2005 Mustang GT
![]() iTrader: 2 reviews
ECM Removal
Anybody on here have removal instructions for the ECM? I have to send mine back to TECHCO for reprogramming since it won't take the tune from the Predator.......
05 Sonic Blue GT, with a shitload of mods... Oh yea and a blower... bring it.................. ![]() Founder "Dead Battery Club"
2005 Mustang GT
Never mind, I found it.
![]() 303-14-1 Electronic Engine Controls 303-14-1 REMOVAL AND INSTALLATION Powertrain Control Module (PCM) Item Part Number Description 3. Disconnect the 3 PCM electrical connectors. 1 14A464 Powertrain control module (PCM) electrical connector (3 4. Remove the 2 bolts and the PCM. required) Installation 2 W505423 PCM bolt 3 12A650 PCM 1. Install the PCM and the 2 bolts. Removal • Tighten to 8 Nm (71 lb-in). 2. Connect the 3 PCM electrical connectors. 1. NOTE: Any PCM replacement will require that ALL customer keys are available to be 3. Connect the battery ground cable. For additional programmed at the time of installation. PCM information, refer to Section 414-01. replacement DOES NOT require new keys. Retrieve the module configuration. Carry out 4. Restore the module configuration. Carry out the the module configuration retrieval steps of the module configuration restore steps of the Programmable Module Installation procedure. Programmable Module Installation procedure. For additional information, refer to Section For additional information, refer to Section 418-01. 418-01. 2. Disconnect the battery ground cable. For additional information, refer to Section 414-01. Copyright ã 2005, Ford Motor Company Last updated: 11/22/2005 2006 Mustang, 9/2005 303-14-2 Electronic Engine Controls 303-14-2 REMOVAL AND INSTALLATION (Continued) 5. Reprogram the passive anti-theft system 6. For automatic transmission/CVT equipped (PATS). Carry out the Key Programming Using models, carry out the Transmission Drive Cycle Two Programmed Keys procedure. For Test. For additional information, refer to additional information, refer to Section Section 307-01. 419-01B. 2006 Mustang, 9/2005
Threads Similar to: ECM Removal
| ECM crapped out | ford6693 | 99-04 | 25 | April 4th, 2011 10:10 AM |
| Do I need to reflash my ECM? | MWWarlord | V6 Mustangs | 4 | September 14th, 2008 02:14 PM |
| ECM?? | imported_Gt_Jay | 5.0 Mustangs | 13 | January 2nd, 2008 03:43 AM |
| can i use a different ecm | beheivjer | Modular Mustangs | 5 | July 28th, 2007 10:43 PM |
| The correct ECM | cobraetti | General Tech | 1 | August 2nd, 2006 07:00 PM |
