#1 | |
2005 Saleen
Livernois Stage 2 vs. Stage 3 Heads
Sorry if this has been answered, I did some searching but didn't come up on anything.
I've been reading that stage 3 heads are usually not good for street, why is this? I plan on being able to drive my car daily whenever the weather is nice. How will a stage 3 head affect drive ability? Because of the boost and cams I'm going to be running, the stage 3 heads are the best match for my setup. Rich, purchase is going to be made very soon
![]() - Phil 05 Saleen Mustang - Broken son! ![]() 01 BMW 330ci - modded daily driver
2007 GT
With the boost your running i wouldn't worry about it. To me and my n/a setup I thought I may have lost some low end with stage III heads. Either way I just didnt think i would benifit from the stage III heads on the stock bottom end n/a. You got a blower and a stroker so no shortage of torq. In your case its different.
Just my 2cents. |
#3 | |
2005 Saleen
So when people say that stage 3 heads are "not suitable for a street car" they are assuming stock block that won't get much power/mods? Cause my car is going to mainly be a street car. Only place I'll track it at is somewhere that does not require a roll cage and what not
2007 GT
Thats all a low end power thing on the steetability issue. In your case its a non issue. stage IIIs all the way in your case. Even on my setup you might be talking 15lbs down low, but it was 15lbs i dont want to give up for the addtional cost and a question of how much would i gain up top.
i'm going with an equal to the stage III's on mine, but i also got a hell of a deal on them and i'm looking at my end state not my now state. if i loose a little down low now oh well. they will be better heads for my end goal than the stage II's.
My impression is that it's more about driveability. Just had Livernois stage III heads/blower cams installed. Lance cranked up the motor for the first time since November, a couple days back, and I heard it over the phone. Sounded like a 100% race car on idle, but not particularly street user-friendly. I'm thinking the idle would really be tricky in stop and go traffic (at least in our car).
can we get a sound clip or video steven......
Hey steve what you do with your stage II heads
07 GT-- Gone But Not Forgotten Military Crew E-5
+1 on the vid.
Brought my cam to work yesterday. Lance just happened to have taken tuesday off. Today my truck is in the shop, so don't have transportation to get to the car. Might be able to use girlfriend's car tomorrow and also see if the NX kit is boxed. Also the JPC intake man. is due in tomorrow...take vid of that too. Stage II heads/cams Can't remember. Usually everything get sold locally by Lance to others that are building up their cars. I'll check with Lance. Last edited by forensicsteve; February 18th, 2009 at 11:55 AM. |
Your Mom's Favorite
2007 Mustang GT
Eats Chevys, Shits Imports...
I called Livernois this fall with the exact same question and the answer I got from them was unless you're running a dedicated track setup like Fornsicsteve, it's going to straight up suck to drive. What psi are you gunning for? I think you'd be better off running the stage 2 heads, Comp stage 2 SPR blower cams and drop your static compression to no lower than 9:1 (I assume you're going to be building the bottom end)...you'll still get a ton of power but you won't have a dog for cruising. Just my $0.02...
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER |
#11 | ||
2005 Saleen
Right now I'm probably going to run between 10-15 PSI until I can upgrade the rear end and tranny. I'm going with the Livernois 298 stroker short block as well. Why would I not be able to drive it as easy? Because of the cams? I'm just lost as to why it would be harder to drive if all that changes is low-end torque which I have made up by getting 4.10's
#12 | ||
2005 Saleen
Blank
Holy shi*, those stage 3's are the most radical Comp cam you can get Suhleen.
#14 | ||
2005 Saleen
Blank
I don't think those would be good for my N/A street car. .-.
He's not N/A. i think he's got a KB
#17 | |
2005 Saleen
There are two different versions. The XFI SPR Blower cams (obviously for blowers) and the XFI SPR cams (for n/a apps). Both have all three stages I believe (stage 3 requires worked heads). You can run the Stage 2 XFI SPR cam (which was what I was going to run) or if you upgrade your heads (which I believe you talked about), you can run the stage 3
Blank
So if I'm staying stock bottom end, but I'm getting heads I should get Stg 3 SPR? I'll talk to rich about that
#19 | |
2005 Saleen
Well idk if I would but you can lol
Blank
Those might need lockouts. >_>
I'll go with Stg 2 SPR, they'll help enough. |
Threads Similar to: Livernois Stage 2 vs. Stage 3 Heads
| Livernois Stage 3's | qwik48r | 2005 - 2010 | 26 | November 9th, 2008 11:12 AM |
| Livernois 298 stroker, Stage 3 heads and Saleen Super Shaker installed!!! | tribaltek | The Clubhouse | 41 | October 3rd, 2008 05:52 PM |
| Livernois stage II heads, Comp stage II VSR's in and dynoed | chad05gt | 2005 - 2010 | 33 | September 24th, 2008 12:06 PM |
| VT Stage 3 Heads | TheBusher | 99-04 | 15 | September 11th, 2007 06:27 PM |
