2005 Mustang GT
12.0 @ 117+
Is there a way to map a/f w/ Livewire?
Is there a way to map or log a/f with Livewire?
I have a friend with an older cobra who does this. You have to use a wideband 02 sensor though. He said something about using an 02 sensor from a volkswagon beetle or something which costs 40 bucks and is a wideband. Then you have to have a signal conditioner to convert it from the output voltage of the 02 sensor to an actual A/F ratio. You would have to mount this in your exhaust before your cats or else it will not get accurate readings. Sorry its broken information, but if you do a google search for using volkswagon wideband 02 sensors, you can probably find out what year and model that was and also a cheap signal conditioner. Hope that helps some. Oh yeah, he uses an X-Cal II.
Yes, you will need a wideband O2 sensor as mentioned above. You will also need a firewire cable; you'll be cutting it in half and wiring it up to the output cables of the wideband.
Attached is the wiring diagram; if you end up connecting a wideband you will need it.
..::Gotta Have That Power::..
Threads Similar to: Is there a way to map a/f w/ Livewire?
| Engine Map | StangMang | 5.0 Mustangs | 5 | November 7th, 2008 10:18 AM |
| I found a Map | HMUSN | The Clubhouse | 8 | December 29th, 2007 07:07 PM |
| Google Map | Cricket | The Clubhouse | 20 | April 12th, 2007 11:14 PM |
| MAP sensor | ROBBED666 | 2005 - 2010 | 0 | October 9th, 2006 04:12 PM |
