Fuel Pump Problem!!! Please Help!!
Old April 25th, 2009, 09:46 AM   #1
2008 Mustang GT Premium
13.30@101.67
Mr.Stang08 will become famous soon enoughMr.Stang08 will become famous soon enough
Send a message via AIM to Mr.Stang08
Hey guys watsup! I just finished installing my NOVI 2200 but after upgrading the fuel pump I could't close the metal ring to close it shut. I've tried everything. How do you close the damn thing? And to top it off Paxton sent me the wrong MAFia. This really sucks I was looking forward to try it today!
Paxton/Vortech Crew Founder #1
Kooks LT's with Catted X-pipe, Roush Stingers, Paxton NOVI 2200 H.O., Hurst STS, BMR Stage I Suspension Kit, FRPP Dampers, Tuned by VMP.
Old April 25th, 2009, 10:32 AM   #2
2005 Mustang GT
11.88 @ 118
TimboStang is on a distinguished road
Is the fuel pump assembly sitting down in the hole properly? Are you just having problems getting the ring to turn and lock? If so, try a little light oil on the ring and o-ring so it will turn easier. You also need to tap it on one side and then the other so it stays straight.
Turbonetics single 60mm
Old April 25th, 2009, 11:21 AM   #3
13.30@101.67
Yes it is sitting properly. I know it has to spring up and down freely, I'm I correct? Thanks for the oil tip though.
Old April 25th, 2009, 11:52 AM   #4
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
There's really no trick to it, Timbo gave you about all of the advise you need. It does take a little massaging to get it to turn closed evenly. Alternating sides like timbo said tapping on the tabs to close is all you can do.
FLICKR Unique Imagery
Old April 25th, 2009, 12:30 PM   #5
13.30@101.67
Thanks Emay
Old April 25th, 2009, 01:01 PM   #6
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
if you have a third hand there...get him to push down on the pump, it will compress the rubber gasket a little more and get the ring started a little eaiser for you. I was by myself so i had to do th back and forth trick as well.
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old April 25th, 2009, 07:39 PM   #7
UrbanRedneck's Avatar
2008 Mustang GT
13.124@105.52
UrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really nice
I haven't looked at the fuel pump retainer on these cars, is it a metal ring with multiple tabs that lock into ridges in the tank? If so, like others said you have to just get it centered and alternately tap on it untill every tab is started. BUT if it is the design I am mentioning, only tap on it with a BRASS or PLASTIC hammer and drift. Sparks on fuel tank = boom boom.
Hurst Crew Member #20
2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Old April 25th, 2009, 07:58 PM   #8
07 STROKER's Avatar
07 Mustang GT
i used an aluminum drift
Old April 25th, 2009, 07:59 PM   #9
2008 Mustang GT
13.124@105.52
yeah I reckon that'd work too. Don't see aluminum drifts too often. Just don't use steel.
Old April 25th, 2009, 09:28 PM   #10
07 STROKER's Avatar
07 Mustang GT
i made it myself LOL
Old April 25th, 2009, 10:10 PM   #11
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
I have a couple brass drifts....
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old April 26th, 2009, 01:25 PM   #12
Anthony05GT is a jewel in the roughAnthony05GT is a jewel in the roughAnthony05GT is a jewel in the rough
I had to use a hammer and a brass drift to button mine up.
JDM 302 Stroker, Whipple 10 rib 12 psi, L&M, JBA, J&M, LFP, Corsa, BBR Stage II cams, Manley, MGW, McLeod RST, Metco, Steeda, Autometer, CDC, Street Scene, SOS, Tuned at JPC Racing by Kevin MacDonald
Old April 26th, 2009, 03:13 PM   #13
07 STROKER's Avatar
07 Mustang GT
well....did you get it on?
Old April 26th, 2009, 03:25 PM   #14
BWAL Is My Hero
JakeM's Avatar
Ahem.... Thats what she said.
Old April 26th, 2009, 04:44 PM   #15
07 STROKER's Avatar
07 Mustang GT
oy vay!
Old April 26th, 2009, 05:12 PM   #16
13.30@101.67
hey guys I was able to install the ring and it is funny cause I did it with a big screw driver and worked. I guess I'm in this world for a reason lol but it worked and I'm still alive. Anyway, I just realised that I prtobably made the wrong connection! tell me if I'm wrong: black with black then red and red; or, black and black then red and red with black stripe. I did the first one! Did I do it correctly?
Old April 26th, 2009, 05:14 PM   #17
07 STROKER's Avatar
07 Mustang GT
huh?
you mean the connector for the fuel sender wires?
Old April 26th, 2009, 05:18 PM   #18
13.30@101.67
It sucks cause I noticed the picture in the book shows the red connected to the red with black strip. But if I have to do it again, oh well shit happens. But I wonder if I can place another connection clip on the other wire then leave the first red one with the connection clip on and hanging. Is it safe?
Old April 26th, 2009, 05:21 PM   #19
07 STROKER's Avatar
07 Mustang GT
uhhhh....are you talking about the fuel sender wires?
Old April 26th, 2009, 05:25 PM   #20
13.30@101.67
huh?
Yep!
Threads Similar to: Fuel Pump Problem!!! Please Help!!
99 Mustang fuel pump problem? stephen V6 Mustangs 18 September 3rd, 2010 07:57 PM
***Need Help*** Fuel pump problem?!?!? Mluna08 99-04 24 March 6th, 2009 11:22 AM
Fuel Pump Wiring Problem Black Five 0h 5.0 Mustangs 3 December 25th, 2007 12:32 AM
Fuel Pump Problem? chaosstangman 5.0 Mustangs 3 December 19th, 2007 11:39 AM
Fuel Pump Problem RyanGT 99-04 2 November 11th, 2007 03:18 PM
