Why are the stage 1,2,3, and 4 cams all the same price??
http://www.lethalperformance.com/pag...gine-cams.html
i was looking at them and i would obvisouly think that the higher the stage the better, so why are they the same price then...?
2006 Mustang Gt Silver Borla Cat Back Exaust K&N Intake Throttle Body Spacer more to come!!!! |
You know,,Thats a damn good question!
yeah i kno and im waiting for an explanation!
LOL!
I would think that grinding a cam, is grinding a cam.There isn't a lot of difference in the amount of material used, or type of material, it's all about the extremely expensive computers & machines used to grind those bad boys out.
i wonder what they mean by...
"Noticable idle change"
![]() its not how fast you can drive.... its how well you can drive, while going fast... why should i tip-toe through life only to arrive safely at death?? |
1990 GT
just cause its a higher number doesnt mean its the best cam for your car. the higher numbers require supporting mods to go with it. but as far as the same cost i would agree with above..grinding a cam is grinding a cam
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
#8 | |
The cams are priced the same because you cannot just go to a stage 3 hoping for the best results. You must buy a cam that is matched to your engine/mods. Therefore, one cam stage is not "better" than the others, they are just matched to your mods.
#9 | |
Re: Why are the stage 1,2,3, and 4 cams all the same price??
#10 | |
On Probation
If you are looking for some cams for your S197 stang also check out these.
http://www.blowbyracing.com/bcamshaftsb.html |
I have the comp stage 3's, and even though rough idle is stated in the description, I find them to be very mild. I've had them for a month and nobody has noticed I have cams on or made a comment on how the car idles. If you're looking for a lopey sound get the bbr's.
2006 Mustang 4.0
![]() iTrader: 1 reviews
stage one is low low RPMS, stage two for like like mid low to high mid, and stage 3 like mid to really high lol.... its all based on what you need.. stage 2 might be good with gears since gears increase your low rpms and then stage 2 or 3 cam will help increase the power all the way up to 2600-6800. which is the stage 3.. i think stage 2 is like 2300-6300 or something.. stag one is like2000- 5800 or something... I am just guessing on the RPM numbers, but this is how i understand it. But I am no expert though.
2006 Mustang 4.0
then you can get custom grinds made specifically for your application, like some blower or turbo cam's.. NA cams, ect... which is really the best choice if you know what your future plans are
#15 | |
#16 | ||
Threads Similar to: Why are the stage 1,2,3, and 4 cams all the same price??
| VT Stage 2 cams? | ckjacobus | 96-98 | 2 | September 7th, 2007 10:27 PM |
| bbr stage 2 cams... | jat | 2005 - 2010 | 16 | February 17th, 2007 07:26 AM |
| VT Stage 2 Cams | DirtyMach1 | 99-04 | 19 | January 22nd, 2007 10:14 AM |
