Reprogram computer/ speedometer for bigger rims? - Forums at Modded Mustangs
post #1 of 25 Old February 7th, 2011, 09:37 PM Thread Starter
Question Reprogram computer/ speedometer for bigger rims?
So I got my new rims and my mom has been nagging at me to get the computer reprogrammed because they put some rims on their Yukon and never had it reprogrammed and it messed up their transmission (supposedly). Anyways I took my car in to get an oil change today at ford and asked them if they could reprogram the computer or whatever and at first he was like oh yea' for sure then he called some guy and apparently they're not sure if they can do it on my car? They were gonna charge me 96$ to take a look at it and if they could do it then cool but if not then I'd have just thrown away 96$ basically. Anyways I guess my question is has anyone had this problem? And if so is it possible to do? Or are they being weird cuz they're after market rims or whatever? I mean I think it shouldn't be a problem since they're the same size as the gt500 rims but idk I'm just confused. Any help would be appreciated! Thanks!
whiteandblack'10 is offline
post #2 of 25 Old February 7th, 2011, 09:41 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
did you change tire diameter or are they the same diameter? if they are the same then you are fine. if they are a different diameter and you have an auto, then yes you need to have it reprogrammed. ford can do it, they just have to go into the computer and change the tire diameter, or you can buy a tuner and do it yourself
Teksid short block, Ported 2v heads, Custom ground cams, Edelbrock Vic Jr intake, Brandon Alsept tuned
F8L GT is offline
post #3 of 25 Old February 7th, 2011, 09:43 PM Thread Starter
See that's what I thought. So I could just get like
The sct x3 tuner and do it on there? And yea' it definitely changed the diameter
post #4 of 25 Old February 7th, 2011, 10:19 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
yes you can do it with that
F8L GT is offline
post #5 of 25 Old February 7th, 2011, 10:22 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
I just looked at your other thread. you should be fine without tuning for them. The tires you got are almost the same overall diameter as the stock tires so theres no need to change the tune
F8L GT is offline
post #6 of 25 Old February 10th, 2011, 03:08 PM
It wont hurt your trany at all thats just stupid it will just mess with your spedo and it will make that read off... You can buy a tuner or have for re-cal it for you... I would buy the tuner they are a life saver
Nick_Adam is offline
post #7 of 25 Old February 10th, 2011, 03:36 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
if the tires were a diff diameter and him being an auto, it very well mess up the trans. with the computer not programmed to the right size, it gives the wrong vss readings making the trans shift at the wrong time which after time, will ruin the trans. but the op doesnt have to worry about that since his tires are the same diameter
F8L GT is offline
post #8 of 25 Old February 10th, 2011, 06:49 PM
Admanistrator
v606er's Avatar
MAD Stangs #8
v606er is offline
post #9 of 25 Old February 19th, 2011, 04:14 PM
So you went from 17 stock rims on a 2010 v6 to 19 inch rims...right? I just left ford asking if i could do the same thing and they said NO, because 19 inch rims were not an option for any 2010 v6 model, so its not an option in the computer to calibrate the speedometer. Were you able to get it calibrated? (also, they said it would mess up my trans if i didnt have it calibrated)
LinT is offline
post #10 of 25 Old February 19th, 2011, 04:31 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
the rims have nothing to do with calibrating the speedo. the only time you have to calibrate the speedo is when you go with taller/smaller tires, not rims
F8L GT is offline
post #11 of 25 Old February 19th, 2011, 04:41 PM
I'd be going from 215 60 17 to 245 45 19. I know someone said that going to that size wouldnt throw off the speedo but can anyone else confirm??
LinT is offline
post #12 of 25 Old February 19th, 2011, 04:46 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
the new tires are a half inch taller. I doubt with that little bit of a difference you would even notice or hurt the trans any. but if you didnt want to take the chance then I would get a tuner at the same time and change for the tire size added
F8L GT is offline
post #13 of 25 Old February 19th, 2011, 04:52 PM
ballpark... how much is a tuner? Ford said that 19 inch wasnt an option in the cars computer. would an aftermarket tuner be able to change it to 19?
LinT is offline
post #14 of 25 Old February 19th, 2011, 04:55 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
yes it will. you can change to which ever diameter you have. they might not have the options with what they have but an aftermarket tuner can change how many revs per mile you get from the tires. tuners can run anywhere from 150-300 depending on if you buy used or new
F8L GT is offline
post #15 of 25 Old February 20th, 2011, 03:26 PM
what if i went with the brembo rims? I think they are 255 40/19. Do you think I'd need to recalc the speedo with those? Also, is there any issue putting brembo rims on a stock v6 mustang?
LinT is offline
post #16 of 25 Old February 20th, 2011, 06:11 PM
Admanistrator
v606er's Avatar
Reread what f8l gt said about the rims size not messing up the speedo.
The numbers you mentioned are the tire size. 19 inches is 19 inches is 19 inches.
Brembo is a break company. I don't know what you mean by brembo rims.
Do you want to upgrade your breaks too? If you have the 19" wheels, you will be able to use pretty much any break system out there.
Here: 2005-2010 Ford Mustang Chips & Mustang Tuners at AmericanMuscle.com - Free Shipping!
Get one of these tuners. Call the people at that shop and tell them what you're trying to do, and ask about the custom or preloaded tunes.
Edit: http://www.topspeed.com/motorcycles/...b-ar56450.html
Are those the Brembo rims you're thinking of? If so, don't buy them. They kill babies and small puppies.
MAD Stangs #8
v606er is offline
post #17 of 25 Old February 20th, 2011, 06:14 PM
!FACEPLATED!
F8L GT's Avatar
iTrader: 13 reviews
he mentions brembo because of the wheels that come on a mustang when you order the brembo package. With a 255/40R19 you should be fine
F8L GT is offline
post #18 of 25 Old February 22nd, 2011, 09:39 PM
OK, i did it! I just bought the "brembo" rims with the 255/40R19 tires and will be putting them on my mustang this weekend!
LinT is offline
post #19 of 25 Old February 24th, 2011, 04:56 PM Thread Starter
Good stuff here guys thanks.
And LinT! U better put up some pics!
post #20 of 25 Old February 27th, 2011, 12:12 AM
arrrghh... it wont let me upload a pic!!
LinT is offline
Human Verification
