Knock after cam install...One problem solved and one to go...PLEASE HELP again
Old March 10th, 2009, 02:25 PM   #1
jerrytubbs1 is on a distinguished road
OK pulled the plug again and find a small knick right by the electode.Changed the plug, miss gone. Thanks for your guys help.....Now help me find the rattle I have.....
Its like on the older cars when the lifters/rockers peck.It does it louder when the car sits for awhile and right when you start it up,then it goes away.Then When you give it gas it doesnt make the sound, but when you let of and it is coming down, it does it right between 2000 and 2700 rpm.So whatcha guys thinking it could be?
Old March 10th, 2009, 02:37 PM   #2
silverstang's Avatar
2007 Mustang GT
silverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the rough
cam phaser most likely.
Bassani Crew Member #3
Old March 10th, 2009, 02:39 PM   #3
It sounds like its coming from the center of the cover at the bottom towards the header.
Old March 10th, 2009, 02:45 PM   #4
2007 Mustang GT
the noise of a cam phaser can travel throughout the engine. A normal sign of a bad phaser is if it is making the noise at idle, then when given a little throttle the noise fades away. You might have a bad follower or lifter (forgot the right word for it). Might even be an improper installed follower (not saying you screwed something up)
Old March 10th, 2009, 03:16 PM   #5
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
and then there is the awfull.....jump a tooth and had PTV contact.
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old March 10th, 2009, 03:22 PM   #6
All scribe marks were lined up when it went back together and everything was torqued down. So could it have jumped AFTER the cover went back on?
Old March 10th, 2009, 03:23 PM   #7
07 STROKER's Avatar
07 Mustang GT
did you use the chain wedge?
Old March 10th, 2009, 03:30 PM   #8
Yes, The wedge and spring compressor.
Old March 10th, 2009, 04:51 PM   #9
2005 Mustang GT
13.4@103
Avengence will become famous soon enough
Bad lash adjuster(s)?
Old March 10th, 2009, 06:33 PM   #10
Isnt there a tsb on those anyways? Could putting the new cams caused them to go bad?
Old March 10th, 2009, 06:54 PM   #11
hammeron is on a distinguished road
i also would have to go with the
phaser, as the most likely cause.
the only other remote posibility i can
come up with is, if by any chance you
didn't put every cam follower back in it's
original position, i wonder if the wear
pattern is enough to cause a ticking until
oil saturates the area
be sure to let us know what it turns out
to be.
Old March 10th, 2009, 07:52 PM   #12
rakkassan34's Avatar
2005 GT
13.5 best to date
rakkassan34 is on a distinguished road
Take the oil fill tube off the passenger side cam cover shine a light in there so you can see the cam phaser in action while it's running. The drivers side you'll just have to take the cam cover off when it's off and tug/twist/pull on the cam phaser to make sure it's tight. Look for loose cam followers and check the cam caps to make sure they're tight. My cam phaser was bad but it didn't make any noise.
Off road pro chamber, JLT II, tune by Bamachips, 4.10's, thumper cams, sunburst orange stripes
Old March 10th, 2009, 09:14 PM   #13
No noise from rivers side.Everything was tight nothing loose.
Pass side nothing loose, and everything I could see thru the oil filler cap was turning straight, no wobbles.So took that side off also and no wiggles and nothing loose.
Probably off to the ford dealer where the tech works.He said bring it up and he would look at ot up there.
What is the drivetrain warranty on these? I know with my 06gt500 it is 3/36 is it the same on the 06 gt's?
Old March 10th, 2009, 09:20 PM   #14
Anthony05GT is a jewel in the roughAnthony05GT is a jewel in the roughAnthony05GT is a jewel in the rough
I'd say either the phaser or a lash adjuster that doesn't want to stay pumped.
JDM 302 Stroker, Whipple 10 rib 12 psi, L&M, JBA, J&M, LFP, Corsa, BBR Stage II cams, Manley, MGW, McLeod RST, Metco, Steeda, Autometer, CDC, Street Scene, SOS, Tuned at JPC Racing by Kevin MacDonald
Old March 10th, 2009, 10:30 PM   #15
2005 GT
13.5 best to date
Got me stumped. I'm still trying to figure out how you cracked a spark plug. I thought I had bad luck, you got me beat.
Old March 11th, 2009, 02:36 AM   #16
Mickey's Avatar
Mickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to behold
to be.
I agree with this
Under Construction
Threads Similar to: Knock after cam install...One problem solved and one to go...PLEASE HELP again
Good size problem with my cam install....:( BakerFX4 99-04 101 February 27th, 2009 04:41 PM
Cam install problem... astras 5.0 Mustangs 22 February 17th, 2009 02:45 PM
Odometer Problem Solved -- Thanks for the Help Eagle2000GT 99-04 0 November 1st, 2008 11:45 PM
E303 Cam Install Problem 89BEAR 5.0 Mustangs 51 October 30th, 2006 07:24 PM
Problem still not solved stang786 99-04 1 April 30th, 2006 07:44 PM
