Help with supercharger parts list
Old January 11th, 2009, 02:43 PM   #1
Merenth is an unknown quantity at this point
OK guys, getting ready to buy the Kenne Bell 2.8L Mammoth supercharger kit (going for about 650-700 RWHP), and I want a little help on what else I need to do to make sure I don't turn my car into a hunk of scrap metal. Here's a basic list of things that I'm pretty sure should be replaced, and please add as you see fit.
Forged bottom end
Driveshaft
Rear gears
Flywheel (aluminum or steel?)
Clutch
Radiator
Wheels & tires
Brakes
Added:
Axles
Transmission
Fuel Pump/Injectors
Full rear suspension
Old January 11th, 2009, 02:48 PM   #2
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
Ok... I'm glad you know what you want. Now, are you buying the complete 2.8 kit from JPC or what? What comes with the kit your looking at?
Keep in mind suspension. Your going to need some pretty hardcore suspension to put 600+RWHP to the ground.
Suspension parts your going to want to research:
Rear lower control arms
Rear upper control arm and a heavy duty mount
Front and Rear sway (Depending if you plan on only going in a straight line fast.)
Shocks & Struts
Don't forget if your going to take it to the track, at that power level, your going to at least need a roll bar if not a cage.
Also, it would help if we knew your goals with the car. Not just the number you want to run on the dyno. What are you planning to do with the car?
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old January 11th, 2009, 02:55 PM   #3
All sissies going to Hell!
navyman8903's Avatar
2008 BULLITT #3385
Killing with a smile
navyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to allnavyman8903 is a name known to all
2006greyGT should know something also hope he chimes in.
BULLITT CREW FOUNDER (The real one)
Bassani Crew Member #5...HARDCORE CREW
MILITARY CREW
E-5
MA2(AW)
Personally, I think being railed in the shitter would make you a meaner more violent fighting machine.
Old January 11th, 2009, 03:02 PM   #4
BWAL Is My Hero
JakeM's Avatar
I'd hope so. Only hes got a 2.6H not a 2.8. Totally differen't lower intakes. Similar power curves though.
Old January 11th, 2009, 03:10 PM   #5
Buying the complete kit direct from Kenne Bell (supercharger, intake, fuel pump, injectors, etc.). Already have the rear suspension, but not the heavy duty mount. Also I will most likely be changing out as much of this from steel to chromoly as possible. This is going to be for drag racing only, though street legal. Not intending any autocross or street racing. Sway bars are a good idea though at that level. Good point. At some point nitrous may be added to the car, but that's down the road after new heads and cams. The overall goal is a car with approximately 900-1000 RWHP. This is the first RWD car I've modded to this level, so I'm not sure how it will react applied to just 2 wheels instead of 4.
Old January 11th, 2009, 03:10 PM   #6
leebunnyz's Avatar
leebunnyz has a spectacular aura aboutleebunnyz has a spectacular aura about
650-700whp your going to need a stronger tranny.
Jesus Christ is #1
"The Founder Of Crews"
Old January 11th, 2009, 03:11 PM   #7
leebunnyz's Avatar
or just ride it out until it fails.
Jesus Christ is #1
Old January 11th, 2009, 03:20 PM   #8
That's more or less the idea for the moment. Anybody have the names of a couple reputable shops that do transmissions for the S197 at that level? Found plenty of places that do normal rebuilds or ones for about 500HP, but not 650+
Old January 11th, 2009, 03:29 PM   #9
TheUNZippee!'s Avatar
You're going to want to upgrade the diff and axles as well.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old January 11th, 2009, 03:35 PM   #10
At what point do the stock axles give out? Any experienced failure yet?
Old January 11th, 2009, 03:38 PM   #11
There's been a bunch of guys break diffs and axles. Most of the factory stuff, the trans, the diff, the axles, is good up to roughly 500 at the wheels....and at that point it depends on luck and how you drive it.
If you put down 700 to the wheels, it's just a matter of time until you break something if you don't upgrade it.
