03 PM
Ball Joint Time.. Blown5.0 5.0 Mustangs 4 June 4th, 2007 01:37 PM
