throwing a code
Old December 29th, 2008, 02:44 PM   #1
Ho_Edge's Avatar
2006 Mustang GT
havent been yet
Ho_Edge is on a distinguished road
throwing a code
my emmissions control light came on the other day and i havent changed anything recently...hell its been prolly 6 months at least since i took the cats out....anyway i'm throwing a code now and this is what SCT said it was
the first 0 is a zero
l
l
P0153 OX S CIR
SLW RESP 2 S1
aassuming this means ...somethin with the 02 sensors?
slow response to driver side?
anybody know what this is for or how to fix?
i thought brenspeed turned them off with my last tune
thnx in advance!
Powerhouse 4" Driveshaft
JLT CAI
Xcal2 + Brenspeed 93 tune
Flow 40s
custom fab'd O/R Hpipe
Old December 29th, 2008, 03:44 PM   #2
Black Baby II's Avatar
2007 GT / CS
Black Baby II will become famous soon enough
Based on the code manual it is as follows -
P0153- Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 2.
I had this happen awhile back for no reason as well. I used my tuner (SCT) to clear and has not returned since.
BBII
Paxton 2200 SL, BBK Equal Length Shorties, Pypes Off Road X, Corsa Axle Back, Hurst Short Throw, J&M UCA / LCA / Adj Pan Rod, BMR Drop / Relo Brkts, FRPP STB / 4:10's / Diff Support / Hot Rod Cams, SCT Brenspeed Tuned, + other stuff
Cammed Crew #2
Old December 29th, 2008, 03:49 PM   #3
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
I would just clear it. It most likely won't come back on.
ΜΟΛΩΝ ΛΑΒΕ
Old December 29th, 2008, 04:05 PM   #4
BlackedOut04GT's Avatar
14.21@97.93 2.107 60' (Best pass. So far.)
BlackedOut04GT has a spectacular aura aboutBlackedOut04GT has a spectacular aura about
Send a message via AIM to BlackedOut04GT
When ever I get a code I clear it and wait to see if it comes back. If it comes back the same code then I'll look it over and see whats wrong.
Old December 30th, 2008, 12:45 AM   #5
Ho_Edge's Avatar
2006 Mustang GT
havent been yet
cool thnx, i'll clear it and see what happens
JLT CAI
Flow 40s
Old December 30th, 2008, 12:54 AM   #6
06GTMustang89's Avatar
2006 Mustang GT 6spd
12.61@109mph
06GTMustang89 is a jewel in the rough06GTMustang89 is a jewel in the rough06GTMustang89 is a jewel in the rough06GTMustang89 is a jewel in the rough
Send a message via AIM to 06GTMustang89
Its a problem with some of us who have LT headers since the o2 sensors are moved from there original position (further down)...but everytime mine pops up i clear it with the tuner and it goes off for a long time..
JLT CAI: KOOKS LT's: Comp NSR II's: 4.56's: TR6060: Steeda LCA, UCA: QA1's: Roush rear springs...see garage for more.
Old December 30th, 2008, 01:39 AM   #7
ttr038's Avatar
2006 Mustang GT
ttr038 is on a distinguished road
Mine throws the same code everytime I drive it, Would replacing them help or just be waisting money?
Old December 30th, 2008, 06:06 AM   #8
mustangmallory's Avatar
2006 Mustang GT
mustangmallory will become famous soon enough
Send a message via AIM to mustangmallory
Will eliminators fix this problem?
Old December 30th, 2008, 10:04 AM   #9
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
There is no need for them to be replaced. Do you have headers?
No, these are concerning the upstream o2 sensors. Eliminators trick the computer into thinking the cats are working fine when they really aren't there because you installed an o/r midpipe.
ΜΟΛΩΝ ΛΑΒΕ
Old December 30th, 2008, 08:23 PM   #10
ttr038's Avatar
2006 Mustang GT
Yes, long tube, H pipe, High Flow Converters
Old January 3rd, 2009, 09:00 PM   #11
ttr038's Avatar
2006 Mustang GT
Tuff luck
Talked to some guys from local shop, they said "welcome to long tube headers". Check it once a month to make sure its the same code and live with it.
Old January 4th, 2009, 10:32 AM   #12
MorePowerMike is on a distinguished road
That's insanity. A properly set up tune should not throw codes, even with long tubes.
Old January 4th, 2009, 10:38 AM   #13
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
Originally Posted by MorePowerMike View Post
That's insanity. A properly set up tune won't throw codes, even with long tubes.
Not true. You can't account for mechanical failure in a tune. If he lost a gasket or is running accessively lean/rich you will through a code. Get the drift?
So, lets say he was running even slightly rich, but for a long time. It slowly killed his 02 Sensor (mechanical failure) and now its respond super slow. Even slower than normal. Therefore he gets a CEL.
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old January 4th, 2009, 10:43 AM   #14
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
I think it throws this code because being farther back in the exhaust the o2s take longer to warm up and throw this code. I think in the tune you can delay the o2s turning on so it won't throw this code.
ΜΟΛΩΝ ΛΑΒΕ
Old January 4th, 2009, 10:47 AM   #15
For the situation above, you are correct.. Mechanical faulty O2s may cause that.
For the situation in the quote above. This is correct as well. The Tune needs to know that the location of the O2s has changed. This is way more common with 05 and up Mustangs and Longtubes.
..::Gotta Have That Power::..
Old January 4th, 2009, 10:47 AM   #16
BWAL Is My Hero
JakeM's Avatar
That would do the trick, Red, as long as the 02 isn't already to far gone.
Old January 4th, 2009, 10:48 AM   #17
Semper Fi
beefmobile's Avatar
2006 Killer
beefmobile is a jewel in the roughbeefmobile is a jewel in the roughbeefmobile is a jewel in the rough
so if i get LT's, high flow cats, splice in my current X pipe, i can hook up my o2's and they be functional?
USMC CREW
NCMM ORIGINAL CREW
You would think they used camm'd LS1's to launch space shuttles.
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
(Must be 18, void where prohibited, not available in all states, restrictions apply)
Good Night Chesty, Wherever You Are
Old January 4th, 2009, 10:49 AM   #18
BWAL Is My Hero
JakeM's Avatar
Only the Front two if your X is offroad. But yes. You may also need extensions.
Old January 4th, 2009, 10:51 AM   #19
Semper Fi
beefmobile's Avatar
2006 Killer
no i said w/ LT's. that would only leave the actual 'X' left...
USMC CREW
NCMM ORIGINAL CREW
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
Old January 4th, 2009, 10:54 AM   #20
BWAL Is My Hero
JakeM's Avatar
I understand that. But if you are running Cat's then you can use all four 02's is what I'm saying. Regardless of your header/manifold choice. On the other hand, if your running a offroad x-pipe, AKA no cats, you only run two 02's. You may need extensions for your front two 02's either way because they are likely placed farther back than on the stock manifolds.
Threads Similar to: throwing a code
My car is throwing a code P1159 - 01 v8 4.6 gt tls01gt General Tech 3 August 12th, 2008 09:17 AM
Throwing a code BLK01SS 99-04 10 June 23rd, 2008 12:40 PM
GF throwing $h!tf!t cause I'm on MM to much!!! G.T. Rags The Clubhouse 82 September 11th, 2007 01:30 PM
Service Engine Soon Ligh - throwing new code. Kevin 99-04 6 September 3rd, 2007 11:59 PM
Throwing a P1152 Code... ChrisJ 99-04 9 March 12th, 2007 06:14 PM
