VCT Operation
Old February 25th, 2009, 12:07 PM   #1
06GTMustang89's Avatar
2006 Mustang GT 6spd
12.61@109mph
06GTMustang89 is a jewel in the rough06GTMustang89 is a jewel in the rough06GTMustang89 is a jewel in the rough06GTMustang89 is a jewel in the rough
Send a message via AIM to 06GTMustang89
VCT Operation
ok so this is probably on the internet, but to make things easier for people that don't know how it works and for people that are wondering about the Phaser Limiters on these new cams...this will give ya'll a better idea of how this all works and how it actually benefits our motors.
Overview
The VCT enables rotation of the camshaft(s) relative to the crankshaft rotation as a function of engine operating conditions. There are 4 types of VCT systems.
* Exhaust phase shifting (EPS) system - the exhaust cam is the active cam being retarded.
* Intake phase shifting (IPS) system - the intake cam is the active cam being advanced.
* Dual equal phase shifting (DEPS) system - both intake and exhaust cams are phase shifted and equally advanced or retarded.
* Dual independent phase shifting (DIPS) system - where both the intake and exhaust cams are shifted independently.
All systems have 4 operational modes: idle, part throttle, wide open throttle (WOT), and default mode. At idle and low engine speeds with closed throttle, the powertrain control module (PCM) determines the phase angle based on air flow, engine oil temperature and engine coolant temperature. At part and wide open throttle the PCM determines the phase angle based on engine RPM, load, and throttle position. VCT systems provide reduced emissions and enhanced engine power, fuel economy and idle quality. IPS Systems also have the added benefit of improved torque. In addition, some VCT system applications can eliminate the need for an external exhaust gas recirculation (EGR) system. The elimination of the EGR system is accomplished by controlling the overlap time between the intake valve opening and exhaust valve closing. Currently, both the IPS and DEPS systems are used
Variable Camshaft Timing (VCT) System
Variable Camshaft Timing System
The VCT system consists of an electric hydraulic positioning control solenoid, a camshaft position (CMP) sensor, and a trigger wheel. The CMP trigger wheel has a number of equally spaced teeth equal to the number (n) of cylinders on a bank plus one extra tooth (n+1). Four cylinder and V8 engines use a CMP 4+1 tooth trigger wheel. V6 engines use a CMP 3+1 tooth trigger wheel. The extra tooth placed between the equally spaced teeth represents the CMP signal for that bank. A crankshaft position sensor (CKP) provides the PCM with crankshaft positioning information in 10 degree increments.
1. The PCM receives input signals from the intake air temperature (IAT) sensor, engine coolant temperature (ECT) sensor, engine oil temperature (EOT) sensor, CMP, throttle position (TP) sensor, mass air flow (MAF) sensor, and CKP to determine the operating conditions of the engine. At idle and low engine speeds with closed throttle, the PCM controls the camshaft position based on ECT, EOT, IAT, and MAF. During part and wide open throttle, the camshaft position is determined by engine RPM, load and throttle position. The VCT system does not operate until the engine is at normal operating temperature.
2. The VCT system is enabled by the PCM when the correct conditions are met.
3. The CKP signal is used as a reference for CMP positioning.
4. The VCT solenoid valve is an integral part of the VCT system. The solenoid valve controls the flow of engine oil in the VCT actuator assembly. As the PCM controls the duty cycle of the solenoid valve, oil pressure/flow advances or retards the cam timing. Duty cycles near 0% or 100% represent rapid movement of the camshaft. Retaining a fixed camshaft position is accomplished by dithering (oscillating) the solenoid valve duty cycle. The PCM calculates and determines the desired camshaft position. It continually updates the VCT solenoid duty cycle until the desired position is achieved. A difference between the desired and actual camshaft position represents a position error in the PCM VCT control loop. The PCM disables the VCT and places the camshaft in a default position if a concern is detected. A related DTC is also set when the concern is detected.
5. When the VCT solenoid is energized, engine oil is allowed to flow to the VCT actuator assembly which advances or retards the camshaft timing. One half of the VCT actuator is coupled to the camshaft and the other half is connected to the timing chain. Oil chambers between the 2 halves couple the camshaft to the timing chain. When the flow of oil is shifted from one side of the chamber to the other, the differential change in oil pressure forces the camshaft to rotate in either an advance or retard position depending on the oil flow.
