Center of rim fell off - Forums at Modded Mustangs
post #1 of 7 Old January 1st, 2017, 05:36 PM Thread Starter
Wife owns a 2006 V6 mustang. We are on vacation out of state right now but right before we left we found the center of the driver rear tire had fallen off and was sitting by the car. Another seemed to be loose. We tried to see if we could just snap it back in for a quick fix but it did not want to. Anyone have any ideas how to fix this or had this problem before?
topgun47 is offline
post #2 of 7 Old January 2nd, 2017, 10:26 AM
Woodman's Avatar
The center of the tire, as in the tread fell off, or the hubcap/lug nut cover fell off?
If it's just the hubcap, pop it back on, a good slap should do it unless there's something wrong with the wheel. Make sure your lug nuts are properly tightened. I would imagine that someone may have been trying to steal your wheels, and got spooked.
You guys are barely 20 years old yet. A fart that vibrates your nutsack is fap material for you.
woodman: achieving the impossible since 1967. 1973? 1980? 1985? 1976? whatever, you get my point
Woodman is online now
post #3 of 7 Old January 2nd, 2017, 11:10 AM
KrimsonKnight's Avatar
hell I had people try to steal the spinners off my stock rims. how sad is that. if its just the center cap fell off slap it on. if its the tire check the lugs on all the car to make sure they are tight.
'00 v6: sold
'05 v6: tint and le mans strips on the way......
KrimsonKnight is online now
post #4 of 7 Old January 8th, 2017, 03:56 PM Thread Starter
Sorry been busy lately. It's the center of the rim that I guess just popped off. I can slap it back but it is still really loose like it may fall off while driving. I don't see any issue with throwing a ring of glue around the inside ring of it and slapping it back on. However I was trying to avoid this. Like I said another rim center cap is loose also but luckily hasn't fallen off.
topgun47 is offline
post #5 of 7 Old January 8th, 2017, 04:23 PM
They need to be removable so that you can put new tires on the rims (tires mounted) as well as have those tires balanced. The center section is used on the tire mount/balance machines, so glue is a no go.
There should be clips on the centercap depending on the type
If it is a basic centercap (non spinner) like this: https://encrypted-tbn0.gstatic.com/i...XmvsBC9P3IFpmA
the back should look like:
https://wheelcentercap.com/wp-conten...79686776_2.jpg
or
a spinner like this: http://www.cjponyparts.com/media/cat...m/1/m1096b.jpg
http://themustangsource.com/forums/a...lz0w-60_57.jpg
There is another style, that is much larger and covers the lug nuts as well:
http://www.suburbanwheelcover.com//v.../3649CC-2T.jpg
I can't find a picture of the back of those, but they also have tabs/clips, and you use a screwdriver or similar in that slot pictured to remove them.
If any of the tabs/clips on your centercaps are broken that would explain the loose fit. If someone was trying to steal the wheels/caps they may have broken them or done the removal improperly, they generally are only supposed to be removed with the wheels off, by applying pressure from the center of the cap from the rear of the rim.
They should click into place and have minimal to zero play. Check the clips/tabs, if any are broken replace the center cap, or leave it off, your choice, they are pretty much for looks with slight protection offered to the hub/axle assembly underneath
2003 Redfire & Black V6. Full suspension, 8.8 w/ 4.10s, tuned. 4.3L stroker + turbo capable of 550 hp soon
DD: 2015 SHO PP, 12.87 @107 1/4 mile (1.8 60') on 93 octane tune/CAI only. SAE corrected: 369.4/451.4 on E20, full Bolt On
Derfdog15 is offline
post #6 of 7 Old January 11th, 2017, 12:43 AM Thread Starter
They appear to be the non-spinner ones. I'll have to try and take a look at the one that came off and the other loose one to see how their tabs look. Worse case I'll try and buy a new set to see if they go on better. I greatly appreciate you taking the time to reply and even post links for to help us out!!
topgun47 is offline
post #7 of 7 Old January 11th, 2017, 10:34 AM
No problem, if you end up looking to buy new ones, used ones are usually a safe bet, as long as all tabs are pictured. There are also generic ones (no mustang image, no writing, etc.) that can be had for ~$20 for a set of 4.
Ebay is a pretty good source for centercaps, as is craigslist some times. Good luck, and keep us posted. Feel free to post pics of the centercap backs, as well as the rim section they pop into when you look at them.
Human Verification
