2005 Mustang GT
AC problem = Tune problem?
Hey guys,
Just wondering. I had my cams installed this past week. Just drove the car home from the shop about 2 hours ago. (Guys were working on Mother's day . . . dedicated) Anyway, I noticed that my ac fan is blowing . . . but no cold air. On further inspection . . . the compressor does not appear to be running. I drove it back to the shop to talk to the guys. We looked at the fuse (was fine) . . . and the plug was in the compressor . . . everything appears to be as it should . . . aside from the fact that the ac does not work. He said to bring it back tomorrow and they would look at it closer. So Question: Could the tuner have inadvertently turned the ac compressor off? I know can turn all kinds of different parameters off: traction control, O2 sensors, etc. What about the ac compressor? I hope that's all it is. I don't know what the ac would have to do with the cam install. It's making me a little nervous though.
Skrapr 2005 Mustang GT (5-spd Manual) FRPP 4.10's Kooks LT's | Kooks Cat'd X C&L Racer CAI Dyno'd | SCT-X3 MGW Shifter | MGW Interior Details Comp XFI SPR Stage-II's |
2005 Mustang GT
Nobody?
I guess you guys must have as much tuning experience as me . . . exactly nada!! Kind of a specialty topic . . . I know.
BWAL Is My Hero
2003 F150 S-Crew 5.4 FX4
The only thing I can think of is the WOT lock out. When you go anything passed 80% throttle the factory ECU shuts down the compressor. So, if you tuner messed with that function that would be the only thing I could think of. If not, its most likely a Mechanical/Wiring issue.
#4 | |
2005 Mustang GT
#5 | |
Senor Tini
BWAL Is My Hero
Yes.. To lessen parasitic drain under high load...
booooost'd
2007 Mustang
My ac isn't working either... come to think of it, it started right after my cam install. Let me know what happens!
![]() Jucostud's Official Build Thread 1988 LX HATCH 5.0 - FOR SALE $5,000 OBO 2007 vortech gt - SOLD! Looking for next project |
KB'd GT
Its totally possible to do that in the tune. It could be due to a low TP for WOT setting, or a low AC disable setting.
2005 Mustang GT
Ok . . . so . . .
The compressor pressures are fine . . . Power is making it to the relay in the fusebox . . . We by-passed the relay just to see if the compressor worked, and it does . . . We swapped another relay in to see if that was the problem, it was not . . . We checked the WOT toggle for the AC . . . that was not it However, we have all deduced that it has got to be something to do with the SCT-X3 or the car's computer - but it is still a mystery. Black Car + Black Leather Interior + Charlotte, NC + Summer + No AC = AAAAaaaahhhhhhhhhhh !!!!!!!!!!!
2008 Mustang GT
GEt ahold of SCT and ask them?
Experience is what you get when you didn't get what you wanted.
2008 Mustang GT
13.124@105.52
in your relay tests you forgot to mention if you checked that the pcm is grounding the relay to turn on the compressor, which I assume it isn't. How did you check the WOT toggle? I'd contact your tuner and ask them if they messed with the wot toggle setting like trick tuners said.
Hurst Crew Member #20 2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
2005 Mustang GT
I've been talking to my tuner all week. Not sure about the ground? I'll have to look at that.
It's just strange that this happened at the same time as the cam install. The cams have nothing to do with the ac. The only common denominator is the SCT tuner or the pcm. God, I hope it's not the pcm. Just shoot me now. It's got to be something with the tune or the X3 . . . that's the only thing that makes sense to me.
Threads Similar to: AC problem = Tune problem?
| Any problem from installing O/R H w/o a Tune? | texas_mustang | The Clubhouse | 6 | December 25th, 2008 07:30 PM |
| Small tune problem i think? | 90Stang | 2005 - 2010 | 3 | October 16th, 2008 12:48 PM |
| Tune problem? | Cricket | 99-04 | 6 | October 13th, 2008 06:04 PM |
| problem with tune or something else? | hardhitter | 99-04 | 72 | June 13th, 2008 10:07 PM |
| Having a problem with Doug's Tune | Modern_Muscle | 2005 - 2010 | 1 | June 2nd, 2007 05:51 PM |
