Blank
Dyno Condition Confusion
I know SAE usually reads higher, but I've heard STD reads higher in certain conditions. On a 302rwhp STD CF dyno run, with conditions being 100 degrees fahrenheit, 17% humidity, and 29.44 in-Hg(posting in case it matters), what would the numbers be in SAE form?
Made in U.S.A.
2011 F150 FX4
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 8 reviews
No, STD reads higher.
Blank
I'm asking though, in those conditions what would SAE read. I just thought that in certain air temp/humidity, SAE would read higher
Made in U.S.A.
2011 F150 FX4
![]() JLT CAI: KOOKS LT's: Comp NSR II's: 4.56's: TR6060: Steeda LCA, UCA: QA1's: Roush rear springs...see garage for more. |
dude who puts this information in your head
![]() Under Construction |
Blank
Me or Nasty? D:
you...since when do sae corrected dyno's read higher than std corrected dyno's...
agreed SAE will always be the lowest compared to STD...
Blank
I never SAID they do, I was asking if in the specific conditions of that dyno run would they. I don't know much about correction factors, so this is why I asked.
i know im just messing with you man
Blank
Oh ok, I have trouble pointing out ball busting in a thread where I'm asking a important question. On that specific dynosheet, the power drops off right before 6500 RPM's, which is the rev limiter
I believe it goes higher due to the unit of measure... I could be totally wrong but I think I know that from somewhere
![]() 2.6l KENNE BELL 298 Stroker, Ported heads Pro Motion Built 3650/McLeod RST/ MGW Short Throw Long tube/O/R X /Borla Touring 8 rib/65 lb injectors/GT500 twin fuel ET Drag Slicks/3.73 gear Detroit Truetrac /CDC AGR Spoiler |
Blank
SAE adds in barometric pressure, humidity, and 100 degrees. I think if anything, the 100 degrees would lower the numbers.
Threads Similar to: Dyno Condition Confusion
| Supercharger Confusion! | thatonekidw/theGT | General Tech | 22 | August 17th, 2008 08:56 PM |
| id confusion | 06HellFireGT | 2005 - 2010 | 11 | August 5th, 2008 09:47 PM |
| V6 confusion | MSO | V6 Mustangs | 15 | June 12th, 2007 08:41 PM |
| 2.3 and 5.0 Confusion | Ga_50_foxbody | 2.3 Mustangs | 39 | June 1st, 2007 11:23 PM |
| 4:10 Confusion | Rusty | 2005 - 2010 | 5 | April 21st, 2007 08:21 PM |