Old January 11th, 2009, 03:39 PM   #12
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
I didn't see what year Stang your building?? if it is an 05+ and you want 650+ you will surely need a transmission as well... and adjustable Upper control Arm... I am still running stock radiator and added drilled and slotted rotors.. there a few other KB guys in here and I am not making the kind of power you want to as my car is still a daily driver. 05mustang_KB_charged has the same type of power you want and he will be the guy to talk to... he hasn't been around much lately but he'll see this..
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old January 11th, 2009, 03:39 PM   #13
There you go, that's the man to talk to^
Old January 11th, 2009, 03:42 PM   #14
2006greyGT's Avatar
11.08@125.22
we already have 31 spline axles and they are almost as strong as the Mosers.. run them till they break... just got done looking for them and they are 350 a pair... another thing your going to be required to have in at least an 8 point cage
[IMG]
Old January 11th, 2009, 03:51 PM   #15
2008 BULLITT #3385
get GT 500 axles they are stronger. They put them in the BULLITT.
MILITARY CREW
E-5
MA2(AW)
Old January 11th, 2009, 03:57 PM   #16
It's an 05 GT. The roll cage will be for next year, as I probably won't have everything ready for the track this year anyways. I'm also planning on this being a daily driver until after the heads and cams, since that level of power is impractical on the street. I did notice that I haven't had any problems with engine temps though. Don't have the S/C yet, but I haven't noticed a difference yet. Is the stock radiator ok for the 600 RWHP level? On that same note, how many people have had success with an electric water pump? I'd rather not really since it's a daily driver and I've heard way too many stories of electrics failing, but at the track I'd like to be able to cool the engine more when I'm not running. Anybody ever set up a dual system for this?
Old January 11th, 2009, 04:02 PM   #17
psycho bob's Avatar
07 GT
12.86@104
psycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to all
Send a message via Yahoo to psycho bob
i did a lot of research into the mammoth kit and was on my way to ordering it until financial responsibilities caused me to spend my money elsewhere.
this kit alone can give you what you are looking for w/o heads or cams.
Currie Enterprises Crate Rear End Products
http://ddperformance.com/
New - Livernois Motorsports - Home
RAD Mustangs Performance Parts Shop talk to rich (07stangGT) he'll hook you up
Originally Posted by RZNCAIN View Post
I didn't check for spelling so fuck off with your grammar police.
Old January 11th, 2009, 04:04 PM   #18
05roush0090's Avatar
2005 Mustang GT Roush
05roush0090 will become famous soon enough
I dont think the supplied KB fuel upgrades will be sufficient to support 600-700rwhp. I think they send you a BAP and 39lb injectors is all correct? I would think you would need dual pumps at least and 60lbers.
2005 BLACK Mustang GT Roush #05-0090
DOB manifold, m122 SC, gt500 TB, 52lbers, KB BAP, AFCO HE,Brisk plugs, Mac Lt's, Off road x, Roush TVS CAI, Detroit rocker sc grind cams, Brenspeed 93 tune,
10 psi (2.875" pulley) 470rwhp-419ftlbs sae
Old January 11th, 2009, 04:06 PM   #19
Good links! Livernois is who I'm going with for the bottom end. They seem to have the best reputation with our engines. That and the fact that they use new blocks instead of rebuilding engines helps.
05roush0090 - You appear to be right about the BAP and injectors, though why on earth they would send out parts that barely meet the specs at the lowest end of the mammoth capabilities I don't know. Though yet again, that's another question... fuel line upgrades. At that level -8 or -10 is normally used, though I know our stock fuel system is actually fairly decent.
Threads Similar to: Help with supercharger parts list
need help making parts list. Fizban 2.3 Mustangs 2 December 31st, 2008 10:54 AM
T-5 help COMPLETE parts list fastford3388 5.0 Mustangs 9 March 8th, 2008 05:02 AM
Parts List jblood37 99-04 8 April 14th, 2007 05:53 PM
parts suggestions list laserstang2 96-98 3 February 10th, 2007 11:44 PM
My Performance Parts List Chris02 99-04 14 November 1st, 2006 06:10 PM
