2008 Mustang GT
13.124@105.52
Longtubes are on
Well yesterday I finally got time to get my X pipe on, so my Mac LTs/offroad X are now on. Haven't had a chance to put the Stingers on yet, I'll do that on saturday after I work out a coupld bugs.
Don't have time right now to go into my observations from the install, I'll do that later. But holy shit it made a big difference in sound. I didn't know what to expect, but the first, most obvious thing is it is a LOT quieter. Is it normal for headers to make the car quieter? But it sounds a lot meaner, takes 85% of the gayness of the violators away actually, because it is a lot deeper, and the retarded farting/popping/gurgling that it used to make on decel is all gone now. Crusing on the highway it is a lot quieter when you aren't on the gas. I did not expect it to be quieter, maybe that's because it smoothed it out and took away the farting or something. My other observation is that the car seems to have lost some low end power (which was expected) but deffinitely feels stronger above 3500. The 4.10s should remedy that nicely though. Can't wait to put the stingers on though and see how it sounds. Exhaust smells a little less potent now, I hope it isn't lean. I think the PCM would pick up on that quick though. BUT I am having a bit of trouble confirming that it is leak free. It almost sounds like I have a header leak at the head, but I can't tell because it kinda sounds like you can hear the exhaust through the pipe, and the engine itself is kinda loud. Saturday after work I'll get under it and get a better listen with a stethescope, or maybe use the smoke machine at work to see if there are any leaks. But I cannot remember for the life of me if the engine has always been this loud, almost like either the injectors or the valvetrain is fairly loud. Do these cars usually have fairly loud engines (not exhaust, the engine itself)? My final observation is that the Mac headers are pretty damn nice. I didn't have any of the problems that others mentioned (header hitting starter, vibration in steering collum, etc.) they look nice and clear everything fine. The Brenspeed X pipe was a BITCH to line up though, and I still may cut the hangers off it and tweek it some more, but it's pretty close to perfect. All in all I'd reccomend these headers to anyone looking for longtubes. Once I get some bugs worked out (making sure there are no leaks, have to re-center the steering wheel because it is a cunt-hair off from loosening the steering shaft and rack bolts, and putting the stingers on) I'll take videos and pictures and give a better description of the install. Maybe get it dynoed in a few weeks see if I'm over 300 rwhp now. Ok, that is all.
Hurst Crew Member #20 2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
2008 Mustang GT
Congrats on the install, did you end up putting them on at home after all?
It's funny you mention how quiet the car is now. I was curious about that last week so had my wife drive the car to the next town over (she drives it pretty damn well...) and I (tried to) followed in her car. Frankly I was pretty surprised how quiet my Mustang was from immediately behind or next to it. Granted I have zero exhaust mods, but my car sounds pretty loud inside, but not at all from outside. It's obvious Ford did that to satisfy the driver without satisfying other drivers on the road. ![]() Do the OEM headers have thinner walls than the aftermarket ones?
Experience is what you get when you didn't get what you wanted.
2008 Mustang GT
13.124@105.52
Yes I did do them at home. Turns out that after I move a bunch of shovels, a shipping pallet, and the snow blower I have a decent amount of room.
From the factory it uses cast iron exhaust manifolds, so they are obviously thicker walled than the headers.
a little tinking noise is common with longtubes.. think about how thick the cast irons are.. they absorb most sound.. the steel isnt thick at all so the individual exhaust pulse can be heard as the leave the exhaust port.
2008 Mustang GT
13.124@105.52
I figured as much, that is what I think I am hearing, because it doesn't sound like a leak so much, and you don't hear it in the car or with the hood closed, just if you crouch down near the wheel or stick your head under the hood. It seems like it makes noises in any area where the exhaust makes sharp turns, like in the headers and where the two pipes combine in the X. The smoke machine will confirm though. I noticed a random clunk over certain bumps too that I believe to be those useless hangers on the X pipe that my car doesnt use. Cutoff wheel will fix those this weekend.
#6 | |
If you have some free time next week and don't mind some driving, hows about helping a brother out installing the same headers? Mine are coming Monday and I already have the car up on stands and almost ready to go. I'm 100 miles west of Chicago, BTW. |
#7 | |
May 08 ROTM
2008 Audi S6
As for your Leak possibility, I think your okay - but if you want to use a 50/50 mix of soap and water, while the car is still cold, spray down the area around both header flanges/gaskets then start the car, if you see bubbles, you got a leak. Gotta move sort of quick, because once the head starts making any heat, the soapy water evaporates quickly. |
i feel the same way. My car seems so much more quiet than befor when i had the stock headers. Like there isnt that raspyness to it anymore. I have bbk longtubes with o/r x and borla stingers. Its so much deeper now.
Just a bottle and some mufflers )))18yrs old S.FL
looking forward to hearing the longtube/or x/stinger combo. i was thinking of selling my MAC's to buy a set of stingers but want to hear what it sounds like before then. my car was a lot quieter at idle after my ARH's went on but boy did it wake everyone up when i stepped on the gas haha
![]() 420rwhp/523rwtq on nitrous 11.45 @ 116mph, 1.55 60', rt- .001 with m/h dr's (4/3/09) http://videos.streetfire.net/video/F...409_644720.htm ARH Longtubes w/offroad x pipe for sale in classifieds. |
2007 GT
Congrats
2007 Mustang GT
Congrats on the install, I knew you would, "Get er done". I guess I have had my MACs on for about 4 weeks and It feels like it needs a custom tune. I switched off the rear O2s and have no check engine light but I feel a slight surge taking off when it is cold. I sure did gain a shit load of top end and it sounds awesome.
Saleen rear fascia with center exhaust, MAC longtubes with o/r Prochamber, Steeda CAI w/carbon fiber elbow, SCT X3, Steeda UDPs, Hurst shifter, modified delete plates, Comp Cams and 4.10s.
#12 | ||||
2008 Mustang GT
13.124@105.52
I have never thought of using soap to look for an exhaust leak, I've always done that for tires though. I am pretty sure it is not leaking, I used the Kooks gaskets that Brenspeed sent with the headers, and I think I am just hearing what qwik mentioned. Tomorrow I am going into work early and one of the other techs and I are going to look at it (it helps to have one guy hold rags over the tailpipes to amplify any leaks), and if I am in doubt at all I can use the smoke machine (made for evap leaks, but works great for exhaust and vacuum leaks too) to test for sure. Once I am positive that I have no leaks, on go the stingers. One thing I was wondering though. You live right by my brother (he sees you driving all the time, lives in algonquin). Would it be possible one day for me to see your car in person and hear it, just because you're the only person I know nearby (well, you and heavygt) with a 3V with aftermarket exhaust, I'd just like to hear what the header noise sounds like and if your engine is as loud as mine (though the procharger might make that impossible haha).
Threads Similar to: Longtubes are on
| Longtubes!!! | RednWhiteFight | 99-04 | 21 | January 17th, 2009 02:08 PM |
| longtubes | moosenuk17 | 99-04 | 6 | October 8th, 2008 01:59 PM |
| LongTubes | Toph6888 | V6 Mustangs | 9 | April 2nd, 2008 02:59 PM |
| Longtubes | coltonrobertson | V6 Mustangs | 9 | November 14th, 2007 01:11 AM |
| Longtubes or no? | 1-over-z | General Tech | 3 | February 8th, 2007 06:00 PM |
