Front suspension??
Old June 5th, 2009, 09:17 PM   #1
usnzt84's Avatar
2008 Mustang GT
usnzt84 is on a distinguished road
Front suspension??
i have a clunk/rattle under my front end when i hit bumps. it has gotten progressively worse throught out the day. i got the bullit strut caps and put them on the other day, and it started after that. at first i though it might be that but now it seems worse, and ive looked under the hood at them and they seem to clear the hood fine. anyone else had any noise from the front suspension? or have any sugestions on what it might be? thanks in advance
Vortech Supercharger,Hurst shifter, Diablo Sport Predator tune, Pypes O/R x-pipe, Super 44 Flowmasters,Hawk HPS Brake pads, Granitelli Slotted and Dimpled Rotors, Goodrich Steel braided brake lines, FRPP 3.73
Old June 5th, 2009, 09:25 PM   #2
2008 mustang gt
timothy is on a distinguished road
Your ball ends I had the same in mine after I put springs on
2008 mustang gt white shaker 1000 and gt appearance package. bmr springs, lower control arms, relocation brakets, panhard bar, and steeda pulleys, crome valve stem caps (stole them off the wife's mini )
Old June 5th, 2009, 09:28 PM   #3
usnzt84's Avatar
2008 Mustang GT
i dont have springs, i still have stock everything when it comes to suspension, will the factory cover this? can i drive on it?
Old June 5th, 2009, 09:44 PM   #4
Made in U.S.A.
NastyFX4's Avatar
2011 F150 FX4
NastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud of
iTrader: 8 reviews
Yes it should be covered under warranty unless you have more than 36,000/50,000 miles.
NastyStang's Garage Sale!!
Old June 5th, 2009, 09:50 PM   #5
2008 mustang gt
Nasty is right I would take that bitch in and keep taking it in till they fix it ( might take a few times , most of those techs suck at least at my local dealer)
Old June 5th, 2009, 10:32 PM   #6
usnzt84's Avatar
2008 Mustang GT
what about driving it?
Old June 5th, 2009, 10:43 PM   #7
ixmotoxi's Avatar
08 Alloy GT
ixmotoxi will become famous soon enough
Send a message via AIM to ixmotoxi
hmm. i had a clunking after I installed my springs. It was a loose front sway bar end link. You could try checking that? maybe it came loose for whatever reason.
vroom.
Old June 5th, 2009, 10:51 PM   #8
usnzt84's Avatar
2008 Mustang GT
why would it all of a sudden come loose?
Old June 5th, 2009, 11:53 PM   #9
Made in U.S.A.
NastyFX4's Avatar
2011 F150 FX4
iTrader: 8 reviews
It worked itself loose, why else? =P
Old June 6th, 2009, 12:10 AM   #10
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
Other then it working itself loose......
You have to unhook the end link to take off the strut to install the new spring. So more then likey it wasnt tightened on reinstallation.
Old June 6th, 2009, 11:05 AM   #11
usnzt84's Avatar
2008 Mustang GT
Thanks guys!!!
Old September 28th, 2009, 02:55 AM   #12
dragrace4fun's Avatar
2006 Mustang GT
dragrace4fun is on a distinguished road
I tried the taking it in method while under warranty, but they still wouldn't do it even though they quoted the TSB on it...buncha jerks. I'm still driving on mine and they shut up after a few thousand miles...probably destroyed, but not worried until something comes loose! Heh. I'm upgrading suspension soon, so I'll change 'em then.
2006 Mustang GT, Satin Silver Metallic, Dark Charcoal Interior
Lotsa mods...lotsa fun! Aspiring to be clean, old-school muscular beauty and N/A powerful!
Others: '67 Coupe
'84 Cutlass Supreme Brougham
Old September 30th, 2009, 10:51 AM   #13
Authorized Vendor
BMR Sales's Avatar
BMR Sales is on a distinguished road
When you get ready to upgrade please consider BMR for your suspension parts. We have you covered from front to back on suspension parts. From k member,a arms,sway bars,and complete rear suspension parts. If you have any questions on which parts would be best for your driving style you can give Rich at Rad Mustangs a call or myself. I am in th office mon-fri 8:30am -5:30pm est.
BMR Sales Dept.
BMR Suspension Inc.
sales@bmrfabrication.com
813.986.9302
Old September 30th, 2009, 11:05 AM   #14
2007 Mustang GT
Q's07RFGT is on a distinguished road
The end links have been mentioned, but I did not see anything about the strut towers. If your car is still under warranty, they should cover it. the TSB just tells the technician how to fix the problem.
I had the same clunking problem and took it to the dealer. They intially thought it was end links also, but in the end it was the strut towers. there is a TSB out on that also.
Old September 30th, 2009, 06:23 PM   #15
usnzt84's Avatar
2008 Mustang GT
my clunking actually did come from the bullitt strut caps, i took them off and it stopped, put them back on and it started agian. so i decided not to put them on unless im at a show, sucks to have to put them on and off but no clunk and it looks good when i have the hood up
Threads Similar to: Front suspension??
front suspension whiteboycustom 5.0 Mustangs 26 February 1st, 2012 12:38 PM
front suspension is on! mixedbreed02gt 99-04 13 February 10th, 2008 02:14 PM
Front Suspension Help? JONJON 5.0 Mustangs 6 December 14th, 2007 02:07 AM
Front Suspension 01dutchGT 99-04 1 December 7th, 2007 03:20 AM
65 Front Suspension? Spiderz Classic Mustangs 11 July 24th, 2007 05:39 PM
