2005 Mustang GT Roush
LT Header install write up?
I thought some one was going to add a write up on how to install long tubes? Anyone know where a guy could find one?
2005 BLACK Mustang GT Roush #05-0090 DOB manifold, m122 SC, gt500 TB, 52lbers, KB BAP, AFCO HE,Brisk plugs, Mac Lt's, Off road x, Roush TVS CAI, Detroit rocker sc grind cams, Brenspeed 93 tune, 10 psi (2.875" pulley) 470rwhp-419ftlbs sae |
#2 | |
2007 Mustang GT - Pretty much stock. Pypes pypebomb a/b, Tri-ax shifter. |
2005 Mustang GT
I was going to do a write-up . . . but haven't started the install yet. But this is basically what I have compiled on it so far.
Here are some links that you might find useful as well. Mag article Ford Mustang BBK Headers Installation - Mustang Monthly Magazine Good source on removing K member (if you need to) StangFreak, Stang Freaks, Mustang Forums, Mustang News, Mustang Clubs - How to Install BBK Tuned Length Headers Modded Mustang write-up Ford Mustang Long Tube Header Install You tube Vid MM&FF Scavenging Article 2005 Mustang GT | Muscle Mustang & Fast Fords Magazine Article at Automotive.com Check out downloaded Word file on 04 installation BBK shorties installation pic’s and description Ford Mustang Headers Photo Tribaltek’s Resource Obx Header Install On 05 Vert/auto Trans - The Mustang Source Forums Header Install Write-up on 2003 GT BBK tuned length header installation write-up inside! - Mustang Forums at StangNet Here are a list of some tools that some have recommended . . . Other parts & tools? New Gaskets (Aluminum) Percey’s or Ford Racing? Locking Header Bolts (Stage 8?) O2 Extenders Flex Head Ratchet S-Shaped Box Wrench (13 mm?) Ratcheting Wrench Thin Open & Closed End (13 mm? or ˝ Inch?) Stubby ˝” Ratcheting wrench & stubby ˝” Combination Wrench Extremely long Ratchet Extensions (2) 1-ft extensions . . . Plus 1-Inch & 2-Inch Extend Penetrating Oil & Rust Remover to spray bolts night before beginning
Skrapr 2005 Mustang GT (5-spd Manual) FRPP 4.10's Kooks LT's | Kooks Cat'd X C&L Racer CAI Dyno'd | SCT-X3 MGW Shifter | MGW Interior Details Comp XFI SPR Stage-II's |
2006 Mustang GT
11.67 - 1.64 60' @ 119mph Livernois 298ci Stroker, Saleen S/C, GT500 FPs, SD 60# inj, GT500 T/B, Thump Tensioner, BGG 8 Rib, Kooks, Gords HE, 4.10, TrueTrac, Spec 3+, Pro 5.0
I didnt do a write up, it was more like a live progress thread. Let me tell you something though, I didnt have shit for ground clearance so there were just some things that I made extremely difficult for myself.
I couldnt get the last two header bolts in on the drivers side. I even had the help of another member on here and he couldnt get to them either...The thing that will help the most is taking your time and having the correct tools and ground clearance
![]() Under Construction |
#6 | |
BWAL Is My Hero
2003 F150 S-Crew 5.4 FX4
What does ground clearance have to do with header bolts? Don't have anyone with a lift you could use for 15 minutes? |
Well Towelly, when you dont have ground clearance, it is hard to manuever your body to certain angles that would allow for you to further reach these elusive bolts...
#8 | |
BWAL Is My Hero
If your car is up on stands then ground clearance has nothing to do with anything. Your car is off the groud 12 inch's, unless your jack stands were to small.... |
jack stands were small
it was some piece of shit autozone package for like $35 my brother picked up...
BWAL Is My Hero
AHH Gotcha. When I think of ground clearance, I think of the space from the bottom of your car to the ground, as it sits on the ground .
You guys know anyone running Pacesetter long tubes? Damn things are cheap. I knew F-body guys that were running them and had similar gaines as any other Long tube for those cars. I am wondering if they are tuner friendly or if the 02 bung is in a bad spot. I heard some long tubes can make things a pain if the 02 bung is positioned in a bad spot. Not to sure about that though. Tell me what you think.
#12 | |
BWAL Is My Hero
#13 | |
2006 S281 3V
Damn right! Can't beat it.
'06 Whipple'd Mustang GT (Coming Soon) '02 Supercharged Harley-Davidson F-150 (Sold) '05 Mustang GT (Sold) |
bullshit, ill bet you beat it all the time
Damn... you got me there!
2007 GT
there has to be a reason why they are so cheap.
I used the write-up that scrablr posted. Just make sure you jack it up high enough and you'll be fine. Remove the cold air or stock air box, battery, and battery tray for extra space. As for the started just the 3 bolts and lay it down. No need to remove the cables
07 GT-- Gone But Not Forgotten Military Crew E-5
If there is, I haven't found it yet. If they weren't stainless, it would make sense... but they are
2007 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
I got a set of pacesetter LT's sitting on my garage floor. I would be interested if there are any issues with the O2 sensors. That and time are the only things standing in the way of installing them.
![]() Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit |
Threads Similar to: LT Header install write up?
| Header Install | zerofx150 | 99-04 | 24 | October 9th, 2007 10:45 AM |
| header install | dumps | 2005 - 2010 | 8 | May 18th, 2007 01:25 AM |
| header install write up | beheivjer | Modular Mustangs | 0 | May 14th, 2007 03:27 AM |
| Long Tube header Install Write-Ups? | xx9gt6xx | General Tech | 2 | April 27th, 2006 03:12 PM |
| Good Nitrous Install Write Up | stangaddict | General Tech | 3 | March 26th, 2006 09:10 PM |
