Kenny Bell Guys Help..
Old April 14th, 2009, 07:41 AM   #1
05gtdroptop's Avatar
05 Mustang Convertable GT
05gtdroptop is on a distinguished road
I am installing a KB 2.6 w/intercooler. I can't find in the install manual where the other end of this vaccum hose connects. It is the one on the passenger side front lower plenum. The manual says to run it behind the intake to where the Driver side rear of fual rail. Please help and thank you.
White With Black Lemans stripes
Staggered 20" Foose Nitros
FRPP HOT ROD Cams
Injected Engineering Custom DYNO TUNE
C&L Race Intake and SCT Tuner
Mac axle backs
Eleanor fog light converson
Lakewood Pan hard bar and Brace
FRPP lowering springs
Old April 15th, 2009, 07:44 AM   #2
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
Eats Chevys, Shits Imports...
Grabber523 has a spectacular aura aboutGrabber523 has a spectacular aura aboutGrabber523 has a spectacular aura about
Yeah you're talking about the vacuum source tube that comes off the passenger side of the intercooler...that goes around the back of the blower to the driver's side of the blower and just hangs out there until you start connecting all your vacuum accessories and bypass valve.
http://www.moddedmustangs.com/forums...p-vote-me.html
TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER)
MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER
TRUNK MONKEY CREW FOUNDER
Old April 15th, 2009, 12:51 PM   #3
yep but this sorry kit has 3 extra vaccum lins in the kit and it never shows where to attach this one. any help?
FRPP HOT ROD Cams
Mac axle backs
Old April 15th, 2009, 12:59 PM   #4
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
After you get all your vacuum lines teed together, that one plugs into a tee and is your main vacuum source for your small hoses. It doesn't really matter how everything's hooked up, as long as everything with the same diameter vacuum line plugs into that one. Does that help? That's your main vacuum line that controls your fuel pressure off the regulator, your bypass valve, the boost-a-pump switch...those are the ones I can think of off the top of my head. You just tee all those lines together and plug them into that one main hose that you're asking about.
p.s. The kit KB supplies is FAR from sorry, and you do have to have a slight amount of knowledge to throw it on. I'm pretty certain that it does, in fact, show you how to hook those hoses up. I'll hafta dust off my manual at home to check.
Old April 16th, 2009, 10:07 PM   #5
hellbred07 is on a distinguished road
Most definately a killer lurking.The manual shows you where everything connects unless you're missing a page.Also be sure to go over those manifold bolts a couple times to help the gaskets to seat properly, at least 4 times that way you won't have a vac leak cause then the blower will have to come back of.
Old April 16th, 2009, 10:27 PM   #6
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
I didn't even attempt to install mine myself... I know my limitations... you will love it when it is all said and done... another KB'ed vert... welcome to fast as hell !!!
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old April 16th, 2009, 10:39 PM   #7
mustang_gtr_99's Avatar
1999 3V GT/2007 GT D/D
corner carver
mustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the rough
Instaling the KB is almost as good as sex, I cant believe you paid somone to enjoy your $$$ experiance, lol, I was a little nervous at first but I had helped a few friends with there diferent SC kits and it turned out to be simple and a blast when it all fires up congrats on the KB and welcome to the club
OS2 (SW) USN
REAR SEAT DELETE FABRICATOR
"RSD pics in garage"
99 3V GT/2007 GT DD
Threads Similar to: Kenny Bell Guys Help..
Kenny Brown suspension americanmuscle90 5.0 Mustangs 0 September 24th, 2008 10:49 AM
PI kenny bell on NPI motor... DrHolliday 96-98 8 July 20th, 2008 08:23 AM
KENNY GT_n_ 4POINT6 330CubeGt Pictures 25 January 4th, 2008 01:57 AM
Kenny Vs. Spenny Tony_90fox The Clubhouse 16 December 9th, 2007 09:15 PM
not so fast,kenny WAVEBYE Videos 2 April 20th, 2007 03:54 PM
