2005 Mustang V6
Tremec 3650
What is the difffrence between the 2004 Tremec 3650 and the 2005 Tremec 3650?
2006 Mustang GT
12.76@105
I believe there are some internal differences along with the 2004 being a top loader and the 05+ being remote shifted.
MM Bracket Racing Crew Member #1 TH350, B&M Ratchet Shifter, 4000RPM Stall, JLT2, O/R X, Cherry Bombs, 4.56's, line locks, Prothane Engine Mounts, BMR LCA's, Lakewood UCA, BMR rad support with Sway delete, CHE K-member brace |
2005 Mustang V6
Can a top loader be converted to a remote shifter or will I need a whole new transmission. Im planning a swap of a 2004 Mach1 drivetrain in to my 2005 Mustang v6 and want to know if this will be a issue.
the casing for hte TR3650 for the 2005+ is completely different from the 99-04' models. The 04' tranny will not be able to convert into your S197. Its because its a top loader and ours is a remote the output shaft portion of the tranny is completely different and would require a custom fabbed shifter to make it work costing you more money...
![]() JLT CAI: KOOKS LT's: Comp NSR II's: 4.56's: TR6060: Steeda LCA, UCA: QA1's: Roush rear springs...see garage for more. |
2003 Twin Turbo Cobra
10.77@131
Another big difference is the 04 trans is cable operated and the 05 is hydraulic. The trans case is entirely different between the two years. I really don't think one will work in place of the other.
EDIT: ^^^Beat me to it. Last edited by 19COBRA93; May 7th, 2009 at 01:07 PM. |
2007 Mustang GT
guys he said he is swapping an entire drivetrain out of a mach1, so yeah you can make it work. It will be a pain in the ass to fab everything up and get it working RIGHT, but you might get away with it. MAYBE
Bassani Crew Member #3 |
10.77@131
It would be a lot easier to just pickup an 05 GT trans and bolt it to the back of the Mach motor. Trying to fab up an 04 trans to work in an 05 would be too much work when 05 transmissions can be picked up anywhere.
Mineral Grey 05 GT GT500 Clone Mineral Grey 03 Cobra THP Twin Turbo 10.77 @ 131 |
2005 Mustang V6
I thought the 05 GT did not have the Hydraulic Clutch, also will a 05 Manual tyranny bolt up to the Bell housing? I’m getting a good price on a totaled 2004 mach1 with 25k miles and i know it s going to cost allot above and beyond the donor car but when it’s done I will have a 05 mach1 with shaker hood. Plus I got the v6 for cheap and the difference between the cost of a V6 and a GT is at least 6K
10.77@131
The bellhousing on both model years don't separate from the case. All 05 up GT's are hydraulic clutches. An 05 trans assembly will bolt up to the Mach motor no problem and will have all the right stuff to work in your V6 body.
Also, the block is different between the two years so the motor mounts won't bolt up. I understand there is an adaptor kit you can use that allows you to bolt up the 05 mounts to an 04 and older block.
Threads Similar to: Tremec 3650
| tremec 3650 or t-56?? | 1fststang | 99-04 | 12 | July 3rd, 2008 04:41 PM |
| Tremec 3650 In 96 GT | jm06 | 96-98 | 4 | November 18th, 2007 01:46 PM |
| F**in tremec 3650 | 2002GTblkonblk | 99-04 | 14 | July 10th, 2007 10:41 AM |
| Tremec 3650 Fluid | Garhfer | 99-04 | 5 | June 10th, 2007 12:55 PM |
| Help with the Tremec TR 3650( PLEASE) | H82LOSE | 99-04 | 1 | July 1st, 2006 05:16 PM |
