NEED HELP!!! Tire Tire Pressure Sensor Fault!! On
Good evening everyone!! While I was painting my calipers I was playing the radio probably a little to long. So the battery is now out. Took my wife's car's battery and used it for my car. Engine is working fine then I see this "tire pressure sensor fault", so when I was doone with the calipers I placed the tires back, disconnected the battery to let it reset for about half hour. then tried it one more time, and still there. Help please!!!!!!!
![]() Kooks LT's with Catted X-pipe, Roush Stingers, Paxton NOVI 2200 H.O., Hurst STS, BMR Stage I Suspension Kit, FRPP Dampers, Tuned by VMP. |
by the way I had to repair one of the tires cause it was poked by a nail. On my way to fill it up.
Make sure all the tires are properly inflated. The tpms light should go out or one of your tires is letting air out just enough to signal the light
07 GT-- Gone But Not Forgotten Military Crew E-5
did you ride with the tire flat?
it sounds like you have a problem with one of the sensors or the computer is not reading one |
booooost'd
2007 Mustang
you had the sensors off the car when you were doing the calipers and you switched the power. you don't have a problem... just need to drive the car with proper air in the tires and it should reset after about 10-20 minutes worth of driving.
![]() Jucostud's Official Build Thread 1988 LX HATCH 5.0 - FOR SALE $5,000 OBO 2007 vortech gt - SOLD! Looking for next project |
I repaired and inflated the tire then went for a ride for a few and it went away thanks guys!
2008 GT
I have got that same thing every time my battery has been disconnected. I have just took it around the block and both times it fixed it.
![]() Procharged D-1SC W/3.7 Pulley, Comp "Mutha Thumprs", Mac Longtubes, O/R prochamber, Steeda CMCV Deletes, 3.73's, FRPP Stingers |
Threads Similar to: NEED HELP!!! Tire Tire Pressure Sensor Fault!! On
| Tire Pressure Sensor Light? | kevio | 2005 - 2010 | 12 | December 2nd, 2008 05:34 PM |
| Tire Pressure Monitor Fault? | DarkCandy08GT | 2005 - 2010 | 2 | June 26th, 2008 08:13 PM |
| Tire pressure gauge fault? | Whippled07 | 2005 - 2010 | 10 | May 7th, 2008 04:49 PM |
| Tire pressure | Blackblurr_00GT | Modular Mustangs | 3 | April 16th, 2007 08:17 PM |
| tire presure monitor fault | trueballerisme | V6 Mustangs | 1 | February 26th, 2007 06:47 PM |
