Upper mount
Old June 22nd, 2009, 04:03 PM   #1
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
Upper mount
3/16 offset left to right. Is this correct or should it be centered?
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old June 22nd, 2009, 04:24 PM   #2
2007 Mustang GT
07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of
Shouldn't make a difference as long as it's screwed or pressed in all the way. It might even make it easier to get the grease gun on it.
Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit
Old June 22nd, 2009, 04:26 PM   #3
07 STROKER's Avatar
07 Mustang GT
no no...i meant the whole piece thats welded to the shaft.
Old June 22nd, 2009, 04:36 PM   #4
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
Well here is the thing.
That other side of the arm connects to the durometer bushing you have and goes in the stock bushing housing. you will have to bang that bushing back into the top of the center section of the axle, which is why i said when you do take that out, make sure you measure and mark how far it was banged in. Its not like it fits perfect. Ill show you a picture.
so technically, straight is the two mounting points lined up. Whether the round center part of the tubular arm is centered from point a to point b is not so much the issue as to whether you have point a and point b line up.
Make sense?
But i have emailed your photo to BMR.
Old June 22nd, 2009, 04:42 PM   #5
2007 Mustang GT
Sorry, I don't know if that is normal. I have the adj. BMR one and I don't know if it was centered or not. I do have to get underneath my car today to see where the gear oil is dripping from so I'll take a look. My initial thought though is that it should be centered.
Old June 22nd, 2009, 04:44 PM   #6
05bluestang's Avatar
2005 Mustang GT
05bluestang will become famous soon enough
Hmmm, from what I remember on mine it was smack in the middle...................
05 Sonic Blue GT, with a shitload of mods... Oh yea and a blower... bring it..................
Founder "Dead Battery Club"
Old June 22nd, 2009, 04:48 PM   #7
More Is Better.
DiMora's Avatar
2006 Roush Stage 1 Blown
DiMora is a splendid one to beholdDiMora is a splendid one to beholdDiMora is a splendid one to beholdDiMora is a splendid one to beholdDiMora is a splendid one to beholdDiMora is a splendid one to beholdDiMora is a splendid one to behold
Send a message via ICQ to DiMora
I *thought* my Steeda was centered, but I don't know for sure.
Roush Short shifter / Carmen's 3.47" TVS pulley
Roush TVS Supercharger
Steeda suspension /Big Brakes
Mac L/T's / Prochamber / Roush Extremes KB BAP
"Daily Driver" RWHP: 492@9 PSI w/ LT's
"Dyno Queen": 512@12 PSI-stock exhaust
Mods in Garage
Old June 22nd, 2009, 04:55 PM   #8
07 STROKER's Avatar
07 Mustang GT
I wish a wasint so anal about these things but I am...thanks Rich, it makes sense but I just want to make sure its not going to throw anything out of whack....and now you say the upper poly bushing isint centered in the axle housing?
Old June 22nd, 2009, 05:04 PM   #9
2007 GT
Let me go take a picture and show you what i mean. Its going to be your job to center everything is my point. the tubular bar section of the arm being off has really no bearing on where the axle ends up centered.
Not to say that if its not suppose to be like that it shouldn't be replaced. just point of fact.
Old June 22nd, 2009, 05:08 PM   #10
IronStomach's Avatar
2008 Mustang GT
IronStomach has a spectacular aura aboutIronStomach has a spectacular aura aboutIronStomach has a spectacular aura about
Is the other end centered?
Experience is what you get when you didn't get what you wanted.
Old June 22nd, 2009, 05:21 PM   #11
07 STROKER's Avatar
07 Mustang GT
yes
Old June 22nd, 2009, 05:27 PM   #12
2007 GT
So you see the busing in the top, You're going to have to get the rubber bushing out of there (have fun with that). Put the poly bushing in that metal sleeve.
So one end on your control arm is in the mount and the other end is bolted to this bushing......What affect really does whether the tubular part is center from point a to point b have? 3/16th
The panhard bar centers the axle. The panhard bar centers the axle and the axle has to be able to travel from left to right. Its going to as the suspensoin travels. Hence, the play.
But yes the control arm should be straight from the factory. Its a defect..
Posted edited and updated for current up to the minute info. Relax, drink some rum and rest assured in the fact that you have a ford with a solid rear axle. It aint pretty or perfect on its best day. It just works.
Old June 22nd, 2009, 05:34 PM   #13
07 STROKER's Avatar
07 Mustang GT
WTF.....now im confused...and how old is that girdle?
Old June 22nd, 2009, 05:35 PM   #14
limegold06gt's Avatar
2006 Mustang GT
limegold06gt will become famous soon enough
should be centered
See Garage For Mods
Old June 22nd, 2009, 05:36 PM   #15
07 STROKER's Avatar
07 Mustang GT
it has to be centered...otherwise it would walk under torque right?
Old June 23rd, 2009, 10:11 AM   #16
07 STROKER's Avatar
07 Mustang GT
I hate being right. Rich, option 3....My welder can cut that piece off and center it. What do you think?
Old June 23rd, 2009, 10:18 AM   #17
2007 Mustang GT
I think if the piece is off and it's not supposed to be, have BMR send you a new one.
Old June 23rd, 2009, 10:23 AM   #18
07 STROKER's Avatar
07 Mustang GT
10 -12 days....I install my parts on Thursday night. This is why Canada blows.
Old June 23rd, 2009, 11:02 AM   #19
2007 Mustang GT
If it's their fault, have them 1-day it to you.
Old June 23rd, 2009, 11:03 AM   #20
07 STROKER's Avatar
07 Mustang GT
id love that....but i couldint even get Livernois to do that for me.
Threads Similar to: Upper mount
GT500 upper strut mount IHVOCD 2005 - 2010 7 March 30th, 2009 08:24 PM
Where Did You All Mount Your Ballasts? energiesource 99-04 7 November 20th, 2007 02:03 PM
where can i mount? KaZpeR General Tech 8 July 19th, 2006 11:22 PM
