Moderator
Lots of questions
Just have a bunch of questions that i would like some help with.
1. I see all this talk about bottom end and top end of an engine. What exactly comprises the top end or bottom end? 2. What is a timing chain for? 3. Whats the difference between a pushrod engine and a modular engine? 4. What is an overhead cam for? I think thats all i have for now. any help is great!
One Man Wolf Pack
1. The bottom end is the rotating assembly, pistons, rods, crank. Top end is the intake manifold, heads, cams, valves, ect...
2. A timing chain links the cams to the cranks rotation so the intake and exhaust valves open in sequence to match the stroke of the pistons. 3. A pushrod motor uses a single cam shaft mounted in the center of the engine that uses steel rods to open and close the intake and exhaust valves which are inside the heads. 4. An OHC motor is just a different design of motor. The cams are in the heads driven by the timing chains instead of one cam in the center of the engine using push rods to open and close the valves.
![]() ΜΟΛΩΝ ΛΑΒΕ
Moderator
so our engines have 3 cams? the two on each side an one overhead, or am i wrong on this.
#4 | |
Moderator
2003 Grand Cherokee
Pushrod engines have one cam in the block with 8 sets of lobes (I use this put as basic as possible). Each set of lobes controls the intake and exhaust valves for each cylinder. As the lobes turn they push on a rod that runs up to the heads. The other end of the rod pushes on the valves to open it. The OHC engine has a cam in each head. Each cam has 4 sets of lobes for the 4 intake and exhaust valves in each head. These lobes push directly on the valves as they rotate.
May 08 ROTM
2008 Audi S6
2 cams, one in each head..
May 08 ROTM
2008 Audi S6
was slow..
Moderator
ohhh ok its starting to make sense. so pushrods have just the one cam in the center?
Moderator
2003 Grand Cherokee
Yeah, in the block. I edited my earlier posts a couple times before I liked it. Hopefully it explains things better.
One Man Wolf Pack
Yes.
![]() ΜΟΛΩΝ ΛΑΒΕ
Moderator
so then if theres intake and exhaust valves, why do we have 3? is that to make it 2 intake one exhaust per cylinder or the other way around?
I probably sound completely retarded to you guys but thanks! Im getting the gist of it. |
07 GT-- Gone But Not Forgotten Military Crew E-5
Last Three of VIN 666
13.7@104mph
check these out:
Overhead valve - Wikipedia, the free encyclopedia Overhead camshaft - Wikipedia, the free encyclopedia gives you some visuals on the differences.
![]() ~ 08 Alloy ~ JLT CAI ~ BBR Tunes ~ Comp Stage II NSRs ~ UDPs ~ MAC LT O/R Prochamber/Violators ~ Hurst STS ~ FRPP 4.10 Gear ~ BMR LCAs ~ CHE Relocation Brackets ~ BMR Adj Panhard ~ Prothane Motor Mounts ~ Coast Drive Shaft ~ |
13.7@104mph
dang AF.....how could you link the guy to a chevy motor?
Well its not that I linked him to a chevy motor. I gave him a link to the basics which is where we all start to learn.
Moderator
do we have port fuel injection or direct fuel injection?
2008 Mustang GT
ooooh pretty pictures
![]() Direct injection is something Ford hasn't gotten to yet. There are some hopeful of seeing it turn up in the coyote, but even that probably won't have direct injection.
Experience is what you get when you didn't get what you wanted.
Moderator
gotcha. Those links were very helpful guys.
2008 Mustang GT
Yeah, thanks guys!
![]() That how stuff works link usafimj posted mdae it clear why different grinds of camshafts have such different effects on the motor. Very fun use of a coffee break. Damn I'm such a n00b.
#20 | |
Blank
I don't know if there are 2 intake, 1 exhaust valves or 1 intake, 2 exhaust valves per cylinder, maybe someone in here can help out on this. |
Threads Similar to: Lots of questions
| First Speeding Ticket.. lots of questions | Reset | The Clubhouse | 36 | April 5th, 2009 01:12 AM |
| Opinions and Questions. [lots of pictures] | thewayshemoves | 5.0 Mustangs | 54 | January 5th, 2009 07:54 PM |
| Lots of PI swap questions | 2000Mustang | 96-98 | 6 | October 21st, 2008 10:31 PM |
| lots of paint questions | johnbarberr | Visual | 6 | September 5th, 2007 07:54 PM |
| Lots Of Questions! Please Help! | DB67 | Classic Mustangs | 2 | October 14th, 2006 12:20 AM |
