Zex Nitrous on/off switch
Old January 25th, 2009, 10:29 PM   #1
texas96gt's Avatar
n/a
texas96gt is on a distinguished road
Today I saw my friends Zex Nitrous system that was installed a while back on his 08 GT. There is something about the way it was installed I do not understand. The power wire for the on/off switch was spliced into a wire from the wiring harness that plugs into the fuse panel under the dash on the passenger side. Is this typical? Why would you splice into a wiring harness that possibly going to you PCM? I would think you would run the power wire straight from the battery. Any thoughts?
BBK CAI, BBK Plenum, BBK 70mm TB, 4.10 gears, BBK o/r H, FRPP headers, 2003 cobra's 255/40/18 front, 285/35/18 rear, Flowmaster 40 series.
Old January 25th, 2009, 10:33 PM   #2
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
I would need to see a wiring diagram and a picture of where is spliced in. That could be any one of many non-critical accessories.
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old January 25th, 2009, 11:10 PM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
^exactly, there are many wires that you can tap into to get power that will not mess anything up. the best way to do it if you are not 100% sure is to place a fuse inline (if it does not already have one) this is to protect the component that the ZEX powerline is being hooked up to.
BUILD 2 IN PROGRESS
Old January 26th, 2009, 12:00 AM   #4
Bhblondguy's Avatar
2005 Mustang GT
12.00@114.82
Bhblondguy will become famous soon enoughBhblondguy will become famous soon enough
Hey texas96gt, I saw the exact same car today. Imagine that I'm glad that you and I spent 4 hours fixing the jacked up wiring that someone didn't get right. It also had 4 (four) holes drilled into the bottom of the trunk that didn't need to be there, and the bottle brackets are so far to the side and crooked in the back, you can't even strap the bottle in correctly.
Old January 26th, 2009, 12:00 AM   #5
Bhblondguy's Avatar
2005 Mustang GT
12.00@114.82
not to mention the purge doesn't work
Old January 26th, 2009, 12:00 AM   #6
Bhblondguy's Avatar
2005 Mustang GT
12.00@114.82
we'll have to go in and fix that ourselves too.
Old January 26th, 2009, 12:02 AM   #7
BWAL Is My Hero
JakeM's Avatar
Eeeek... Sounds like you guys are working out someone elses nightmare eh?
Old January 26th, 2009, 12:06 AM   #8
Bhblondguy's Avatar
2005 Mustang GT
12.00@114.82
and let's not mention the header exhaust bolt hole that got stripped out and was causing the exhaust leak, AND the new header gaskets he paid for but instead, someone put the STOCK gaskets back on the car.
Old January 26th, 2009, 12:14 AM   #9
08blackchrome's Avatar
2008 Mustang GT
11.897 @ 116.72 w/1.803 60'
08blackchrome is on a distinguished road
he forgot to put a valve cover bolt back in too, and my brand new nitrous bottle is all scratched up from "someone"
FRPP Hot Rod Cams, Mac LTs, Mac ORX, Pro 5.0, 2 Step, 100 shot Zex Kit, BMR K-Member,A arms,
CHE LCA and Anti Squat
BMR springs, CHE UCA, MotoBlue Pulleys
Steeda Delete Plates, C&L Racer,
4.10s, 305/35 Shittos, 1pc D/S, Flowmasters
Old January 26th, 2009, 08:26 AM   #10
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
Were the installers reputable? I run into some garbage wiring all the time. If it starts taking me diagnosis time to figure something out, I'll just rewire the entire thing. Run into too many dead ends, splicing, tapping, and whatever else some of these hacks like to do. Sometimes it's quicker to start fresh.
That said, I brought an 8 guage off the battery into a fused distribution block for all of my accessories to come into a main hub. This way I have control of everything independently from all of the rest of the cars wiring. Provides an easy diagnosis point, as well as a central location as things get added on. Plenty of room behind the glove box and under the center counsel for a good sized hub.
FLICKR Unique Imagery
Old January 26th, 2009, 09:18 AM   #11
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
A lot of shops will put the stock header back on the car. Its about the best gasket out. But most of the time they would ask the customer first.
Old January 26th, 2009, 10:57 AM   #12
Bhblondguy's Avatar
2005 Mustang GT
12.00@114.82
if someone asks if you want new gaskets and you tell them yes, and purchase them, they should go on the car. period.
