Building a modular street beast... - Page 7
LinkBack (1) Thread Tools
Old May 5th, 2009, 04:25 PM   #121
AnimalCrackers's Avatar
2007 Mustang GT
12.6@110
AnimalCrackers is a name known to allAnimalCrackers is a name known to allAnimalCrackers is a name known to allAnimalCrackers is a name known to allAnimalCrackers is a name known to allAnimalCrackers is a name known to all
Originally Posted by forensicsteve View Post
No issues with the intake. Dynopulls have indicated that we're losing boost into the atmosphere. Not an intake, tuning, turbo issue. So pulled motor last week and inspecting. Could be something as simple as valvesprings?????
We should communicate regarding the JPC and I would be happy to share any and all results, issues, solutions regarding same. Right now, our short term goal is to go mid 9s with as little hp as necessary. Going to keep boost at about 20-23lbs and the emphasis is on weight reduction.
you keepin Lance away from the cheeseburgers then?
Have you all made any decisions if you're going to shoot for building towards a specific race class?
Professor Crackers
Old May 5th, 2009, 07:56 PM   #122
forensicsteve's Avatar
10.0@136 mph 1/4
forensicsteve will become famous soon enough
Will PM response. It's too significant a thread, to start talking about our car, unless CK choses to. Not a thread to be hijacked
2006 mustang GT, 10.0 at 136 mph, 1/4 with old build. New build in progress for low 9s. (sold)
srt10 coupe (stock) for street, 505 ci, previousy viper gts, before that C5Z06.
Old May 5th, 2009, 09:33 PM   #123
Chevykiller's Avatar
05 Roush GT
Chevykiller will become famous soon enoughChevykiller will become famous soon enough
What blowoff do you have on the car and what size? With your set-up, I'd like to see you with the big procharger valve on there. What size is your wastegate as well? You are still air cooled, correct?
It could be a spring too. Did you ever have your heads tested? If you did, the bind rate will speak volumes. If you are binding under 40 thousands, then that could be it right there. When I checked my Livernois R heads, that was the one thing I wasn't happy with (bind at .0039) and am swapping the srpings and retainers for something a little stronger but looser.
Let me know if you want to talk weight. I've been through the ringer and have all the info. I dropped almost 500 lbs off the car now and when I start next season, the car will weigh in at 3200 lbs w/o driver. Obviously, fiberglass panels and a front clip are the big ones, but I was amazed at the weight savings of a flaming river pinto rack and lightweight brakes. I shaved almost 180 lbs right there. If you have a 9" - you also want to gun drill your axles.
05 Sonic Blue Roush RGR/JPC Built Monster
Old May 6th, 2009, 08:14 AM   #124
10.0@136 mph 1/4
Thanks for your interest and questions. I have passed on your post to our team members for review.
Old May 6th, 2009, 11:43 PM   #125
4.6L Coupe' 5spd
2002 BLK GT will become famous soon enough
Send a message via AIM to 2002 BLK GT
1,200 wow......
Old May 7th, 2009, 11:53 AM   #126
10.0@136 mph 1/4
CK
Just been informed that the intake valves on the heads were leaking badly. Being sent back today.
Old May 8th, 2009, 08:13 PM   #127
05 Roush GT
Good news (not the leaking valves) LOL - just that it is all is was and the problem was found. Good job. New valves easy to swap and good to go. You should check your bind rate and spring pressure while you have the head off IMO.
Old May 8th, 2009, 10:43 PM   #128
10.0@136 mph 1/4
Thanks. Recommendation passed on
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/121270-building-modular-street-beast.html
Need Help!!!!!!! This thread Pingback May 8th, 2009 12:32 AM
Threads Similar to: Building a modular street beast...
pics from memorial day MEAN 16, TRUE STREET, AND KING OF THE STREET RACE 56K KILLER injected03stang Pictures 12 January 16th, 2012 08:56 PM
Building an 1/8 mile beast? DarkCandy08GT 2005 - 2010 12 November 25th, 2008 11:28 PM
New beast here, A handsome Beast i might add 562cobra New Members Introductions 13 June 2nd, 2008 09:19 PM
New to this beast theninja 5.0 Mustangs 25 October 18th, 2007 08:00 PM
Whiteboy's 8 second street driven 280z street king Mellon Videos 3 December 27th, 2006 09:15 PM
