Help--- Nsr Cam Install
LinkBack (3) Thread Tools
Old December 5th, 2008, 09:36 PM   #1
Semper Fi
beefmobile's Avatar
2006 Killer
beefmobile is a jewel in the roughbeefmobile is a jewel in the roughbeefmobile is a jewel in the rough
Ok, so i've got the valve covers off, BUT i don't have the wedge thing....can i still proceed w/ the swap?????
also, if i don't have the wedge, can i still remove the cam journals? i'm trying to get as far as possible tonight so i will have less to do tmrw.
i'm getting my valve covers powdercoated ford blue tmrw btw
USMC CREW
NCMM ORIGINAL CREW
You would think they used camm'd LS1's to launch space shuttles.
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
(Must be 18, void where prohibited, not available in all states, restrictions apply)
Good Night Chesty, Wherever You Are
Old December 5th, 2008, 09:38 PM   #2
MMs Ford Racing Nut Swinger
1FUN4RD's Avatar
2007 MUSTANG GT
1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold
Off topic but...
Woot Woot!! Ya got a sig finally!!
www.1fun4rd.blogspot.com
Old December 5th, 2008, 09:38 PM   #3
Semper Fi
beefmobile's Avatar
2006 Killer
oh..um thx..exactly what i needed
USMC CREW
NCMM ORIGINAL CREW
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
Old December 5th, 2008, 10:05 PM   #4
MikeysOTP will become famous soon enough
I believe there is a way to do it without the wedge and without pulling the front cover. PM Bluestorm, he did mine without the wedge as far as I know.
Old December 5th, 2008, 10:14 PM   #5
silverstang's Avatar
2007 Mustang GT
silverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the rough
get a second pair of hands (friend, parent, just anyone).............set the cam where you need it, and remove the three journals........and now is where the friend comes in handy.......THIS IS VERY IMPORTANT!!!! remove the bolt on the front of the cam that holds the phaser on. when you remove the phaser, DO NOT take it off the chain, just pull it forward with the chain still on it and KEEP TENSION ON IT!!!! dont let ANY slack get in the chain, or it could jump a tooth. while your friend is holding the phaser (make sure its a patient buddy), you swap the cam real quick like..........then suck down the cam journals (not very tight, just tighten them up until there is no slack. set the phaser back on the cam and install the bolt. now you can procede with torquing and all that other fun stuff. that should work, but im not promising anything.
Bassani Crew Member #3
Old December 5th, 2008, 10:30 PM   #6
Semper Fi
beefmobile's Avatar
2006 Killer
okokokok wait a minute....
so the bolt (i'm assuming) that holds the cam in, remove it? will this make the chain/sprocket free? that's when my buddy has to hold it in place, correct? then i pull out the cam, swap it, then replace the sprocket with the phaser?? then reconnect the journals?
Edit: i am calling the phaser bolt the phaser and the sprocket is actually the phaser
USMC CREW
NCMM ORIGINAL CREW
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
Old December 5th, 2008, 10:34 PM   #7
2007 Mustang GT
the sprocket and phaser should come off as one piece if i remember correctly.......its just one bolt in the front holding it onto the camshaft. remove it, get your friend to hold it TIGHTLY (you can also get your friend to hold "other" things tightly for you later if you want hahaha jk)..........then you swap out the cam. with the journals already removed, there should be no spring tension on the cam, which makes it a fast and easy job
Old December 5th, 2008, 10:37 PM   #8
Semper Fi
beefmobile's Avatar
2006 Killer
alright, i've already got the journals off, i think it's actually 4 journals. but anyway, by tension, do you mean just to hold it in place firmly? or pull a certain direction?
**might be a stupid question, but how do i know which cam goes on which side or does it matter???**
USMC CREW
NCMM ORIGINAL CREW
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
Old December 5th, 2008, 11:01 PM   #9
It DEFINITELY matters. One cam might even be longer than the other if I'm not mistaken.
