Official Problem Thread
Ok, the other progress thread is getting too long so I figured I start this one to see if I can get an answer.
The timing on the driver side chain is accurate, it has not moved. The timing on the passenger side may be off, not 100% sure. I realize that the most accurate way to check timing is to pull the front cover. However, after looking over the Ford service manual, I do not have the tools for this and it looks quite extensive. My question: Is there anyway to retime the PASSENGER'S SIDE without taking off the front cover? Is there some way I can use the orientation of the driver's side (which is accurate) to retime the passenger's side? This is a crucial part of the install for me so please give me all the advice you may have. Thanks in advance
![]() Under Construction |
2007 GT
if you dont get it figured out. give me a call tomorrow. I read through the other thread. but it will be easier if you explain to me exactly what happened. I can get you on the phone with someone to help you.
Why do you think just one side is out? becuase the chain came off the gear on that side. |
#3 | |
mickey, 07stanggt may have already got
you straightened out, but just in case.... it seems to me if you want to use the drivers side as a reference, then you could: set cylinder #5 (drivers front) to TDC of a stroke in which all valves are closed (like after the compression stroke). hook up compressed air to that cylinder and pressurize it. turn the crankshaft until air starts to escape out of the exhaust valve. note the number of cam degrees turned. now do the same thing on cylinder #1 (passenger front) making sure the piston is at TDC after compression stroke. turn the crankshaft the same direction as before and note the number of cam degrees turned, before air escapes from the exhaust valve... you might be able to visualize this (without using compressed air), but i don't know how accurate that would be....it's early and this is the best i can come up with before my coffee..... let us know how you actually end up doing it.... Last edited by hammeron; December 29th, 2008 at 11:52 AM. |
ive been using tdc to change the springs so i know what you mean...however, how would i note the number of cam degrees turned?
BWAL Is My Hero
2003 F150 S-Crew 5.4 FX4
Mark a tooth. Then mark a coinciding visual reference point( Something you can watch the teeth pass accuratly).
2005 Mustang GT
12.0 @ 117+
Keep up the good work...
These things take longer than expected... my heads/cams change took a month (and a hurricane) b/c of 'small' unforseen. I luckly had someone there with loads more knowledge than me, yet, after a week was when I started getting anxious. I wish I could help more, but unless I have it in front of me, I'd hate to lead you astray. We'll ALL have gooooooood stories to tell at our next HRP meet
thats for sure
2008 Mustang GT
13.124@105.52
Why do you suspect that you lost time on that cam?
Hurst Crew Member #20 2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
chain may have slipped when my buddy and i were putting the sprocket on the chain...MAY have slipped...better to be safe than sorry
ok, i have a chance now to clarify
something. the number of degrees each cam turns before air escapes out of the exhaust valves should be the same (or very very close). so if the passenger side cam turns a different number of degrees (could be less, could be more) before air comes out, you know that the sprocket is not in the correct position on the chain. you would need to adjust it's position accordingly. |
Threads Similar to: Official Problem Thread
| The Official 4.0 Exhaust Thread | WLJohnson05 | 2005 - 2010 V6 | 15 | February 4th, 2012 04:33 AM |
| The Official MM Recipe Thread! | Mustangshar | The Clubhouse | 20 | December 9th, 2008 06:33 PM |
| official ike thread | thorpedo26 | The Clubhouse | 26 | September 13th, 2008 01:18 AM |
| Official ProBowl thread! | MustanG_guy17 | The Clubhouse | 6 | February 11th, 2008 02:28 AM |
| Official Jackass 2 Thread | turp | The Clubhouse | 11 | September 26th, 2006 11:11 AM |
