flow chart - Page 2
Old May 15th, 2009, 03:32 PM   #21
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
ya stainless valves as well...i hope. i thought they would have done more aggresive porting on the exhaust side to compliment the oversized valve
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old May 15th, 2009, 03:34 PM   #22
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
The flow per square inch on the exhaust side is pretty damn good.. I'd say they pretty well ported the shit out of the exhaust side. You want almost twice as much flow on the intake side as the exhaust side anyway. Not quite twice but close. On three valve heads anyway.
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old May 15th, 2009, 03:38 PM   #23
07 STROKER's Avatar
07 Mustang GT
i see.
Old May 15th, 2009, 06:13 PM   #24
2007 Mustang GT
kraigster will become famous soon enough
I was looking at your flow numbers and I can say that the intake flows very well, However the exhaust is not as good as the claim. The say stage 2 flows 283int/203exh. that would be an exh/int of 70% and that is kick ass. Your heads on the other hand have a % exh/int of 66.8@ .600 lift, thats not 70% wtf happened ? Now your gonna have to compensate by adding a camshaft with a little more exh duration to make up for a head that is a little short on the exh. Not trying to burst your bubble , just pointing out some facts. They should still make good power though.
Saleen rear fascia with center exhaust, MAC longtubes with o/r Prochamber, Steeda CAI w/carbon fiber elbow, SCT X3, Steeda UDPs, Hurst shifter, modified delete plates, Comp Cams and 4.10s.
Old May 15th, 2009, 06:15 PM   #25
07 STROKER's Avatar
07 Mustang GT
who runs a .600 lift cam on the streets...look at the lower flow numbers.
Old May 15th, 2009, 06:18 PM   #26
2007 Mustang GT
If you run a SPR stage 2 your gonna be @550. Right ? No one invest that much money in a set of heads to run a .450 lift cam forever.
Old May 15th, 2009, 06:21 PM   #27
07 STROKER's Avatar
07 Mustang GT
very true on that point...my current cams are way small
Old May 15th, 2009, 08:28 PM   #28
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
now that we have the technical speculation and conjecture out of the way let me be the one to put my neck on the line here and lay this down in plain chapter and verse.
Here is my tech response.
These heads are bad ass! With NSR cams on them this car is going to make more power then 99.999% of the so called bad ass stage 45 heads and stage XXX cams out there.
Shit, i make more power with 535 lift then guys are making with 565.
Relax.
On more thing. When i have time this summer, im putting my stage II NSR's back in the car and ripping 11s with them. MID 11s with them. And i will be taking bets on it.
END THREAD
btw way here are the pics i promised. not enough info to trully compare the heads though.
Threads Similar to: flow chart
college flow chart graystang01 The Clubhouse 7 March 30th, 2009 02:22 PM
whipple dyno chart onederful100 2005 - 2010 24 February 17th, 2008 10:45 AM
pill chart 40thmustanggt 99-04 1 January 13th, 2008 09:44 PM
New 4.10's... and conversion chart! wormster00 2005 - 2010 15 June 27th, 2007 11:40 PM
Displacement Chart StangAddiction 5.0 Mustangs 4 May 8th, 2007 10:02 AM