Old December 5th, 2008, 11:06 PM   #10
2007 Mustang GT
it matters........i know with my comp cams you can look at the part numbers and tell.........i think the last letter on them were L on one, and R on the other (for left and right)..........you dont need to pull the cam journal a certain way, just keep the slack out of the chain and dont let it jump a tooth. it wouldnt hurt to take a sharpie and make a mark on the chain/gear as there where it goes just in case you mess something up. also its three journals (as per the Ford way)
Old December 5th, 2008, 11:09 PM   #11
2007 Mustang GT
the wedge isnt really important unless you plan on removing the phaser from the car (to install lock-outs or limiters).........if its just a direct bolt in cam with no phaser mods, all you have to do is unbolt the phaser, hold it forward of the cam, install the cam, and then reverse the removal procedure. follow your torque specs too, its important.
Old December 5th, 2008, 11:42 PM   #12
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
You know you cant reuse those cam phaser bolts beef.
Old December 6th, 2008, 12:01 AM   #13
Semper Fi
beefmobile's Avatar
2006 Killer
hey rich i tried calling you. sry it was so late i lost track of time. anyway, ya i know i can't reuse them i'm going to go by ford tmrw when i drop off my valve covers. and i need to get a torque wrench..
so here's what we did...
Unbolted the phaser bolts, my buddy held the phaser/chain in place as i swapped out the cams....one follower fell out, but i wiped it off good and placed it back on... then i put the new cam on and lined it up correctly with the keyway so i was in there nice and tight. walked the phaser back on and put the bolt back in (for now) just enough to hold it in. as we were doing that, i put the journals back in place and tightened them back in; just snug....complete (for now)
ok so what did i fuck up..?
USMC CREW
NCMM ORIGINAL CREW
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
Old December 6th, 2008, 12:02 AM   #14
Semper Fi
beefmobile's Avatar
2006 Killer
oh and my buddy sliced the shit out of his finger on the phaser.. he's a tuner so i guess my car could sense that or something and tried to eat him. lol. is a lot of blood ok to get in there?? for reall.....
USMC CREW
NCMM ORIGINAL CREW
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
Old December 6th, 2008, 12:20 AM   #15
Mickey's Avatar
Mickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to behold
blood = hp
Under Construction
Old December 6th, 2008, 12:32 AM   #16
Semper Fi
beefmobile's Avatar
2006 Killer
everybody go to bed or something??
USMC CREW
NCMM ORIGINAL CREW
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
Old December 6th, 2008, 12:33 AM   #17
Mickey's Avatar
pussies ....wish I could help brotha but my cams dont go in for a few weeks when I get home.
Under Construction
Old December 6th, 2008, 12:39 AM   #18
Bkbulldog's Avatar
Bkbulldog is on a distinguished road
beef man me nad your mom where in bed
C6 Corvette
Borla catback , Vararam intake , tune.
Old December 6th, 2008, 12:41 AM   #19
Semper Fi
beefmobile's Avatar
2006 Killer
hey dousche bag at least i know where the hole is...my moms is kinda big so u might slip out just a heads up...oh ya and AT LEAST I CAN PUT MY OWN CAMS IN....
USMC CREW
NCMM ORIGINAL CREW
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
Old December 6th, 2008, 12:43 AM   #20
Bkbulldog's Avatar
your car
C6 Corvette
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/100253-help-nsr-cam-install.html
Help--- Nsr Cam Install - Page 7 This thread Refback December 17th, 2008 02:32 PM
Help--- Nsr Cam Install - Page 8 This thread Refback December 17th, 2008 02:21 PM
Help--- Nsr Cam Install - Page 5 This thread Refback December 9th, 2008 07:33 PM
Threads Similar to: Help--- Nsr Cam Install
NSR cam write up. 07 STROKER 2005 - 2010 39 April 18th, 2010 12:26 PM
NSR cam write up page 2 07 STROKER 2005 - 2010 28 April 17th, 2010 02:56 PM
Cam install usafimj 2005 - 2010 35 March 4th, 2010 06:01 PM
cam install? Jucostud 2005 - 2010 23 October 12th, 2008 09:44 PM
Cam Install? beastGT 2005 - 2010 44 August 28th, 2008 11:43 PM