JLT CAI: KOOKS LT's: Comp NSR II's: 4.56's: TR6060: Steeda LCA, UCA: QA1's: Roush rear springs...see garage for more.
Old February 25th, 2009, 03:09 PM   #2
12.61@109mph
does anybody appreciate this information?? Or did i post it for no reason
Old February 25th, 2009, 03:17 PM   #3
05 Mustang GT
tommy023gt is on a distinguished road
Thumbs down
The info is definitely appreciated. I was actually thinking about how it all worked when I was looking at some of the phaser lockouts and limiters out there.
Old February 25th, 2009, 03:18 PM   #4
12.61@109mph
good im glad i just saw 40 views and was like damn cuz i thought there would be discussion about it since were talking about cams soo much these days
Old February 25th, 2009, 03:20 PM   #5
TheUNZippee!'s Avatar
Dude you're lucky I didn't post this before you.
*put in sticky thread*
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old February 25th, 2009, 03:58 PM   #6
ROUSH STAGE II's Avatar
2005 Turbonetics Baby!!!
ROUSH STAGE II is just really niceROUSH STAGE II is just really niceROUSH STAGE II is just really niceROUSH STAGE II is just really nice
I'd rep you but it says I have to spread some around first...sorry bro. Great info though!
Turbonetics baby!!!
11.23@122 mph...
Old February 25th, 2009, 03:59 PM   #7
Hurry up and spread for me Roush
Old February 25th, 2009, 04:06 PM   #8
K
Turbonetics baby!!!
11.23@122 mph...
Old February 25th, 2009, 04:08 PM   #9
Whoa...I had no idea you were so easy
Old February 25th, 2009, 04:16 PM   #10
I'm fickle too.....
Turbonetics baby!!!
11.23@122 mph...
Old February 25th, 2009, 04:17 PM   #11
lol
Old February 25th, 2009, 04:24 PM   #12
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
good stuff. Didnt read it but rep'd you anyway
Old February 25th, 2009, 06:09 PM   #13
12.61@109mph
zip did you put this as a sticky?
Old February 25th, 2009, 06:19 PM   #14
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
he said he did
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
Old February 25th, 2009, 06:20 PM   #15
12.61@109mph
gotcha yeah its in there nvm lol
Old February 25th, 2009, 06:51 PM   #16
leebunnyz's Avatar
leebunnyz has a spectacular aura aboutleebunnyz has a spectacular aura about
Vtec for mustangs!...VCT jus Kicked in yo!
Jesus Christ is #1
"The Founder Of Crews"
Old February 25th, 2009, 07:54 PM   #17
UrbanRedneck's Avatar
2008 Mustang GT
13.124@105.52
UrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really nice
Actually lee they are different. VTEC uses two different cam profiles and a solenoid controls oil flow to an actutor that switches which cam lobe actuates the rocker arm (in a nutshell). This is why VTEC "kicks in", because it is like an on-off switch, you either have your low speed cam or your high speed cam, and there is a noticible difference when it happens. VCT like our cars have is a linear control, meaning that the cam can be advanced or retarded at any position within it's range, so I guess you could say it has more adjustability.
Hurst Crew Member #20
2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Old February 25th, 2009, 08:34 PM   #18
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
i just realized i need another retune if i instal my limiters...and Doug at Bamachips just washed his hands with me.......fuck.
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old February 25th, 2009, 08:35 PM   #19
leebunnyz's Avatar
LOL it was definately a joke.
Jesus Christ is #1
Old February 25th, 2009, 10:18 PM   #20
qwik48r's Avatar
alotta shit
no fat girls fast
did you and doug have a scuffle?
qwik's build
Threads Similar to: VCT Operation
3v VCT 99mustang232 2005 - 2010 5 March 13th, 2009 12:07 PM
VCT or charge motion plates? Kemp"Da_Chit"08GT 2005 - 2010 5 March 3rd, 2009 01:11 PM
Black 2v Operation Youngin The Clubhouse 6 June 26th, 2008 01:49 AM
Operation Golden Flow Squints The Clubhouse 36 June 17th, 2008 04:33 PM
operation clean the coolant system KhaosGT 99-04 0 June 14th, 2008 04:18 PM
