#1 | |
All sissies going to Hell!
2008 BULLITT #3385
Killing with a smile
I know this has been brought up before but...
Livernois lock outs, BBR lockouts, or comp cam phaser limiters. Which will work better?
I like the construction of the comp cams limiters better, but the livernois and the BBR are cheaper. Do the limit the same ammount? And will they have the same effect on the 127500 cams????
BULLITT CREW FOUNDER (The real one) Bassani Crew Member #5...HARDCORE CREW MILITARY CREW E-5 MA2(AW) ![]() Last edited by navyman8903; May 30th, 2009 at 05:13 AM. |
If you go with the 127500 cams you should consider using limiters that are intended to limit the VCT to the same degree. I would go with the Livernois limiters though because they are spring loaded which really does cut out the phaser clicking noise. Some guys have installed the Comp limiters only to be pissed off about all of the noise.
The VCT system really is more for emission control than performance and using lockouts doesn't rob you of any noticable power.
JDM 302 Stroker, Whipple 10 rib 12 psi, L&M, JBA, J&M, LFP, Corsa, BBR Stage II cams, Manley, MGW, McLeod RST, Metco, Steeda, Autometer, CDC, Street Scene, SOS, Tuned at JPC Racing by Kevin MacDonald Last edited by Anthony05GT; May 30th, 2009 at 08:34 AM. |
comp limiters ftw
![]() Under Construction |
i like the construction of comps also, but i'd like to hear some of the livernoise to see if the clicking really would be gone due to the use of a spring.
2007 Mustang GT
I had no extra engine noise after the comp limiter install........what are the sounds coming from these other cars like??
Bassani Crew Member #3 |
What are the limiters used for
07 GT-- Gone But Not Forgotten Military Crew E-5
2007 Mustang GT
They limit the amount camshaft retarding or advancing to 20 deg. so you don't have valve to piston problems with high lift cams etc..
Saleen rear fascia with center exhaust, MAC longtubes with o/r Prochamber, Steeda CAI w/carbon fiber elbow, SCT X3, Steeda UDPs, Hurst shifter, modified delete plates, Comp Cams and 4.10s.
Gotcha. Thanks. And how does that come into affect with making power. Will you gain more or less depending on what you set it at
2007 Mustang GT
You want to keep the VCT still functiong, some companies totally lock out the VCT but it has been proven on the dyno that there is 10-15 hp gain if you retain VCT and have cam timing properly tuned.
2007 Mustang GT
I think that is how I gained so much power with a set of thumpr cams maybe. They spent a long time getting the VCT tuned right on my car, besides just turning it off like alot of shops will do to you.
So its best to tune w/out limiters and just use the vct
2008 BULLITT #3385
Anyone know about the BBR's?
2008 BULLITT #3385
With what cams and what was the total HP gained?
2007 GT
Threads Similar to: I know this has been brought up before but...
| new '03 GT brought me here | TurboMustang370 | New Members Introductions | 30 | February 24th, 2009 01:17 AM |
| Look what Santa brought... | Dansby | The Clubhouse | 25 | December 26th, 2008 02:32 PM |
| Brought it back! | Dansby | The Clubhouse | 0 | August 15th, 2008 06:42 PM |
| Jesus brought me a present | 99v6stang | V6 Mustangs | 45 | February 21st, 2008 11:16 AM |
| Look What the UPS Guy Brought Me! | 00vabchgt | 99-04 | 3 | November 19th, 2007 07:49 PM |
