Need advice on purhcasing a supercharger....
Looking to tap into some experience and expertise... I have decided to move forward and install a supercharger..... My research is leaning me to the Kenne Bell Twin Screw Supercharger (8 PSI Intercooled); however, they have yet to develop the tune for the 07 model. They are expected to do so over the next month or so.....
Can I get some success stories for the '07 model? Anyone direct me to the best deal for purchase??
roushcharger reall good thats what i want to get
On Probation
If you want a really good, very streetable blower w/ great power increase. i would go with a Saleen Blower. If you have a ford tech install it, you don't lose your factory warrenty and you can get an easy 420 rwhp.
They give great torque, moderate boost levels (8-14psi) great driveability. it's the perfect street/strip blower. |
On Probation
IBEATU
06 GT, 98 GT, & 93 Notch
I'm torn between roots or centrifigal???
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
#7 | |
On Probation
Ihave a roush s/c fun to drive. Dont know what the others are like probably fun to drive also. went with the roush, dealer install for warrenty. I think it was worth every dollar,
I Love my Ford Racing / Whipple Supercharger!!
Great power, great torque, reputable Ford tune, complete system with GT 500 fuel pump, spark plugs, everything needed for the job and I could not be happier! |
2006 Mustang GT
After speaking with a reliable dyno shop, the real answer is a centrifical(Vortech) and screw type (KB) will essentially net the same area under the horsewpower and torque curves. The screw type will come on earlier and peak sooner and the centrifical will come on later but climb steeper up the curve giving more power on the top end.
It's a matter on preference on your part. The best bet is to make a decision on what you want to get out of the car. I'm going for a Whipple and a complete tune session with my dyno shop to maximize the set up. Good luck on your choice! |
#11 | |
![]() its not how fast you can drive.... its how well you can drive, while going fast... why should i tip-toe through life only to arrive safely at death?? |
#12 | ||
#13 | |||
2008 Mustang GT
STS Twin Turbos if the stock block can hack it - otherwise single turbo.
Look Ma! My First Post!
I Can make anyone a good deal on a brand new roush Supercharger kit Cheaper then anywhere else i have seen so low you will have to PM cause i cant advertise it
Thanks nick |
#16 | ||||
give this guy a call Jared @ Lethal Performance 877-2LETHAL he'll hook you up. tell him paul from NJ sent you |
how do those things run? power up high or down low?
how much does it effect intake temps on the highway? how loud is it? does it fit under the stock hood? i know i have to do some reading on it, but sinee you have one thought i ask...
#18 | |
Also, I believe the roots generate more heat which can be overcome with an intercooler, and I think it's the Saleen that will need special motor mounts to lower the engine if you want it to clear a stock hood.A nice cowl hood will solve this problem as well. All blowers will make noise, but it's a noise to behold!! |
#19 | |||||
Threads Similar to: Need advice on purhcasing a supercharger....
| 07 GT...need some advice | djslcfr | 2005 - 2010 | 15 | October 30th, 2007 10:58 PM |
| need advice on upgrades for supercharger | fastlane_24 | 94-95 | 7 | July 10th, 2007 12:06 PM |
| advice | triggerhappy101 | 94-95 | 11 | June 4th, 2007 05:30 PM |
| Cam advice! | Smoph | 5.0 Mustangs | 8 | April 10th, 2007 08:35 AM |
| Some Advice Please | Vamp89 | 5.0 Mustangs | 4 | August 4th, 2006 07:29 PM |
