2006 Mustang GT
tire size?
i have a buddy that works at a local tire shop and they are doing there yearly shop cleaning. he ran into a brand new pair of falken 275/35/18's that they will sell to me for 100 bucks. will these fit on my factory 18x8.5?
2006 Mustang GT (Auto),FRPP Hot Rod Cams,Hooker Longtubes w/ Off Road X-Pipe,Stock Mufflers,TCI 3000 Stall,Delete Plates,C&L Racer CAI,Tuned By The Guys From American Muscle,FRPP 3.73's,Coast Line Full Length DriveShaft
they might look a little small but they will fit the rims...
![]() 2.6l KENNE BELL 298 Stroker, Ported heads Pro Motion Built 3650/McLeod RST/ MGW Short Throw Long tube/O/R X /Borla Touring 8 rib/65 lb injectors/GT500 twin fuel ET Drag Slicks/3.73 gear Detroit Truetrac /CDC AGR Spoiler |
2006 Mustang GT
small as in side wall or width?
for a hundred bucks i'd go for it. they won't handle quite as good as 255's though
One Man Wolf Pack
Way too small. About 2 inches shorter than your stockers. It will look goofy.
![]() ΜΟΛΩΝ ΛΑΒΕ
2006 Mustang GT
i want a wider look from the back. these factory tires i have look way to narrow
#7 | |
2006 Mustang GT
whats the widest i can go?
FR500 18 x 10 in the back + nittro will do that
C6 Corvette Borla catback , Vararam intake , tune. |
2006 Mustang GT
yeah i know that will . but my funds are a lil low since my lay off at work
i think my fronts are about 25.5 inches in front and they look fine, but i'm lowered also
One Man Wolf Pack
Hold on, are you talking about a set of four tires or just two?
![]() ΜΟΛΩΝ ΛΑΒΕ
ah true i didn't see that either. if it's not all 4 i wouldn't bother
I had that size DR's on my car for the strip... it really did look silly.... even with my drop there was still a lot of room around the tire and they are smaller than the stock tire diameter...
All sissies going to Hell!
2008 BULLITT #3385
Killing with a smile
dont hit any pot holes going fast. And that will throw your speedo off a bit too.
2008 Mustang GT
Pass it up unless you dig the no sidewall look.
IBEATU
06 GT, 98 GT, & 93 Notch
Thats what size I had on my 98. Looked pretty good on there but looks even thin on it. I think it would look way to small on a S197
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
2006 Mustang GT
yeah its just 2 tires. i wanted to mount them for the rear but yall say the side wall is going to be to narrow so forget it. whats the biggest size i can go with? thanks guys
Abyssinian of AX
'02 Saleen
19.34@42.259
Running 8.5" wheels, you are really only going to run a 255~265 (maybe a 275 in some tires), depending on the profile. The higher the profile, the wider the acceptable fit per manufacturer, generally speaking.
I would run a 255 as it is the best fit, IMO. Jazzer EDIT: Big type-o there... eek! fixt
![]() Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news Last edited by Jazzer The Cat; December 26th, 2008 at 06:14 PM. |
do you want dr's or street tires.
the best size for them to still handle optimally would be 255/45/18 you could squeeze the 275/40/18 on there probably. nitto 555 (street) Nitto Tire - High Performance Tires for Car and Truck Enthusiasts nitto 555R (dr's) only come in a 285/40 that might fit. i don't know if you could get them on there. Nitto Tire - High Performance Tires for Car and Truck Enthusiasts bfg kdw2's BFGoodrich Tires | g-Force? T/AŽ KDW | Tire Sizes & Specs bfg g/force dr 275/35 this one ends up being a little short, but if you're looking for a dr that will fit on the stock 18's this should go on there. BFGoodrich Tires | g-Force? T/AŽ KDW | Tire Sizes & Specs |
2006 Mustang GT
anyone have any good pics of a 255/45/18 on their stock rims? i want to get an idea of what thety look like before i order them. should i just run them in the rear or all the way around? i just want a wider look in the back. thanks
Threads Similar to: tire size?
| Tire Size | ermister | V6 Mustangs | 10 | May 10th, 2010 10:41 PM |
| Tire size? | BLK01SS | 99-04 | 8 | September 6th, 2008 05:08 PM |
| Tire Size | dgt_mustang | V6 Mustangs | 10 | December 16th, 2007 05:08 PM |
| Tire Size | 89StAngerLX | 5.0 Mustangs | 2 | December 10th, 2007 11:27 AM |
| tire size? | bdp55 | 99-04 | 1 | March 30th, 2007 05:34 PM |
