High RPM miss
Old May 9th, 2009, 10:09 AM   #1
2005 Mustang GT
11.88 @ 118
TimboStang is on a distinguished road
High RPM miss
Took the car to the track last night and I developed a miss at around 5k. Where would be the first place to start diagnosing. I don't have any way of datalogging. I guess I need to pull the plugs first and check them out. Kind of felt like it could have been blowing the spark out. Any suggestions?
Turbonetics single 60mm
Old May 9th, 2009, 11:25 AM   #2
ROUSH STAGE II's Avatar
2005 Turbonetics Baby!!!
ROUSH STAGE II is just really niceROUSH STAGE II is just really niceROUSH STAGE II is just really niceROUSH STAGE II is just really nice
What's your plug gap set at right now? The only time I've had an upper rpm miss with mine is when I blew the air intake coupling off slightly and it created a gap at the throttle body.
Turbonetics baby!!!
11.23@122 mph...
Old May 9th, 2009, 02:18 PM   #3
Anthony05GT is a jewel in the roughAnthony05GT is a jewel in the roughAnthony05GT is a jewel in the rough
I'd check for the obvious and a new set of HTO plugs gapped at .030
JDM 302 Stroker, Whipple 10 rib 12 psi, L&M, JBA, J&M, LFP, Corsa, BBR Stage II cams, Manley, MGW, McLeod RST, Metco, Steeda, Autometer, CDC, Street Scene, SOS, Tuned at JPC Racing by Kevin MacDonald
Old May 9th, 2009, 02:42 PM   #4
2005 Mustang GT
11.88 @ 118
When I get a chance I'll go over all my connections and pull the plugs. I guess it could be a coil pack getting weak.
Old May 9th, 2009, 02:46 PM   #5
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
I very much doubt that. I would check your plugs, including the gap. Then I would check your connections after you replace the plugs. Then go run it hard and see if you still have a miss. If you do, you have the ability to datalog right? Datalog and see where the problems is. Whether its fuel or spark.
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old May 9th, 2009, 07:01 PM   #6
I know I've had Motorcraft HTO's give me problems (seen on the dyno too) with just a few thousand miles on them. The simple rule of thumb is if you are running forced induction change the plugs at every 10k miles and gap them down to about .030
Old May 9th, 2009, 07:11 PM   #7
05roush0090's Avatar
2005 Mustang GT Roush
05roush0090 will become famous soon enough
Plugs are exactly where I would start.
2005 BLACK Mustang GT Roush #05-0090
DOB manifold, m122 SC, gt500 TB, 52lbers, KB BAP, AFCO HE,Brisk plugs, Mac Lt's, Off road x, Roush TVS CAI, Detroit rocker sc grind cams, Brenspeed 93 tune,
10 psi (2.875" pulley) 470rwhp-419ftlbs sae
Old May 10th, 2009, 09:58 AM   #8
2005 Mustang GT
11.88 @ 118
Used my Predator to watch some fuel parameters this morning and the fuel pressure is dipping at 4800-5200 rpm. Should it be showing a steady 38 or should it rise with boost pressure? It rises up to 48 and then when it gets around 4800 it will drop to as low as 33psi and then start to rise back up after 5200. Maybe it's time for a fuel filter.
Old May 10th, 2009, 09:59 AM   #9
2005 Mustang GT
11.88 @ 118
What voltage does the factory computer and maf run on? At one point this morning it saw 4.5v
Old May 10th, 2009, 10:25 AM   #10
One thing's for sure, when you are running boost change the filter every 10k miles.
Old May 10th, 2009, 11:48 AM   #11
2005 Mustang GT
11.88 @ 118
Here is the spark plug gaps. 3@.035 3@.034 1@.038 1@.040.
Is that enough gap to cause spark blow out at 11psi?
Old May 10th, 2009, 12:04 PM   #12
BWAL Is My Hero
JakeM's Avatar
I'd slam them all down to .030 or .032. Also, changing your fuel filter will probably be a good idea. Max volts on the MAF is 5v's I think.
Old May 10th, 2009, 01:37 PM   #13
2005 Mustang GT
11.88 @ 118
Changed fuel filter. Gapped plugs to .031. Now time to go test her out.
I probably need to get one of those slot style ba5000 meters so I don't run out of maf down the road.
Old May 10th, 2009, 01:59 PM   #14
BWAL Is My Hero
JakeM's Avatar
Its a good idea if you plan on going big boost someday. If not you could always got a Diablo MAFia MAF range extender.
Old May 11th, 2009, 12:28 AM   #15
2005 Mustang GT
11.88 @ 118
I've got a mafia on it now. Took it to the track tonight and the miss is gone.
Old May 11th, 2009, 12:43 AM   #16
Just so you know... I'm using a 2400 maf without a mafia without any issues.
Turbonetics baby!!!
11.23@122 mph...
Old May 11th, 2009, 12:08 PM   #17
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Whats your Combo? 97 in the 8th is about 122 or 123 in the quarter.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old May 11th, 2009, 12:20 PM   #18
BWAL Is My Hero
JakeM's Avatar
Awesome! So, did you try it with just the plugs? Or was it indeed the MAF running out of range?
Old May 11th, 2009, 01:49 PM   #19
2005 Mustang GT
11.88 @ 118
I phrased that wrong. I already had a mafia on it. The only things I changed were the gap and the fuel filter. I should have done these two individually and tested each one just for knowlege sake. I don't know which actually fixed the problem. I poured the fuel filter out today and the fuel that came out the inlet side was nasty nasty. Looked like Galveston beach water.
Old May 11th, 2009, 01:58 PM   #20
2005 Mustang GT
11.88 @ 118
Stock 05 mustang GT with a turbonetics single 60mm turbo. I ran friday at the 1/4 track and only trapped 113. That is why I started this thread. Ran at the 1/8th track last night and was trapping 93. We had some really muggy air last night. I'm hoping that is why the mph came down so much. We are at around 95ft. elevation, but with the DA last night it was like 1867ft.
Hopefully that warrants dropping 3-4mph, otherwise that would show that I lost some power by gapping my plugs down. What do yall think?
Oh, and on a side note, I manged to pull off a 1.80 60' on Nitto555 street tires with less than half tread on them. 7.80 @ 93. The two step really helps on launch control.
Threads Similar to: High RPM miss
low rpm miss mxnate116 5.0 Mustangs 11 May 7th, 2008 11:36 PM
High Rpm Miss cptkng79 5.0 Mustangs 9 April 28th, 2008 06:36 PM
Please Help With High Rpm Miss cptkng79 5.0 Mustangs 8 October 1st, 2007 08:54 PM
Low rpm miss Badasstang281 99-04 3 March 22nd, 2007 02:48 PM
Slight Miss When In High Gear / Low Rpm built54 Modular Mustangs 10 October 15th, 2006 11:22 PM
