2005 Turbonetics Baby!!!
Rear end leaking/slack
My rear end was leaking (no homo) at the pinion seal, so I removed the driveshaft and I don't have any movement up and down with the pinion, but there is slack rotating it back and forth (forward and reverse). Do you guys think I can just replace the seal and tighten the pinion nut close to the same torque spec to fix it???
![]() Turbonetics baby!!! 11.23@122 mph... Last edited by ROUSH STAGE II; June 6th, 2009 at 07:29 PM. |
2007 Mustang GT
yes your going to have some slack doing that, 99.999999% of vehicles do. You should be fine just changing out the seal and torquing her down.
Bassani Crew Member #3 |
I've read in the manual about the pinion nut torque setting trick with an inch pound torque wrench but I don't have access to one at the moment. Do you think it would be doable by "feel"?
9. Using a Nm (lb-in) torque wrench on the pinion nut, record the torque required to maintain rotation of the pinion gear through several revolutions.
![]() Turbonetics baby!!! 11.23@122 mph... Last edited by ROUSH STAGE II; June 6th, 2009 at 07:40 PM. Reason: added text |
Welded in mid mount mufflers may sound bad ass, but they suck when working under the car... DONE! Thanks for the input Silverstang. I tried to rep you but I have to spread some around first...
![]() Turbonetics baby!!! 11.23@122 mph... Last edited by ROUSH STAGE II; June 7th, 2009 at 01:08 AM. Reason: x |
2007 Mustang GT
lol what does that mean by "you need to spread some around first"?? why does it tell you that?? Just wondering lol
So you got her done?? I have an inch lb torque wrench but its not the right style. You need the old school wrench that you can constantly monitor torque on, not the "click" type like I have. Let me know if you need any of those special expensive ass tools, I can usually dig them up.
2007 G9 Eye Catcher
If you mark where the nut sits on the pinion now, make note of how many threads are exposed, remove nut, replace seal, reinstall nut to the exact position with the same amount of threads exposed, you'll be all good. No prob! A man of your caliber, should be a cinch!
2007 G9 Eye Catcher
Who are you again? lol
The man with a slight whine on deceleration... but no leaks.
![]() Turbonetics baby!!! 11.23@122 mph... |
2005 Mustang GT
12.0 @ 117+
Just your ears ringing from the BOV...
2007 GT
You ask if it could be done by hand. If you remember what it feels like when you turn the flange before you take it off. Basically you will feel just slight resistence on your rist. Like a slight pull on your wrist. If that makes sense. Better to use a torque wrench I guess but most of the guys i see just do it by hand.
2007 G9 Eye Catcher
The only thing is that the crush sleeve inside has already been compromised on the pinion. It's possible but make sure you mark it as well then.
#12 | |
Made in U.S.A.
2011 F150 FX4
2007 Mustang GT
Definately put a mark on the nut and the pinion. That pinion nut is pretty tight when you take it off. If you have access to one of those cheap ass torque wrenches with the dial, you can loosen the nut and see how much torque is on the nut for reference. If you don't get the pinion nut tight enough, you will have noise on decel.
Saleen rear fascia with center exhaust, MAC longtubes with o/r Prochamber, Steeda CAI w/carbon fiber elbow, SCT X3, Steeda UDPs, Hurst shifter, modified delete plates, Comp Cams and 4.10s.
#14 | |
2007 G9 Eye Catcher
#15 | |
Threads Similar to: Rear end leaking/slack
| Rear Quarter Leaking | SteviGX | 99-04 | 2 | November 26th, 2009 08:22 PM |
| Leaking rear | Calumus | Modular Mustangs | 5 | September 27th, 2008 03:26 PM |
| help rear end leaking. | mustanginca | 2005 - 2010 | 8 | July 6th, 2008 11:00 PM |
| T5 rear seal still leaking after install | 83 5.0 | 5.0 Mustangs | 6 | January 8th, 2007 09:17 PM |
| Rear Axel Leaking? | MSTGGT00 | 99-04 | 2 | November 16th, 2006 10:24 PM |
