Forged Piston heads????
I have been looking at super six motorsports and e-mailed them about adding power to my car and they recommended the forged piston heads, i told them i want to run 12 or 13 psi. how big of a job is it to install them and where would u recommend i go to have them installed????? how much money and how big of a job is it??
Installing them is not to bad but getting the cam timing correct is extremely critical. You will need the ford timing tool to get them close however even a couple degrees off can kill the performance. To get it right you will need a degree wheel. There is no "lined up the dots or keyway to get it right. You will also need another special valve spring compressor tool to get the cam followers in and out. If you spend all that money on heads opt for better valve springs as well. If you turbo in the future you will be glad you did. I have not swapped my heads out but know of several who have and getting the timing correct is the bitch.
05 4.0 v6 auto JHP turbo kit 415rwhp 8.8 3.31, alum DS, 3k stall, LCA's, GT brakes, |
i already have the turbo installed i just want to run more boost, any i dea on the cost and where i should take it
Hip Hop Artist
Byebye V6~
Welcome Home New Pony :P
Okay
1. you should probably get cams installed with the heads 2. Price for installation may vary my quote was 1050$ 3. Ask around local forums or go to the Review section 4. You should probably look into buying a 8.8 real soon Are you gonna get the forged block anytime soon?
![]() ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig http://www.myspace.com/moddedmustangz Modded Mustang's Song
i already have an 8.8 installed im just asking around and weighing my options, i want to get the 70 mm throttle body, underdrive pulleys and aluminum driveshaft as well
My opinion is you can make all the power the stock tranny can take using the stock heads with a turbo. You can make the power at lower boost with better flowing heads and cam. The heads wont give you more boost but will give you more power at the same boost. What turbo are you running? Nevermind I remember it is the sts set up. Bump the boost up to 12-13 and get a safe tune and you will be happy. As long as your fuel system can support it and your tune is safe you can run 15psi and make over 400rwhp. I did it for a month and a lot of races but my injectors were maxed out so I dropped the boost to 13 to be safe untill I get some 60's.
wait your running that much boost im only running 7 psi, how much can the tranny handle, with a good tune im assuming a dyno obviously i can safely run that much boost
they are called forged pistons not forged piston heads. you wont gain much by adding a larger TB. you will gain a few hp with the UDP.that aluminum DS would be questionable on a 400hp car since they do break.a chromoly is better for durability .if your car is automatic you could get a higher stall converter.a set of drag radials and a set of rear lower control arms like steedas with an adjustable upper control arm would work great.
Threads Similar to: Forged Piston heads????
| Piston Ring | andres0286 | 99-04 | 7 | June 22nd, 2008 01:28 AM |
| 2 piston calipers | cj1220 | 99-04 | 4 | March 16th, 2008 12:04 PM |
| Piston heads | imported_Gt_Jay | 5.0 Mustangs | 23 | January 22nd, 2008 12:01 AM |
| forged piston engine ? | fogged306 | 5.0 Mustangs | 4 | July 15th, 2007 07:05 PM |
| PISTON ? | 89GTCONV | 5.0 Mustangs | 1 | June 14th, 2006 10:44 PM |
