Tighting shock bolts
Go Back   Forums at Modded Mustangs > Mustang Forums > V6 Mustangs > 2005 - 2010 V6
Old February 2nd, 2010, 04:37 PM   #1
Teamsterjohn's Avatar
2005 Mustang V6
Teamsterjohn is on a distinguished road
I installed my new C/C plates on my car. But how do you get shock bolt on top tight? When I try to tighting it, the hole shock shaft turns. I know you can put a wrench on the shaft to stop it from spinning, but then that makes it hard to get a wrench onto the shaft bolt.
CAI, UDP, Eibach Pro Kit, Predator performance tune, C/C Plates, Ajustable Panhard Bar, 17 inch rims and tires, GT duals with Pypes X pipe. GT Rear Bumper.
Old February 2nd, 2010, 04:59 PM   #2
MM's Official Lucifer
goren813's Avatar
'00 3.8L
Kinda the same way you got them off. A large flat head screwdriver or prybar, or fashion something that will fit in the slot on top of the shock. You need 2 people. One holds whatever you use on top, the other tightens the nut with a wrench. Not the easiest thing in the world to do...
Old February 2nd, 2010, 05:02 PM   #3
goren813's Avatar
'00 3.8L
just realized your s197 model, should be relatively the same though...
Old February 3rd, 2010, 10:48 AM   #4
chaaase has a little shameless behaviour in the past
+1. or do what i did last week when i needed my struts & shocks replaced... call daddy, which called his friend, they worked on it, while i played modern warfare =) fyi: i get lazy sometimes.
BBKShOrtyz.OR-Xpipe.Flowz.BBKCAi.SCT.FRtLok.373z.StEEdaSHoRtsHif teR.RAMcLuTch.H&RSpRinGz.MM C/CpLateZ.StEEdaB-joints&bUmpstEEr kIT.18x9 bLk SalEEn whEEls.NiTTO NT555z.GTScOOped hOOd.GTfROnt bUmpEr.maCh1 gRill dELete&sPOiLer.smOkeD hEad&tAiL LiGHts
Old February 4th, 2010, 04:11 PM   #5
2005 Mustang V6
That was a big help
Threads Similar to: Tighting shock bolts
APR timing cover bolts and waterpump bolts ddarkslayer 5.0 Mustangs 3 July 14th, 2009 06:18 PM
stuck bolts and bolts that will turn but wont come out ddarkslayer 5.0 Mustangs 18 May 23rd, 2009 11:12 PM
Help with header bolts - Locking header Bolts? Rush 94-95 4 February 4th, 2009 05:37 PM
Still in shock JASonic The Clubhouse 23 May 29th, 2008 12:57 AM
Shock Help jawaheeb Classic Mustangs 2 November 20th, 2007 09:26 PM
