pistons after boooom
Old January 2nd, 2009, 05:57 PM   #1
forensicsteve will become famous soon enough
Went visit Lance today. Had a chance to see the pistons after little trouble we had three weeks.
The new MMR pistons are being shipped monday. Bunch of other stuff already delivered (headers, head gaskets, bearings, motor studs, Brisk plugs, GT500 throttle body), just waiting to be installed. JPC intake manifold expected in two weeks. Custom meth jets and new intercooler due in next week. Holiday season delayed most of the shipping.
Then let tuners TPS do their magic and then back to the track. We're staying at 22 lbs of boost. Should comfortably be in the high 9s (the two 10.0s were with car misfiring and fouled plugs) and that's about it for this car. Stay around 9.7-9.8 and race more.
Old January 2nd, 2009, 06:26 PM   #2
ROUSH STAGE II's Avatar
2005 Turbonetics Baby!!!
ROUSH STAGE II is just really niceROUSH STAGE II is just really niceROUSH STAGE II is just really niceROUSH STAGE II is just really nice
Sorry about the misfortune steve, I'm sure it'll happen to me sooner or later too. Which headers did you go with for the rebuild?
Turbonetics baby!!!
11.23@122 mph...
Old January 2nd, 2009, 06:28 PM   #3
IBEATU
stanglifemike's Avatar
06 GT, 98 GT, & 93 Notch
stanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nice
Ouch!!!
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
Old January 2nd, 2009, 06:38 PM   #4
Think they are Pypes?
You're right about the bound to happen part. It's unnatural stresses we're placing even on the built parts and we expect failures. That's why we had a little team meeting recently and decided that staying at consistent high 9s would be less hassle, a lot less expensive, theoretically a lot less down time, and just generally more fun.
Old January 2nd, 2009, 06:41 PM   #5
Sounds like a good plan. I'm budgeting around the low 11's myself.
Do the Pypes look like they are made well?
Turbonetics baby!!!
11.23@122 mph...
Old January 2nd, 2009, 06:44 PM   #6
Only gave them a glance. Actually I could have stared at them for an hour and still couldn't answer your question. They were nice and shiny though. Lance was happy with them.
Old January 2nd, 2009, 06:47 PM   #7
Okay, thanks.
Turbonetics baby!!!
11.23@122 mph...
Old January 2nd, 2009, 08:44 PM   #8
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
hmmm.. what was the ring gap set at? what oil did you use to break in (and how did you break it in?) what ring set?
thats definitly piston failure.
sorry about that.. hope the blocks not scared up to bad.
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
Old January 2nd, 2009, 08:51 PM   #9
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
WOW !!! things that make you say huh? that is not the way pistons break very often... I can't even guess how that happened...
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old January 2nd, 2009, 09:03 PM   #10
qwik48r's Avatar
alotta shit
no fat girls fast
almost looks like a lot of negative crank case pressure grey... but I know thats not possible..
they look like 2 piece pistons (wtf???)..... with those fancy "anti friction" skirts... and it looks like the head seperated from the skirt. Probably due too huge cylinder temps.
qwik's build
Old January 2nd, 2009, 10:22 PM   #11
2006greyGT's Avatar
11.08@125.22
yea but there doesn't seem to be any melting... could you see through the hole to the inside? I have told myself that I am going to stop at 10 sec.. then try to get it to run low 11's all day without killing it knowing I have more.. at least for this year
[IMG]
Old January 2nd, 2009, 10:46 PM   #12
I haven't a clue (just me...not the others) how all this stuff works. Think it's likely that the boooom was simply the end result of developing issues that started many months ago. It just all came to a head at 27 lbs of boost. The oil pump had failed a couple of weeks prior at the track. Before that one of the GT500 pumps failed at least twice during dyno runs and air/fuel was seriously disturbed. It's possible that our little excursion into nitrous land didn't help.
We're taking measures to reduce chances of repeating this experience. Firstly, stay at 22 lbs. Instead of measuring air/fuel based upon an average of 4 or even all 8 cylinders (we suspect that although AFR was showing safe, 2 or more cylinders were rich, and others running quite lean), each cylinder will be measured independently. The JCP intake manifold is designed to support this effort.
Even so, it's a gamble. We speak to a lot of different heavy-duty racers and builders and nobody it seems escapes such mishaps. Fortunately it's a team effort now and there's a lot of expertise to draw from....no egos....just a bunch of different folk on the same page and sharing a passion for dragracing and S197 mustangs.
Old January 3rd, 2009, 01:09 AM   #13
TheUNZippee!'s Avatar
So much pressure, so little time.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old January 3rd, 2009, 03:15 AM   #14
psycho bob's Avatar
07 GT
12.86@104
psycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to all
Send a message via Yahoo to psycho bob
well steven....it looks like you got your new paper weight for the office. NICE, but it is quite the expensive paper weight
Originally Posted by RZNCAIN View Post
I didn't check for spelling so fuck off with your grammar police.
http://www.moddedmustangs.com/forums...build-bob.html
Old January 3rd, 2009, 07:52 PM   #15
2006greyGT's Avatar
11.08@125.22
Well I don't have people,or a team,so you are in quite a different situation there...I already did the "rod bearing spin/build a stroker" routine and will be finished paying for it by the time the strip opens in mid March....Hell, I threw my clubs in the trunk and played a round of golf this morning then dropped the top on the way home and was ready to kill anyone who tried me.. no one did.. I guess driving to the course wearing the drag radials was a little over prepared but without them I can't race any one...
[IMG]
Old January 4th, 2009, 08:44 AM   #16
psycho bob's Avatar
07 GT
12.86@104
next set of tires for those 20's need to be some nitto's grey. that way you'll look a little more inconspicuous
Old January 4th, 2009, 08:47 AM   #17
kenneth's Avatar
2006 Mustang GT
11.45@123.61
kenneth has a spectacular aura aboutkenneth has a spectacular aura about
Hey Steven, pinks is coming up next month. If car is ready are you'll planning on racing in it.
Track opens Wednesday for test-n-tune I'll try to be out there to see the difference the supershaker made.
Is the ford GT in your avatar your new daily driver.
Stock for now.
Old January 4th, 2009, 09:59 AM   #18
2006greyGT's Avatar
11.08@125.22
Yes... I am already looking for a shop to put them on... the Toyo's are just plain wore out I am going to smoke the rest of them before I trash them... I'll get some good video out of them...
You LA. guys can kiss my A** .... J/K I hate you and your warm weather and your freaking track opening in January... I wonder how much it would cost me to trailer my car down there????
[IMG]
Old January 4th, 2009, 02:45 PM   #19
kenneth's Avatar
2006 Mustang GT
11.45@123.61
How about a road trip, by time you get here your old tires should be shot.
Stock for now.
Old January 4th, 2009, 03:05 PM   #20
2006greyGT's Avatar
11.08@125.22
I don't know if I can trust it to go that far... and I would need to bring a spare set of tires.. I have a truck that can make the trip... the only problem is that is has a snow plow on it that has to be used here if and when it snows...
[IMG]
Threads Similar to: pistons after boooom
Pistons 68 dlxcoupe 4V / SVT 21 July 29th, 2008 01:11 AM
pistons mmvi V6 Mustangs 32 September 2nd, 2007 09:18 PM
pistons notsoslow50 5.0 Mustangs 2 August 22nd, 2007 11:30 AM
Pistons kmjsmith 2005 - 2010 0 May 29th, 2007 01:38 PM
pistons the misfit wolfie General Tech 3 January 31st, 2007 06:09 PM
