installed cams, need help
Old May 2nd, 2009, 09:34 PM   #1
pear0119's Avatar
2005 Mustang GT
13.50@105
pear0119 will become famous soon enough
Alrighty then, I just finished installing a set of FRPP cams, and the install went great maybe to well. Anywho, I went to start it after double checking everything was connected and well it won't start .
It tries to start but stumbles and it only seems to be firing on a few cylinders. At first I thought it was the coil on plugs but I took them all out again and reseated them, same thing. I do have an aftermarket canned tune from my tuner in the car, should I return the tune back to stock??
Is there anything else that you guys can think of for me to check?
JLT CAI, FRPP 4.10s, FRPP Hot Rods, FRPP x-pipe, FRPP TB, CMCV, UDP, Spydershaft, JBA Shorties, Flowmasters, Hurst Billet Plus, AM/Bama 93 race, BMR STB, BMR adj. panhard bar+brace, BMR LCA's, BMR UCA+mount, BMR front+rear swaybar, BMR A-arm brace.
Old May 2nd, 2009, 09:38 PM   #2
UrbanRedneck's Avatar
2008 Mustang GT
13.124@105.52
UrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really nice
At the front of each valve cover there is a small black square on a mounting bracket that is part of the ignition system, did you properly reconnect and mount them? Make sure everything is connected and mounted properly. Any fuel injectors that may be unplugged, etc.? Is the check engine light on? Use your tuner and see if you get any tunes. And, are you SURE the timing is correct?
Hurst Crew Member #20
2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Old May 2nd, 2009, 09:44 PM   #3
pear0119's Avatar
2005 Mustang GT
13.50@105
I don't think its the fuel injectors as I can smell unburnt fuel coming out the tailpipe. I am not getting any check engine lights. I will recheck all connectors and see if I can see anything. The only thing im not sure about is the coil on plugs as when I was putting then in there was no click or anything.
As for the timing i'm not sure about that, I was thinking of returning it back to stock and see if that helps.
Old May 2nd, 2009, 10:12 PM   #4
2008 Mustang GT
13.124@105.52
with the valve timing off though it would most likely backfire a lot when running, or not run at all. You may be right to suspect an igniton issue. I don't think you will feel a click though when the coils are seated.
Are the camshaft position sensors installed correctly?
Old May 2nd, 2009, 10:31 PM   #5
pear0119's Avatar
2005 Mustang GT
13.50@105
I believe they are. But I did find that I forgot to connect, well its a big connector right beside the ECU that has 4 leads going into it. Connect and still nothing not even firing. I think its flooded now as I have been trying a lot, so I will wait until morning and try it again. Finger crossed.
Old May 2nd, 2009, 11:13 PM   #6
88 GT
RainsFather is on a distinguished road
I just finished doing mine. The cops won't make any noise going back on. One thing I had a problem with as getting the damn rockers to stay in place. I would assume that if any of them slipped down far enough that nothing would touch it and would cause it to not want to start. Also, what did you use to keep the chain from slipping? The last thing would be to check and make sure you put them on the right side, I know this sounds stupid but one of the guides I read online had it wrong.
1988 Black Mustang GT - CAI, headers, throttle body, 3.73 gear, and a lot of hope.
2007 Silver Mustang GT - R.I.P.
"we don't talk about the that car, he still gets really upset" - my wife
Old May 2nd, 2009, 11:43 PM   #7
pear0119's Avatar
2005 Mustang GT
13.50@105
yeah I had a hard time keeping the followers in place. One falls out so you go and put it back in and you hit the one beside and it falls out.
As for the chain, I tied a few zip ties around the phaser and tied a rope to the ceiling of the garage, And I also had my dad hold the sprocket and chain up while I removed and place the new cam.
I also just realized that I decide to roll the engine with all coils unplugged just to see if any weird noises were going to appear, so I think that flooded the engine as I did roll it for a while.
Old May 3rd, 2009, 12:13 AM   #8
2008 Mustang GT
13.124@105.52
hold the gas to the floor when cranking, it will disable fuel injection to "clear flood".
Old May 3rd, 2009, 10:59 AM   #9
Anthony05GT is a jewel in the roughAnthony05GT is a jewel in the roughAnthony05GT is a jewel in the rough
^^ Yes, this should help if a flooded condition exists.
