MM's resident Juice head
07 Mustang GT
spec 3+..
lasted 100 miles before i got called out....long story short i blew second....then when i hit 3rd the clutch stuck.
I drove it around dtown after and it seems to be okay...little shudder of the line at times...hope i didint nuke it, how nessecary is the 500 mile rule?
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
Safud: MM's Resident Hadji
I would like to know this also...Just changed my clutch today
bump this i wanna know as well
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
It is very necessary. Don't fuck up and waste your new clutch...
The 500 mile break in is very important, if you don't follow it you will most likely fry your clutch.
The little shudder you are feeling off the line sounds like clutch chatter. That is a normal characteristic of the Stage 3+. Because of the materials that make up the clutch disc you will not be able to smoothly slip the clutch as you would with the stock setup, what is happening is the disc is trying to "grab" and engage and because you are slipping it is not able to do that smoothly and thus it jerks a bit. Hope that makes sense. But I would take it easy for the next couple hundred miles. |
#6 | |
MM's Mad Scientist
Slow Fella
BTW, Derek: I am going to try to get that harness from our local Ford, but I may have to get it from you. I can't get the guy at Brandon Ford to understand what I am wanting over the phone, so I am going to go down there this afternoon and see if I can draw it out for him. I really don't even see what is so hard to understand about wanting just the main ECU harness??
2007 GT
So how necessary is a break in on the stage I clutch?
07 Mustang GT
little feedback in the pedal as well.....probably my TOB that Rich wouldint let me replace
![]() It makes sense....i was just wondering if anyone out htere has ignored the rules and lived.
Wait, your engine is finally in? When the hell did that happen? How did I miss this?
'06 Whipple'd Mustang GT (Coming Soon) '02 Supercharged Harley-Davidson F-150 (Sold) '05 Mustang GT (Sold) |
07 Mustang GT
oh dude...the thread is in here somewhere, on the end of the "you wont believe this"
How's the new found power Ken
07 GT-- Gone But Not Forgotten Military Crew E-5
07 Mustang GT
fukkin awsome....i picked up way more bottom end than i ever thought possible. cant even tell i have cams anymore.
Well if you end up taking it out because it doesnt work, chances are it wont, go with a RAM. I wont go into the trouble I had with a SPEC and their customer service. You can find it by using the search function.
GT 6sp Grabber OrangeFor mods check my garage. 349 rwhp, 331 rwtrq Naturally Aspirated 445 rwhp, 495 rwtrq 100 Shot 60ft: 1.74 1/4: 12.15 @ 112.43 N/A 60ft: 1.71 11.40 @ 121.18 100 shot Nitrous |
MM's Mad Scientist
Slow Fella
Every company has a few trouble customers. Spec has always been great to me- easy to access and always taking time for questions and to give help.
2009 ROTY
love my stage 3+. well over 120 passes on it, and 80 of those have been launchin from 6200 on a 10.5" slick. so, i know they can handle it. a little chatter is normal though, mine has always done it. its a noisy clutch...
2005 Mustang GT
12.00@114.82
you should be fine if it still feels like it is gripping. but don't listen to me...I'm the clutch expert.
07 Mustang GT
oh its gripping, its never slipped...just stuck on me for a second when i speed shifted it last night.
2009 ROTY
i have heard of that happening before. and it un stuck and the guy never had an issue again...
2008 Mustang GT
11.35@123
My buddy did that with his mach 1 and the clutch failed just after that! So.. Hope you get lucky man!
CRT-Performance Tuned by Jeff Chambers in Norwalk Ohio, 2.6 Kenne Bell, 62mm T-Body, LT Headers, O/R H-pipe, 4.10s, Foxlake CNC Heads, VSR Stage 2 cams 530/447 Mustang Dyno www.crt-performance.com |
07 Mustang GT
got under the car and installed my torque limiters....no black stuff coming out the hole at the bottom....nothing smells burnt.....ill go try it out tonight if it stops raining.
Threads Similar to: spec 3+..
| Spec! | Bhblondguy | 2005 - 2010 | 14 | May 31st, 2009 02:04 AM |
| Spec 2, 2+, or 3? | shnouz | 99-04 | 5 | February 25th, 2009 06:35 PM |
| spec 2+ or 3+ ??? | Bhblondguy | 2005 - 2010 | 12 | December 6th, 2008 08:54 AM |
| v6 spec ? | Danderson | V6 Mustangs | 2 | April 15th, 2007 12:51 AM |
| Spec 2 Clutch | sb2f5marine69 | 5.0 Mustangs | 7 | March 10th, 2007 03:19 PM |
