Line Loc w/Clutch Staging
LinkBack (1) Thread Tools
Old February 27th, 2009, 01:09 PM   1 links from elsewhere to this Post. Click to view. #1
GTPONY1's Avatar
2006 Mustang GT
539rwhp / 482rwtq
GTPONY1 will become famous soon enough
Ok, so I got my Line Loc ordered and was throwing around this idea about setup for track. My track experience has always been with automatics using transbrakes, because of consistency. I just love this car with a stick so I am trying to get the same type of setup.
2 switches, 1 to Active Line Loc (like normal use), and 1 to Override for a switch on Clutch.
So Switch 1, Line Loc works like it does normally, apply brakes, flip switch, locks front only, do burn out, flip off.
Now staging, Flip Switch 1 to arm, ease up to line using clutch to stage, apply brak, Flip Switch 2 to allow Line Loc to disengage off a custom switch on clutch. Would only disengage when clutch is all the way out.
This allow me to use the clutch to pre-load a little (clutch slippage) before launching at 3000-3500 RPM’s
Again this is just one idea I am throwing out for discussion
Concerns I have is its a lot of things going on to stage in a such a short time.
So this why I am posting to see what others with sticks are doing at the track for staging and/or using some other type setup.
Old February 27th, 2009, 01:14 PM   #2
06GTMustang89's Avatar
2006 Mustang GT 6spd
12.61@109mph
06GTMustang89 is a jewel in the rough06GTMustang89 is a jewel in the rough06GTMustang89 is a jewel in the rough06GTMustang89 is a jewel in the rough
Send a message via AIM to 06GTMustang89
all i have is a line lock and i love it...i just stage normally clutch pedal slightly depressed so its got its preload and i launch at 4K..thats way too many things to be thinking about in that short amount of time..
JLT CAI: KOOKS LT's: Comp NSR II's: 4.56's: TR6060: Steeda LCA, UCA: QA1's: Roush rear springs...see garage for more.
Old February 27th, 2009, 01:18 PM   #3
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
On my car I just have the line loc hooked up to a momentary switch on the shifter and release that and the clutch at the same time.
Old February 27th, 2009, 02:00 PM   #4
06VistaBlueGT's Avatar
2006 Mustang GT
12.76@105
06VistaBlueGT will become famous soon enough06VistaBlueGT will become famous soon enough
I have 3 switches. The first switch is for arming the linelock switch (12v switch). The second is a switch next to the arming switch that I use for burnouts (switches ground). The third switch is behind the clutch pedal that engages the linelock when the clutch is pushed all the way in (alos switches ground). So, here is my routine:
Burnout: Turn arming switch on, push brake pedal to floor, turn burnout switch on, release brake pedal, do burnout, switch burnout switch off when burnout is done.
At starting line: pre-stage car, inch up to stage beam, when stage beam comes on, push brake pedal just hard enough to stop car, push clutch to floor engaging linelock, release brake, bring revs up to about 5k and release clutch pedal on last amber.
At finish line: turn arming switch off before hitting brakes.
Seems like a lot but it's really not.
Old February 27th, 2009, 02:13 PM   #5
GTPONY1's Avatar
2006 Mustang GT
539rwhp / 482rwtq
Thanks Vista, I figured someone was doing something like this already. I know staging, it goes pretty quick so much practice would be required to get the routine down.
Old February 27th, 2009, 03:27 PM   #6
2006 Mustang GT
12.76@105
It would be much easier if I had a 2 step so i wouldn't have to look at my tach to check RPM's. I run 2 classes, footbrake and street legal. Neither allows 2 steps.
Old February 27th, 2009, 10:16 PM   #7
UrbanRedneck's Avatar
2008 Mustang GT
13.124@105.52
UrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really nice
I believe the way Vista has it htough, the brakes are released as soon as the clutch pedal is up, just to stop the car from rolling on the line.
Pre-loading the engine with clutch slippage is not really a good idea unless you want to burn up your clutch. It isn't going to have the benefit that a transbrake has, because a clutch does not multiply torque like a torque convertor. It's not so much because you are "loading" the engine, it's because the convertor is multiplying torque while you are slipping it, so when the brake is released there is a large amount of torque "built up". I guess it could help build boost in a turbo car, but bouncing off a 2-step will do that as well.
Hurst Crew Member #20
2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Old February 27th, 2009, 10:20 PM   #8
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
We could make it happen with a few relays. The hardest thing would be how you would setup the clutch especially if you have to slip it out of the hole.
TT Build in progress.......
Old February 27th, 2009, 10:30 PM   #9
GTPONY1's Avatar
2006 Mustang GT
539rwhp / 482rwtq
I think the setups are identical, maybe I explained it differently but basically the idea is arm the system with one switch and then have one to allow for a locked burnout that the clutch would not affect, then be able to switch back to a clutch type lock/release.
Either way, the idea is to automate the release.
Old February 27th, 2009, 10:31 PM   #10
GTPONY1's Avatar
2006 Mustang GT
539rwhp / 482rwtq
I believe in this case, you would just flip the main arming switch to disarm the system, thus releasing the lock altogether.
Old February 27th, 2009, 10:33 PM   #11
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
I made this setup for my fox and it can be altered slightly to do what you want to do.
Old February 27th, 2009, 10:36 PM   #12
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
I guess I would really have to be a strip only car to set all that up... I hope I never have the bug to go that direction.. It will be interesting to follow your progress tho.. good luck..
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old February 27th, 2009, 10:37 PM   #13
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Originally Posted by 2006greyGT View Post
I guess you would really have to be a strip only car to set all that up... I hope I never have the bug to go that direction.. It will be interesting to follow your progress tho.. good luck..
Its nothing but a few switches and wires. Its still drivable.
Old February 27th, 2009, 10:43 PM   #14
GTPONY1's Avatar
2006 Mustang GT
539rwhp / 482rwtq
Yep...simple wiring and can be shut off when not needed.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/112528-line-loc-w-clutch-staging.html
Line Loc w/Clutch Staging This thread Pingback March 11th, 2009 06:09 AM
Threads Similar to: Line Loc w/Clutch Staging
Brake line used for Nitrous Line 04mustang232 V6 Mustangs 12 July 21st, 2008 07:26 AM
feed line, return line? 91cobra5.0 5.0 Mustangs 2 March 10th, 2008 12:45 AM
T-Loc PyroFox79 V6 Mustangs 11 December 27th, 2007 04:41 PM
T-Loc scubasteve041186 V6 Mustangs 16 March 15th, 2007 03:05 PM
newbie 347 street fighter stroker staging mustang mikey New Members Introductions 4 February 17th, 2007 10:21 AM
