Ported Heads
Old March 1st, 2009, 04:06 PM   #1
Rench's Avatar
2006 Mustang GT
12.02@114.98
Rench is on a distinguished road
Ported Heads
How many of you guys are running ported heads with bigger valves and what kind of gains are you seeing...........
'06 Mustang GT, Bolt-ons and Cams
11.71 @ 116 My Garage
Old March 1st, 2009, 04:16 PM   #2
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
There are no N/A guys on this website running heads with bigger valves. I think 05kbcharged might have livernois stage III heads with oversized valves but he is stroked, bored, blown and i dont think he did the heads alone to know what they specifically gained him.
I saw about 30hp with livernois stage II heads.
Probably better to call livernois, JDM, or JPC, Justin has built a few n/a 3vs and will know what the specific gains were with the bigger valves.
Old March 1st, 2009, 04:18 PM   #3
Blank
unlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to behold
The bigger valves are usually for serious strokers/FI cars. Its not worth paying 800 more(stage 3 over 2) bucks if they wont make a large difference.
Old March 1st, 2009, 04:24 PM   #4
forensicsteve will become famous soon enough
Just installed Livernois stage 3 heads and 3spr cams. Car is at tuners but they are doing some other stuff before any dyno pulls...so no results yet. Car has very very limited street use. Not used for transportation anymore.
Old March 1st, 2009, 04:29 PM   #5
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
How the FRICK do you know this? Do you even know the purpose of going with larger valves? LoL
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old March 1st, 2009, 04:38 PM   #6
Mickey's Avatar
Mickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to behold
MF, what did we say about advice....if you don't know what you're talking about, don't say it
Under Construction
Old March 1st, 2009, 05:05 PM   #7
2008 Mustang GT
12.13@111.63
germansheperd is on a distinguished road
Send a message via AIM to germansheperd
Ported heads here with stock size valves. I guess depending on the combo people will see 20-30 RWHP.
N/A Automatic 3V GT-Nuff said
Can we please have George W. Bush back?
Old March 1st, 2009, 05:06 PM   #8
2008 Mustang GT
12.13@111.63
+1 not going to make much of a difference on N/A strokers either but to each his own.
Old March 1st, 2009, 05:15 PM   #9
BWAL Is My Hero
JakeM's Avatar
You don't get larger valves for performance reasons guys. Larger diameter valves with larger diameter stems take more heat and abuse. Thats why you get larger valves. Or if you are getting some crazy heads you need the larger valve to cover the larger opening. Another function of larger valves is to better atomize fuel because they hold more heat. But that is arguable.
When your looking into larger valves it should be reliablity sake. Not performance. You will not see a increase in performance from larger valves.
Old March 1st, 2009, 05:24 PM   #10
Rench's Avatar
2006 Mustang GT
12.02@114.98
I'm just thinking ahead to my winter project. Here's what I'm thinking, if I'm going to go through the trouble of swapping the heads (definitely more work than the the good old windsor motors) I may as well throw a stroker rotating assembly in while I'm at it. If I'm going to do that may as well go with the bigger valves. Shoot, while the engines out why not tack a 6060 on the back of it....Well, you get the idea. Anyway, I was curious to see if anyone sprung for the bigger valves. Rich, 30 HP is decent, I geuss that's not bad for a weekend project on these cars. Ford did a great job on these 3V's. Tough to improve on.
Old March 1st, 2009, 05:25 PM   #11
TheUNZippee!'s Avatar
The purpose of larger valves it to allow for more air flow, to get more air/fuel mixture into the combustion chamber, and to get more out because you put more in. It's for performance.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old March 1st, 2009, 05:32 PM   #12
UrbanRedneck's Avatar
2008 Mustang GT
13.124@105.52
UrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really nice
+1. While the things towelly said are correct also, larger valves allow for more airflow (given that the ehad is properly modified to accomodate them) and hence can support higher HP. But I think that the general idea is that the valves on the stock heads are large enough to flow as much air as the small engine is capable of drawing in without forced induction anyway.
Hurst Crew Member #20
2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Old March 1st, 2009, 05:34 PM   #13
Yup.
Old March 1st, 2009, 05:42 PM   #14
BWAL Is My Hero
JakeM's Avatar
Larger Valves don't make for more air flow. Large valve OPENINGS like in ported heads do. But Larger valves are just plugging the same whole with a larger valve. Am I missing something?
Old March 1st, 2009, 05:44 PM   #15
Blank
Damn Mickey, I know what I'm talking about, I've heard this stuff before, even germansheperd agreed. But yes the bigger valves take more heat, and why do you think most people who buy them have BUILT cars? Because they need the better heat resistance. Even if my info is not 100% accurate at least I'm trying to help. If everyone was scared as hell that their information was inaccurate, they wouldn't post any.
Old March 1st, 2009, 05:46 PM   #16
BWAL Is My Hero
JakeM's Avatar
Larger Valves in of themselves dont' make for any real gains in performance. Which is what you were saying.
Old March 1st, 2009, 05:47 PM   #17
Blank
Yeah I meant they don't make much difference for performance, so if performance is why people are opting for them, then they're wasting $800
Old March 1st, 2009, 05:49 PM   #18
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
you two play nice....
I am not sure why but we upped the exhaust valves by 1mm when I did my build... I trust my shop and just let them drive the build..
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old March 1st, 2009, 05:50 PM   #19
One would assume that when you go for a head with larger valves that the opening would also be larger.
Old March 1st, 2009, 05:51 PM   #20
Blank
Well the oversized valves go well with your application 2006greygt.
Threads Similar to: Ported Heads
Ported Heads RAGEman 99-04 70 March 12th, 2008 09:27 PM
where can i get my heads ported brokebp417 5.0 Mustangs 4 January 17th, 2008 02:22 PM
PI heads vs ported non pi stanglifemike 96-98 2 January 21st, 2007 02:25 AM
ported heads coreyfitz 5.0 Mustangs 0 January 9th, 2007 11:25 PM
Ported heads tlgrant 99-04 7 December 12th, 2006 02:55 AM