JDM 302 Stroker, Whipple 10 rib 12 psi, L&M, JBA, J&M, LFP, Corsa, BBR Stage II cams, Manley, MGW, McLeod RST, Metco, Steeda, Autometer, CDC, Street Scene, SOS, Tuned at JPC Racing by Kevin MacDonald
Old May 3rd, 2009, 11:33 AM   #10
pear0119's Avatar
2005 Mustang GT
13.50@105
well, went out this morning and it started right up . So it seems to be a combination of the electrical connector that I forgot to connect and it was flooded.
Took it for a spin and it satisfied the butt dyno, next step is to get her dyno tuned at some point this week. Other then the pulsing idle everything seems to be OK, which the dyno tune should fix the idle.
Old May 3rd, 2009, 12:52 PM   #11
Yeah, when I did my cams Kevin spent a lot of time getting the idle shit right.
Old May 3rd, 2009, 02:21 PM   #12
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
change your oil if you left it flooded overnight...guess where the fuel went?
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old May 3rd, 2009, 02:29 PM   #13
pear0119's Avatar
2005 Mustang GT
13.50@105
Yeah, my tuner has done a few of the FRPP cam tunes on the dyno so I think i'm gonna be OK there. Its just trying to find time to bring it there.
There is fuel in the oil and I do plan to change it. would 5w30 synthetic be OK to put in these motors? as I have a few cases of 5w30 Castrol Syntec, that I bought when it was like $25 for 6 quarts plus k&n oil filter.
Old May 3rd, 2009, 02:30 PM   #14
07 STROKER's Avatar
07 Mustang GT
i wouldint, but thats me 5 20 only for me.
Old May 3rd, 2009, 03:30 PM   #15
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
Eats Chevys, Shits Imports...
Grabber523 has a spectacular aura aboutGrabber523 has a spectacular aura aboutGrabber523 has a spectacular aura about
+1 with the cam phasers being oil-pressure dependent and the tolerances in our engines, you'd sleep better at night knowing you had the right weight oil.
http://www.moddedmustangs.com/forums...p-vote-me.html
TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER)
MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER
TRUNK MONKEY CREW FOUNDER
Old May 3rd, 2009, 08:13 PM   #16
joeice14's Avatar
2006 Mustang GT
joeice14 will become famous soon enough
Send a message via AIM to joeice14
Hmm I am thinking of startin my install tonight... Remove everything, intake pelum, valve covers and make some room around too work... Send stuff out to get powdercoated tomorrow and then get started... I just need to pick up a torque wrench... Cant find mine... I need a inches to pounds one correct???
Mods: Some Intake Shit...
Old May 3rd, 2009, 08:35 PM   #17
Yeah, you need a 3/8'' drive inch/pound torque wrench.
Old May 3rd, 2009, 08:47 PM   #18
usafimj's Avatar
2007 Ford Mustang GT
12.847 @ 114.12mph
usafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of light
Send a message via Yahoo to usafimj
joeice you don't need to take the intake off. it does not interfere with the install
07 GT-- Gone But Not Forgotten
Military Crew
E-5
Old May 3rd, 2009, 08:52 PM   #19
joeice14's Avatar
2006 Mustang GT
Thanks Anthony I need to pick that up for sure..
Sorry ment to say I am doing my delete plates at the same time... Sorry man..
I also read about people doing it without a valve spring compressor... I could probably get my hands on one just wondering though... I am going to either make my own wedge out of wood, hose or something... Any ideas..
Not sure I will be able to tie to the ceiling lol... Nice idea though...
-Joe
Old May 3rd, 2009, 09:05 PM   #20
pear0119's Avatar
2005 Mustang GT
13.50@105
I just used zip ties and rope to tie the phaser and to the garage door opener bracket on the ceiling. But what I found to be best is to get someone to hold the phaser and sprocket up as you remove the old cam and place in the new cam. I also tried a bock of wood but couldn't find anything narrow enough to fit down and also I didn't want any wood chips/shavings to fall down in the motor.
I also didn't used a spring compressor either just got the cam in a sweet spot just enough to get the caps back on and then tighten them in sequence. Just be careful that the followers don't fall out of place.
Threads Similar to: installed cams, need help
new cams installed need break in? 90Stang 2005 - 2010 9 November 10th, 2008 01:40 AM
Frpp cams installed mustanglouie 2005 - 2010 10 August 31st, 2008 03:19 PM
Vid of heads and cams installed ZoomZoomMFer Videos 26 June 15th, 2008 04:40 AM
What Cams And How Much Money To Have Installed BYEBYE2U 99-04 25 April 1st, 2008 11:18 PM
How much $$$ to have cams installed in my car and tuned? silverstang05 2005 - 2010 4 January 12th, 2008 11:37 AM
