2007 Mustang GT
12.6@110
What do you think was the change?
So 2 weekends ago I went to a dyno day at Shop 1 who uses a dynojet, the weather was a bit humid, temperatures were great, and it started to drizzle about an hour before I got to do my pulls, car put down 388/344.
Two days ago I go to a dyno day at Shop 2, they also use a dynojet, day was gorgeous, temps stayed pretty low, maybe 5-10 degrees warmer than the previous dyno day, humidity was almost non existant. The car put down 430/368 then 426/381, then they let it sit and cool for about 10 minutes and it ran 447/397. So my question to you is, what do you think was the 1 thing I did to the car in those 2 weeks to net that change?
![]() Professor Crackers
#2 | |
2008 GT Alloy
13.2@107
" I Am Tarpeeler, And I Approve This Message." ![]() Quarter Window Delete Member#1 |
#3 | |
2008 Mustang GT
Experience is what you get when you didn't get what you wanted.
2005 Mustang GT
11.88 @ 118
Either cleaned the air filter or changed the fuel filter. That and loosing the humidity which actually lowers the density altitude.
Turbonetics single 60mm
2007 Mustang GT
12.6@110
No change was made to the tuning or boost level
MM's Resident Ginger
the shop?
Mods:In Garage Military Crew E-5
Aircraft Fuel Systems Journeyman |
2009 ROTY
temp and air density will make a difference, but dang, thats alot! sounds like a difference in the correction factor used...
where you been sonic?
2009 ROTY
i tends to get lost sometimes. shiney things distract me. lol...
2005 Mustang GT
12.0 @ 117+
sounds like the dyno day worked for dyno 2; they've got another customer
Golf Pencil Kawk Juggler
![]() Procharger D-1SC Kit - Pypes O/R H - FRPP Stingers Team Ricer GT Co-Founder
2007 Mustang GT
12.6@110
lol, same correction factors, so far as I can tell there was no difference between the two parameters used on the dyno's. I was dumbfounded as well, I don't know if the shop 2 dyno reads high and shop 1 reads low or what, the ONLY thing I did to the car between the 2 dynos, was to unplug the battery for a couple hours while working on a little paint project on my steeda battery box. I didn't think the adaptive learning would have THAT big of a difference! I know the humidity had a large part in it though, it's noticeable at the track when it's moist out compared to later in the evening with cooler air.
I Poop Entirely Way Too Much
Blown 03 GT
Well that big a gain should be felt in the butt dyno
2007 Mustang GT
12.6@110
Nope, no illicit dealings, the guy in front of me even dyno'd right about where I guessed he would too. I did notice that shop #1's dyno day had a lot of cars that dyno'd a bit lower than I would have guessed them at, not by a lot, but some cars I expected to see hit 400 were only hitting 380-390ish.
and here's the dyno from shop #1: ![]() I'll have to take a digital pic of my new dyno and post it up later
you sucked him off...so he bumped the numbers
2007 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
WOW........................................REALLY?
![]() Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit |
2007 Mustang GT
12.6@110
This is all conjecture until I see some proof...
![]() You shouldn't be spreading around the trade secrets like this...
Threads Similar to: What do you think was the change?
| change up | Jucostud | 2005 - 2010 | 43 | October 3rd, 2008 11:50 PM |
| No Change! | oldernewbie | The Clubhouse | 7 | June 11th, 2008 08:00 PM |
| Maybe I should change my name... | turp | The Clubhouse | 26 | June 3rd, 2007 12:05 AM |
| change it up | kaizerdan | Visual | 12 | January 11th, 2007 06:15 PM |
