Aligning axlebacks with bumper holes!?
The right one fit perfect but the driver side one was a bitch to get in and i fixed it a little bit but its too far off still for me and its bothering the shit out of me and i don't want to yank the thing off again but it didnt fit easily... its just a pair of Macs... any tips?? thanks
Hammer
2008 Mustang GT
loosen the clamp at the back of the midpipe and loosen the bolts on the axel back, move everything around till it lines up where you want it and have someone hold it there while you tighten it back up.
Make sure nothing in the pipes will be hitting the diff or anything else to rattle on. |
#4 | |
ok i'll try that... i've also tried hammering with a rubber mallet and that does nothing |
![]() iTrader: 1 reviews
i had this problem with my left boom tube.. took it off and bent the mounting rods with a vice, perfectly centered
08 GT/CS 5spd C&L Racer CAI, Steeda UDP's CMCV Deletes, UPR O/R X-pipe 3.5" Aluminum DS, Stock 3.31's ![]() 1/8 th: 8.258 - 84.87 1/4 th: 12.853 - 107.31 |
2006 Mustang GT
12.76@105
I had to do a combo of both adjusting the hangars and adjusting the connection at the mid pipe because when I adjust the over axle pipe to make the tip centered, the over axle pipe would vibrate on the axle. So I bent the hangar a little bit and adjusted the mid pipe connection.
Thank you i'm going to try today and maybe post some pics
2008 GT
Oh man, I fought with mine on a lift several different weekends to get things lined up. All the advice above is true - loosen, refit and realign. Then, you get to go back and do it all over again because something is rattling! Oh boy!
Fuel Altereds Rule The Earth
2006 Mustang GT
12.76@105
The lift doesn't help either unless the lift lifts the car by all 4 wheels. If you lift the car by the chassis, get everything lined up then lower the car, it will be out of alignment again. It would be nice if we could crawl under these cars without lifting them. Maybe my uncle will let me use his pit!!
All sissies going to Hell!
2008 BULLITT #3385
Killing with a smile
rubber hammer. Bend the mounting hardware after trying the other things.
#12 | |
2008 GT
2008 BULLITT #3385
nope, but it does give you some angles I suppose.
2008 Mustang GT
13.124@105.52
Because when you load it the axle could hit the over-axle pipes.
Hurst Crew Member #20 2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Yea i used a life when i did it.... my dad has one in the garage but i am going to try and do it this weekend
#16 | |
2006 Mustang GT
12.76@105
![]() When I had the exhaust done on my Dakota I had to take it back to the shop several times because they would lift in, look at the the tail pipes and tell me it was straight. I finally had them look at it when it was off the lift. |
Threads Similar to: Aligning axlebacks with bumper holes!?
| Aligning TDC on a V6 3.8. Help Please? | lwhitetrash88l | V6 Mustangs | 3 | April 14th, 2007 03:04 AM |
