Mac Lt's - Page 2
Old November 21st, 2009, 07:00 PM   #21
The Mustang Shop
Marc S's Avatar
2008 Mustang GT
Marc S will become famous soon enough
I installed Mac L/T and the O/R Prochamber last month. The stock studs have to be removed. The kit comes with new non-locking bolts, I used them and they have not come loose. You can re-use the stock gaskets. The extension are for the front sensors. If you do not shut off the rear sensors you will get a code. However, this code will not make it run poor. You do not need a tune for the headers if your tune is not lean to begin with. I checked my air fuel ratio before and after the install. Before it was 12.6%, after it was 13.4%. I did fatten the tune up a little and it picked up a couple more HP.
08 3650-Procharger D1SC-GT500 pumps w/BAP-80lb-BA5000-C&L intake-Mac L/T-mid mount Flowmaster-127550 cams-Lockouts-Aluminum flywheel-Ram HD-Hurst-Shaftmasters-3.31-K springs-D Specs
10.90 @ 132 pump gas tune
9.98 @ 141 race gas tune
Old November 21st, 2009, 08:27 PM   #22
hamish's Avatar
2006 gt
hamish is on a distinguished road
Originally Posted by 06HellFireGT View Post
those who have or had the mac LTs did you use the locking header bolts or reuse the stock studs and are the O2 extenstions for the front O2 sensors or the rear ?
Used locking bolts.
Just cut and soldered the original wires for the front sensors.
get some ratchet wrenches for the bolts, helps on the nasty ones.
Saleen Supershaker
Old November 23rd, 2009, 12:05 AM   #23
UrbanRedneck's Avatar
2008 Mustang GT
13.124@105.52
UrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really nice
Can't use the studs. I just used the bolts that came with the headers. I retightened them after a couple days, then after a couple weeks. No problems. The extensions are for the front sensors. The rear sensors reach if you just reroute the harness.
also is the tune for long tubes needed just to turn the rear O2 sensors off or will the car run like crap without a tune ?
No tune needed.
Hurst Crew Member #20
2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Threads Similar to: Mac Lt's
MAC LT's, O/R Prochamber, and MAC Cat-back. (Exhaust clip) RAGEman 99-04 19 April 15th, 2008 12:21 AM
Mac LT's? KenDogg 2005 - 2010 39 January 1st, 2008 06:31 PM
MAC LT'S leebunnyz 2005 - 2010 13 July 24th, 2007 03:00 PM
Mac LT's+Prochamber+???? 02gt317 99-04 8 July 11th, 2007 08:38 AM
