2006 mustang gt
Gear whine?
I have had my new gears now for a few months and thought they was quite until I took my off road h pipe off and put the stock one back on. Now I hear a slight whine. I bet more people have gear whine and just don't notice it because of their loud exhaust.
auto, JLT,Brenspeed 93 tune,3.73's, Steeda pulleys, Bassani race axle-backs, Kaenen 3 inch cowl hood, CDC aggressive chin spoiler, gt500 rear spoiler, 20" Saleen wheels wrapped with Toyo proxxes4, |
I have alil gear whine but it doesn't bother me
07 GT-- Gone But Not Forgotten Military Crew E-5
2006 Mustang GT
1/8 mile 8.34@83.6 in tropical Miami with heavy rims and street radials
I have freakin gear whine with my motive gear 4.10s!!!!! What brand do y'all have?
![]() Steeda: CAI, UDP, Delete Plates, Throttle Body Spacer, Axle Back, LCA and Sport Springs MSD: Coil Packs Magnaflow: X-pipe Motive Gear: 4.10's American Racing: Deep Dish Bullit 18 x 9 f 18 x 10 r Nitto Street Radials: 275/40 & 285/40 |
2006 mustang gt
FRPP 3.73's
FRPP 4.10s
2005 Mustang GT
12.00@114.82
i have the frpp 4.10s and they whine a lot. They are fun though so who cares!
vroom. |
2005 Mustang GT
When do the gears whine?
Whine on acceleration that mellows out when the axle is no longer under load is usually due to improper gear set up or worn ring and pinion gears. Deceleration whine is usually attributed to the pinion bearing. Either bad preload or a bad bearing itself. Deceleration whine almost never has to do with the ring and pinion gears themselves. Whine that starts after the vehicle is moving and is steady across all MPH ranges \ torque loads can be bad or old carrier bearings. There are a bundle of other potential causes but these are the most likely culprits. Depending on where the whine is happening it could become more than just an aesthetic problem. If ignored they can cause a major failure in the ring and pinion and leave you sad on the side of the road, or worse. |
I have Pro5.0 3.90s on my Auto and they whine. FRPP Gears with the part# that ends in "A" are less likely to whine.
A lot of people say that it is all about the install, but I do not believe this is true. I think it is partly due to the Gears manufacturer and the installer. It is not easy to get the gears perfectly aligned. If you didn't want gear whine then get ready to spend a lot of money on oil and installation costs. Because trial and error would be the only way to reduce or get rid of gear whine.
2007 Mustang GT - Pretty much stock. Pypes pypebomb a/b, Tri-ax shifter. |
^^ how bad is the whine?
vroom. |
2003 Mustang GT
13.987@100.98 MPH
check pinion backlash...
![]() 88 NOTCH,351 WINDSER,BUILT C6 TRANY,750 CFM CARB,4:30 GEAR=??? WWIII 2003 MUSTANG GT SOLD with 488 RWHP and 520 FT-LB on 150 shot and bolt ons R.I.P. |
Mine is pretty loud. It doesnt bother me that much though. I am good at tuning out sounds. I also blast the radio
. I have FRPP 3.73 gears, install kit and oil in my garage waiting for install. At the same time I will be doing a Detroit True Trac. I talked to Techco and they want $700 for the install, but I know they will do an awesome job. Most of them are exSaleen workers.
so youre going to longer gears? why's that?
vroom. |
I didnt want 4.10s on my auto daily driver and the next gear down from FRPP is the 3.73. I will eventually supercharge anyways.
^dont fear the gear.
C6 Corvette Borla catback , Vararam intake , tune. Last edited by Bkbulldog; December 9th, 2008 at 04:47 PM. |
2005 Mustang GT
i have FRPP 4.10's with no gear whine so far. But if i do aquire some whine it wont bother me since that gear ration is pretty awesome on the stang.
http://videos.streetfire.net/video/0...ust_143888.htm My mods: Comp NSR II's, JBA shorties, Pypes o/r H-pipe, Steeda axlebacks, Steeda UD, BBK TB, Steeda CAI, FRPP4.10, BMR panhard/LCA/Relo, Eibach springs, D-specs,Bama 91race, CMDP
I drive to much freeway. At 80 mph I am at 3000 rpms. I wouldn't want that to be any higher. If I didn't drive so much on the freeway then yea I would get 4.10s for sure.
2003 Mustang GT
13.987@100.98 MPH
if you drive buy rpms and not buy speed , and dont mine leveing for work or school earlier go with 4.30s like me they realy liven the car up and i hate to admet it put i do travel off out of towm to race and some people like to 40 roll and thats nooo problem with me...i have left some cars buy 2 cars off the hit.
2003 Mustang GT
13.987@100.98 MPH
BTWay you may ....no you well need tires on and off the street. i drive interstates to school all i doi is set my cruse to 1600-2200 rpm and i roll with it all the way to school . oh and allways use fully syntetic oil in you engine and trany as well as your dif......saves you car alot of pain.
Threads Similar to: Gear whine?
| gear whine | v606er | 2005 - 2010 V6 | 8 | December 2nd, 2008 10:40 PM |
| 4.10 gear whine | ivan48humble | 2005 - 2010 | 7 | July 27th, 2008 03:34 AM |
| Gear Whine | 06Black5spdGT | 2005 - 2010 | 21 | July 26th, 2008 02:42 PM |
| Gear whine? | eLLuSioNiST | 2005 - 2010 | 22 | June 24th, 2008 09:22 AM |
| Gear Whine? | DanTheMan | 99-04 | 30 | December 10th, 2007 06:32 PM |
