Stange noise from engine **with video**
Old December 25th, 2008, 02:50 PM   #1
2005 Mustang GT
13.4@103
Avengence will become famous soon enough
Can anyone tell me what this noise is? Its the louder clunking noise. It doesnt cause an idle change or shake the car.
original post in a diff forum:
Ok, new problem... engine clunking? - MustangForums.com
Old December 25th, 2008, 03:00 PM   #2
trill gear head's Avatar
2006 Mustang v6
trill gear head will become famous soon enough
Sounds like a exhaust leak. I have the same sound coming from my 4.0L
Former :06 4.0L 6spd Mustang...TR6060
Now: 06 Mustang 4.6L 3V with some mods
MAD Crew 23
Originally Posted by 1FastFox
Your only as big as your smallest oriface.
Old December 25th, 2008, 03:09 PM   #3
brianm's Avatar
2011 ram 1500 hemi
brianm will become famous soon enoughbrianm will become famous soon enough
sounds like something mechanical to me.
vmp500 hp. jba lts. powerhouse d/s Sold
Old December 25th, 2008, 03:18 PM   #4
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
what are your mods besides the K&N ?
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old December 25th, 2008, 03:25 PM   #5
07 Grabber GT's Avatar
2007 GT
07 Grabber GT is on a distinguished road
I'd like to hear it with varying rpm's ... initially it sounds like an exhaust leak.
Old December 25th, 2008, 03:52 PM   #6
07 STROKER's Avatar
07 Mustang GT
doesint sound like a exhaust leak to me.
Old December 25th, 2008, 04:45 PM   #7
2005 Mustang GT
13.4@103
no other engine mods
Old December 25th, 2008, 05:55 PM   #8
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
That is not a exhaust leak. That is something mechanical for sure.
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old December 25th, 2008, 07:02 PM   #9
GT33's Avatar
2006
GT33 is on a distinguished road
it sorta sounds like a clutch chatter. cause my spec has a similar sound sometimes..idk thats my guess.
Just a bottle and some mufflers)))
18yrs old S.FL
Old December 25th, 2008, 07:37 PM   #10
weldreth's Avatar
2005 Mustang GT
weldreth is on a distinguished road
every newer gt i heard has that noise in the valvetrain.... normal??? not as loud as that though
puedo tocar tu gato?
Old December 25th, 2008, 10:33 PM   #11
Dr Detail's Avatar
Dr Detail is on a distinguished road
Get short piece of broom stick or a long screw driver and hold it to your ear and on the cam cover and listen to the valve train,moving from cyl to cyl. You can use this trick isolate many strange noises coming from engines, like bad alternator bearings,etc.To my ear it reminds me of a bad rod bearing, to determine which one disable each spark plug one at a time till the noise stops. By eliminating the load(combustion) on the rod the noise will go away or at least lighten up. Don't ask about how I know the rod bearing trick.
Old December 26th, 2008, 12:28 AM   #12
UrbanRedneck's Avatar
2008 Mustang GT
13.124@105.52
UrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really nice
Sounds like a collapsed lifter. Is there oil in the car? When you revv the engine, does it get faster and louder? Does it get louder when the engine slows back down than when it speeds up (that'd be more likely a rod bearing)?
Hurst Crew Member #20
2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Old December 26th, 2008, 12:40 AM   #13
2005 Mustang GT
13.4@103
There is oil in it, I checked it and it shows there is enough oil in there.
It doesnt get any faster or louder, it actually quiets down the more it revs. It does get a little faster though, just quieter as the revs get higher.
Old December 26th, 2008, 12:45 AM   #14
Dr BlackStang's Avatar
2007 Mustang GT
Dr BlackStang is on a distinguished road
Send a message via AIM to Dr BlackStang Send a message via Yahoo to Dr BlackStang
hmm my guess would have been a lifter tapping too, but if it doesnt get faster with higher rpms then thats not it...
C&L CAI
XCAL 3/Brenspeed Tuned
Cervini Ram Air Hood
Hooker LTs/ or Xpipe
Borla Stingers
Hurst Competition Plus short throw
Steeda UD pulley
Ford Racing 4:10s
Old December 26th, 2008, 01:26 AM   #15
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
it can be many things.. most of them not good... were you running it hard before it started? what weight oil are you running? the noise might go away with a thicker oil. it could be cam phaser lash which can be caused by the computer advancing/retarding the timing. It could also be a pulley on the serpentine belt... it it wasn't being beaten then it could be electrical/programing/oil pressure. if it was driven hard just before the problem started then it could be deeper... another way to isolate the noise is take a piece of vacuum line and use it like a stethoscope..
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old December 26th, 2008, 01:56 AM   #16
2005 Mustang GT
13.4@103
Sorry i mis-worded my last post. I meant to say it DOES get faster with revs but gets quieter with more revs.
I do drive it hard sometimes so I guess it could be something mechanical. Its just weird that the CANBUS system reset and then I really noticed the problem. It seems to me like its coming from the top of the engine on the passanger side. Seems more likely to be something in the head, people have told me that the cam phaser gear can go bad and cause a loud noise like that and I guess a loss in power because its not advancing the timing. Isnt there spring in there that makes it return after advancing the timing, when the oil pressure goes back down?
I am very lost in this but I guess I will keep searching for the answer. My wife told me that she sort of hear this noise before the CANBUS system go reset but after it reset it seems to have gotten louder. It just confuses me a LOT
Old December 26th, 2008, 02:39 AM   #17
stangNV's Avatar
07 Mustang GT
stangNV is on a distinguished road
all ive heard have the same noise also but not as loud......sounds kinda bad
JLT II, Superchips 93 Octane Tune(Finally have the SCT X3), Steeda UDP's, Bassani Catted X, Bassani Race Axlebacks
Old December 26th, 2008, 02:55 AM   #18
2006 Mustang v6
well shit, i guess I better get my stang looked at by my mechanic.
MAD Crew 23
Old December 26th, 2008, 03:20 AM   #19
psfracer's Avatar
2006 mustang GT
9.417 @ 142.96 mph
psfracer is on a distinguished road
Cam follower or exhaust leak. If you have the stock manifolds, then the likelihood of it being an exhaust leak is pretty slim. With a bad cam follower it would make sense that the sound is coming from the "top" of the engine.
2005 Mustang GT Auto - Whipple @ 18 psi - 604 rwhp 543 rwtq
Old December 26th, 2008, 03:25 AM   #20
2005 Mustang GT
13.4@103
Would a cam follower cause a decrease in power?
Threads Similar to: Stange noise from engine **with video**
noise from engine Toph6888 V6 Mustangs 1 February 9th, 2008 09:41 PM
Engine Noise? coltonrobertson V6 Mustangs 3 August 27th, 2007 08:51 PM
engine noise DCstangGT 99-04 25 July 31st, 2007 08:10 PM
Engine noise energiesource 99-04 4 May 17th, 2007 03:43 PM
Help With Engine Noise AM1AW 2005 - 2010 3 September 17th, 2006 07:22 PM
