best streetable N/A
what could be the best possible N/A SET UP??
06 GT jba shorties jba axle backs pro 5.0
go look at 07stanggt his garage tells it all if you have the $$$ to do it
heads, cams, lt's, cmdp's, udp's, drive shaft, 4.10's, electric water pump, full suspension. = lots of moneyif you can do all the wrenching yourself you'll save yourself about 4 grand in labor Last edited by psycho bob; February 18th, 2009 at 04:07 PM. |
what kinda money??
2005 Mustang GT
12.0 @ 117+
or mine
is that you ryan?
![]() Under Construction |
just throw a number out there without doing any extreme math with power and supsension around 10 grand. sound about right chad.....rich....???
heads 2100-2900 depending on which ones you get cams 825 (w/ phase limiters) lt's 1200 shaft 500 cmdp 150 or 300 udp's 200 water pump i think 350-400? 4.10's 500 after install suspension depends on what you get. don't skimp do it right and you'll pass the guys with more hp misc. parts needed always add up also |
Blank
Yeah someone forgot to say stickies.
Is EagleStroker a member here? He's on a few forums. Anyway he's bored out to 301 cubic inches, and stroked obviously. Has heads and I think cams too. Puts out over 400rwhp on a conservative tune.
Probably $8,000-$9,000 at least in engine mods.
By my E-Force'd 2008 Mustang GT! |
Blank
Yep he has all the goodies. I swear he put down 385
don't need the shortblock to get to 400.
and mf i didn't say stickies because he said streetable. didn't mention anything about the track. |
Blank
Well I was just suggesting incase he intended on hitting the track. 400 is a hard number to hit. You need full bolt ons, longtubes, cams/heads, and intake manifold for that.
#12 | |
2005 Mustang GT
12.0 @ 117+
...about 15K and some change...
I do all my wrenching, so it could be much worse. Full suspension, Full stiffening, Full drivetrain, extra set of wheels for, upgraded brakes/rotors to be able to use the hp... extras like hood, facia EVERYTHING about 15K and some change... NOT including all the bad decisions (too much clutch, buying 'built' 3650 ,... ) I didnt skimp on much of anything... ...and hope for a NICE et to go with it this Sunday
built 302 on its way...and 67mm turbo, ![]() No N20, No boost, ALL N/Asty! 12.0 @ 117+ FRPP intake, (thanx Joe)... Last edited by chad05gt; February 18th, 2009 at 04:59 PM. |
Blank
I hope you hit 11's Chad.
All sissies going to Hell!
2008 BULLITT #3385
Killing with a smile
Chad will definately hit the 11's. My power build is as follows
-Stage II spr comp cams with phaser limiters -ported stage 2 heads -steeda crank udp only -meziere electric water pump -airaid intake 100mm maf(only with cams and heads) -frpp 39lb injectors -At least 4.10's -bassani LT's (which dyno joe has for a steal price right now someone snach them up!!!) -catted x-pipe -race axle backs -spyder drive shaft -findanza aluminum flywheel/ exedy clutch so all and all built top end, drive train and alot of bolt on's. And you can get there, and if you hate having a strut tower brace and want another 20-30hp get the custom race intake manifold from JPC. |
hhmm well thx, i have alot of ideas going thru my head now. i dunno i need to figure out how to do it step by step and keep my car on the street with minimal down time
#16 | |
Team Edlbrock Racing Team Magnaflow Racing
Blank
With cams,heads, and longtubes, it could be down for a week.
2 days MAX and that's with tuning.
Blank
Wow thats quick. The reason I said that is because of other cars you may be working on.
im only working on my car, so as soon i as i got everything i'd put it together. . .
but long tubes are def worth swapping out my shorties?? i also found a used gt 500 for 33k im almost thinking about doing a trade in!
Threads Similar to: best streetable N/A
| whos got the fast streetable v6? | gttowner | V6 Mustangs | 45 | August 19th, 2008 11:35 AM |
| Streetable Naturally Aspirated 400hp 4.6L, Does it exist? | ReverendDexter | Modular Mustangs | 38 | July 6th, 2008 10:24 PM |
| What is Streetable? | ModMustang97GT | Modular Mustangs | 4 | August 17th, 2007 06:59 PM |
| streetable compression | Clockman | 5.0 Mustangs | 2 | April 23rd, 2007 12:36 AM |
| 3.27s, 3.45s, 3.73s, and 4.10s, The Better Streetable Gear? | emperorx1984 | V6 Mustangs | 3 | August 17th, 2006 10:45 AM |
