2009 Corvette
Hurst shifter rattle on new shifter
I added a Hurst shifter when I got the 4.10's put in and it seemed quiet at low speeds, but between 2500-3000 RPM under hard acceleration the knob rattles like a coffee can full of marbles. Seems like a little bit more noise/vibration compared to the stock shifter, but not bad at all other than the knob rattle. It's nasty sounding. I'll be searching the posts about this problem and see if I can't make it stop. Other than that I love the shifter.
2009 C6 |
MMs Ford Racing Nut Swinger
2007 MUSTANG GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Not properly installed.. That's all.
Made in U.S.A.
2011 F150 FX4
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 8 reviews
I've seen quite a few Hursts that were properly installed that rattled.
Had the same problem after I installed mine, and it turned out to be somewhere in the parking brake mechanism. I know they're not connected, but next time you drive the car and get it to where it's makin noise lift the parking brake handle just a little bit and see if the noise goes away. You might also try just pushing the little button on the brake handle and see if that's it.
Steeda CAI, JBA Shorties, Comp Stage II NSR Cams, SLP Loudmouths, Mac Pro Chamber, Hurst Shifter, 18" DD Black Bullitts, Brisk Racing Plugs, FRPP 39# Injectors, and last but not least, Saleen Series VI SC. |
#6 | |
Made in U.S.A.
2011 F150 FX4
Semper Fi
2006 Killer
i properly installed mine, but loctite on the bolts
put lithium grease on the knob and the ball joint put silicon between the shafts still rattled don't worry about it. cosmetic issue. short throw+rattle=who gives a fuck. |
Made in U.S.A.
2011 F150 FX4
My MGW doesn't rattle ...
2005 Mustang GT
hursts are know for it, my ebrake lever did rattle i found a thick double sided tape and stuck a strip of it under the plastic of the ebrake handle.. no more rattle
puedo tocar tu gato? |
Threads Similar to: Hurst shifter rattle on new shifter
| Hurst shifter rattle question | Humphry | 2005 - 2010 | 32 | January 2nd, 2009 11:09 AM |
| Hurst Comp plus shifter "vibration" rattle... | rickles512 | 2005 - 2010 | 6 | October 10th, 2008 02:56 PM |
| hurst shifter ? | speed freak | 2005 - 2010 | 20 | September 13th, 2008 03:49 PM |
| Hurst Shifter Rattle | kevio | 2005 - 2010 | 11 | June 23rd, 2008 09:27 PM |
| Rattle From Hurst Shifter On '08 GT | Oddball | 2005 - 2010 | 9 | December 17th, 2007 05:29 PM |