Emay, we did have to start fresh with a few things on that car. That includes going to a different tuner, as well as re-wiring the previous tuners work.
Old January 26th, 2009, 11:02 AM   #13
chad05gt's Avatar
2005 Mustang GT
12.0 @ 117+
chad05gt has a spectacular aura aboutchad05gt has a spectacular aura aboutchad05gt has a spectacular aura about
[QUOTE=07stanggt;1777257]A lot of shops will put the stock header gasket back on the car. Its about the best gasket out.
Yup...I went back to stock gaskets during head change.
built 302 on its way...and 67mm turbo,
No N20, No boost, ALL N/Asty!
12.0 @ 117+
FRPP intake, (thanx Joe)...
Fucking chad in my kitchen drinking my damn Kool-Aid. Fucker.
Old January 26th, 2009, 11:05 AM   #14
2007 GT
No i agree they should have said something. I was more refering to like people ordering headers online that come with gaskets, kooks for example and then shops that dont use the supplied gaskets, but even then, they should ask first.
Old January 26th, 2009, 11:08 AM   #15
Bhblondguy's Avatar
2005 Mustang GT
12.00@114.82
exactly. The new shop we took the car to put 3 layer gaskets on the car and fixed the leak. Also they re-tapped the stripped out header bolt hole.
Old January 26th, 2009, 01:28 PM   #16
BWAL Is My Hero
JakeM's Avatar
Erin, What did you use for a distrobution box? That is a great idea.
Old January 26th, 2009, 02:16 PM   #17
texas96gt's Avatar
n/a
I have thinking about that. Do you have any pics of the fused distribution box? I think that would be the best solution for anyone that has many accessories.
Old January 26th, 2009, 03:35 PM   #18
May 08 ROTM
2008 Audi S6
I don't have pics, I did all of that while I was prepping the car for world of wheels last year so I didn't have time to do all the picture taking I would have normally.
I need to move the car over this weekend as I have a few things to work on. I'll see if I can grab a few shots While I'm in there.
Painless makes a bunch of items that are very user friendly. The best one for building a seperate accessory panel is this one here: Painless Performance: 7-Circuit Heavy Duty Auxiliary Fuse Block but there is no picture. It looks similar to some of the others they list, except it has a single 6ga that you bring into the car fused, with this breaking everything out to your accessories.
What I did (and it was far more involved because I had to loom my own harness) was fused an 8ga line into the car and used a 10 slot fused distribution block out to the accessories. I'm running all of the following off of it: GT500 dual pump hot, intercooler sprayer main power, purge, window switch, strobes, electric trunk release, line lock, and I'm forgetting one (brain fart), because I have just 2 bays left.
It's on the passenger side behind the glove box. I'll see if I can get a clean shot up in there.
Old January 26th, 2009, 03:47 PM   #19
BWAL Is My Hero
JakeM's Avatar
Thanks much for the info! Reps for sure. I was wondering about doing something simlar and wasn't aware painless had these available. Thats the hot ticket for sure.
Old January 26th, 2009, 03:54 PM   #20
Golf Pencil Kawk Juggler
2006GTARPD3's Avatar
2006 Mustang GT
509RWHP/450RWT
2006GTARPD3 is just really nice2006GTARPD3 is just really nice2006GTARPD3 is just really nice2006GTARPD3 is just really nice
Send a message via AIM to 2006GTARPD3
speaking of batterys and such, does anyone else have a problem with the optima fitment? My red top took awhile to get it fitted well enough. 15 min batt swap took like an hr. Plus adding the remote start and neon wires to it was a headache.
Procharger D-1SC Kit - Pypes O/R H - FRPP Stingers
Team Ricer GT Co-Founder
Threads Similar to: Zex Nitrous on/off switch
Zex Nitrous Purge!!! bubsdelicious 5.0 Mustangs 32 September 7th, 2008 08:01 PM
Zex window switch yamahammer 2005 - 2010 2 September 6th, 2008 07:24 PM
nitrous,nx or zex tom2000r 99-04 27 February 3rd, 2008 09:54 PM
zex nitrous APER 2005 - 2010 6 August 30th, 2007 06:37 AM
Installing Zex window switch ! Tach wire help NEEDED calpat1985 99-04 0 May 8th, 2007 07:59 PM
