LinkBack (1) | Thread Tools |
#1
DIY oil catch can.
Found this at clubrsx. Think im gonna try it in a few days.
DIY: Oil Catch Can - Club RSX Message Board |
2005 Mustang GT
13.4@103
Nice find, sounds good.
2007 GT
Why would you put one on a engine with a PCV ... and with no boost?
They still help.
#5 | |
BWAL Is My Hero
2003 F150 S-Crew 5.4 FX4
I'm ording a Steph's catch can myself here in the next couple of weeks. (Among other things.) |
you can get a NICE looking catch can for $10 more on summit or jegs rather then that
but good find....i see people selling these and catch cans made of PVC(yes PVC)piping...for $50-60....i never understood why in the world would anyone put something so ugly looking that doesnt look like it belongs to save $5-10
#7 | |
![]() JLT CAI: KOOKS LT's: Comp NSR II's: 4.56's: TR6060: Steeda LCA, UCA: QA1's: Roush rear springs...see garage for more. |
and why don't you just put a little filter over the pcv valve and the opening that returns it to the throttle body???
Yes i know its turboed but still...this guy blocked his off..
![]() why would you do a catch can when you can block the throttle body side off...and put a filter over the pcv valve so when the pressure builds it just releases it back into the atmosphere instead of back into your intake?? this makes more logical sense to me..
![]() JLT CAI: KOOKS LT's: Comp NSR II's: 4.56's: TR6060: Steeda LCA, UCA: QA1's: Roush rear springs...see garage for more. Last edited by 06GTMustang89; December 25th, 2008 at 10:51 PM. |
2007 Mustang GT
14.70@97.24
Here is a link to a write up for a S197. Are there any downsides to just sticking a breather on it?
PCV Oil Seperator Install - WWW.S197FORUM.COM |
creating a vacuum in the crank case is desirable, especially on a forced induction application where blow by is a potential issue. Another option would be krank vents to prevent pressure inside the crank case and prevent oil from being moved where it should not. krank vents are also quite cheap.
I gave brenspeed a shout about this whole situation asking them if a breather filter would be ok...so ill wait to hear from them.
#13 | |
Either way is perfectly fine i would imagine...im going to do the filter and block off tomorrow.. And the vacuum is really only needed to pull the oil and gases back into the intake..thats why the hose is that way...if your not using hte gases to burn then no vacuum is needed because the PCV valve will vent out the gases at the same pressure it would regardless of vacuum or not.
![]() JLT CAI: KOOKS LT's: Comp NSR II's: 4.56's: TR6060: Steeda LCA, UCA: QA1's: Roush rear springs...see garage for more. Last edited by 06GTMustang89; December 26th, 2008 at 01:07 PM. |
2007 GT 2000 GT
i had the moroso oil separator, i didnt like how it was real close to my radiator hose, so i replaced it w/ K&N crank cas breathers. my car is running fine. i see some high hp stangs w/ breathers on theirs too, some w/ breathers on the oil filler cap too. the crank case breathers are cheaper, easier to install, and take up less area in your engine. w/ turbo or centri space may be an issue.
there are a few ways to fix this oil burning problem. Using a breather and blocking of the line is one way to stop oilconsumption, but vacuum can no longer be held in the crankcase. With a krank vent you get both decreased oil consumption and vacuum. The crankcase vacuum greatly reduces oil migration around the piston rings and valve guides of the engine in order to reduce oil consumption, decrease contamination of the combustion chamber from oil leakage, and reduce detonation tendency. The block off/breather would also do that by preventing positive pressure from being created, krank vent would maintain vacuum. The crankcase vacuum also allows a reduction in oil ring tension which in turn reduces engine friction, resulting in a high power output and cooler running engine during operation.
Different approaches, will there be any noticeable change in the vehicle, probably not. But there is a change, thats why I went with a $5 krank vent. Last edited by ImpulseCars; December 26th, 2008 at 02:56 PM. |
nice.. and the catch can is a no brainer.. burning oil in cylinder = DETONATION.
I think mine came with my KB... it has never been full but I just empty it when I notice oil in it... with 16 lbs of boost I think it is a good piece to have..
![]() 2.6l KENNE BELL 298 Stroker, Ported heads Pro Motion Built 3650/McLeod RST/ MGW Short Throw Long tube/O/R X /Borla Touring 8 rib/65 lb injectors/GT500 twin fuel ET Drag Slicks/3.73 gear Detroit Truetrac /CDC AGR Spoiler |
BWAL Is My Hero
An oil separator catch can is beneficial on a PD blown car. With a PD blower, it always has high negative pressure on the intake / inlet side. This allows for alot of oil to be pulled into the intake.
As stated, it is not good to have oil in the air / fuel mixture. Oil breaks down the octane and can cause knock. I also believe in using a truly designed separator can. This is what I run with great success..... Separator catch can This is used by alot of GM guys. |
BWAL Is My Hero
Nice info GrtWht.
As for using breathers instead of a catch can. You also will get a little oil leaking from the breathers and smell of burnt oil. Let alone vacuum being good for crankcase fumes. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/102746-diy-oil-catch-can.html
| Oil Separator ....Cheap Insurance? - IMBOC | This thread | Refback | April 1st, 2009 02:32 AM | |
Threads Similar to: DIY oil catch can.
| New Clutch is IN, but always a catch! | Ugmul | 99-04 | 6 | November 14th, 2008 04:46 PM |
| where can i get a cheap blowby oil catch can? | Bandit | 2005 - 2010 V6 | 8 | May 23rd, 2008 12:56 PM |
| deadliest catch | whitemustang02 | The Clubhouse | 25 | April 21st, 2008 04:32 PM |
| Catch Can / 347 | JayVee | 5.0 Mustangs | 38 | January 10th, 2008 01:25 PM |
| cant catch me im the mustang man | 232stang | The Clubhouse | 63 | March 27th, 2007 01:02 AM |
