2008 Mustang GT
11.35@123
NSR Stage II comp cam install! HELP!
Im gonna install the NSR stage II cams myself! I have rebuilt the old 5.0 ( my 93 fox ) myself so Im no stranger to the mechanic side but know jack shit bout these 3v engines! Do I need special tools? Does anyone have a link to directions for the install? Any advice & help would be great, DOs and DONTs on the install. Heard I have to replace the cam bolts or something? Let me have it!!!!
All sissies going to Hell!
2008 BULLITT #3385
Killing with a smile
RICH!!!!!!!!! where are you????
2005 GT
13.5 best to date
You don't need special tools. It's really easy. There are alot of write ups on how to do it. Only word of warning from my experience is to check the three small tension pins holding the reluctor to the cam phaser. If any of those are missing or the reluctor is loose get new tension pins.
Off road pro chamber, JLT II, tune by Bamachips, 4.10's, thumper cams, sunburst orange stripes |
2007 GT
http://www.moddedmustangs.com/forums...ch-center.html
There is the write up. Yes you need to replace the phaser bolts. You could use a spring compressor and the timing chain wedge or some guys do it without, if you have two people you could do it without. beefmobile didnt use a wedge or compressor. You need a in-lb torque wrench. I think thats it. |
you'll need 2 cam phaser bolts, ft-lb torque wrench, a friend to help you out
07 GT-- Gone But Not Forgotten Military Crew E-5
tools:
-valve spring compressor -timing chain wedge
![]() Under Construction |
2006 mustang GT
good luck with the install
JLT CAI, Xcal3 tune, Steeda UDP, FRPP shorty headers, Flowmaster exhaust, Comp cams NSR StageII, FRPP 3.73 gears |
MM's resident Juice head
07 Mustang GT
i did it by myself...totaly do-able with the tools.
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
You should have the timing chain wedge and the valve spring compressor. I know some guys do it without the spring compressor, but the cam journal caps are torqued to 89 inch lbs and to get that torque figure correct you can't have any of the valves open at all. You don't want any upward pressure on the cam journal caps while torquing the bolts. The upward pressure will mess with your torque setting. Since the engine uses no cam bearings at all this torque figure is extremely important. The compressor is used to remove 3 rockers (cam followers) per side so no valves are open. I know some guys have claimed to have a big fat fuck push down on the camshaft while the other guy torques the bolts. I guess it's possible...haven't tried that before.
QTRHORSE, if you need a timing chain wedge I have them real cheap (new tools) Just PM me. I don't have compressors for sale.
JDM 302 Stroker, Whipple 10 rib 12 psi, L&M, JBA, J&M, LFP, Corsa, BBR Stage II cams, Manley, MGW, McLeod RST, Metco, Steeda, Autometer, CDC, Street Scene, SOS, Tuned at JPC Racing by Kevin MacDonald |
07 Mustang GT
awsome point on that torques spec being off cause of spring pressure....never though to that but sounds correct. i removed the followers.
They wouldn't have you take them off in the repair manual if it didn't matter. I could see if the bolts were torqued to 50 ft lbs or something, but 89 inch lbs is very light.
07 Mustang GT
its like 7 ish foot pounds
Threads Similar to: NSR Stage II comp cam install! HELP!
| Cam installation - Comp cam stage II | Dolbs4082 | 99-04 | 4 | February 28th, 2009 11:36 PM |
| Comp cam - hi tech stage 2? | Dolbs4082 | 99-04 | 42 | February 19th, 2009 12:56 AM |
| Help--- Nsr Cam Install | beefmobile | 2005 - 2010 | 168 | December 14th, 2008 03:26 AM |
| BBR Stage 2, FRPP Hot Rod, Comp Stage 4 or Comp Thumper Cams | ivan48humble | 2005 - 2010 | 179 | December 8th, 2008 03:19 AM |
