Cooling services
Old June 28th, 2009, 05:17 PM   #1
2007 Mustang GT
registo is on a distinguished road
Cooling services
Hello,
I planned to replace the coolant.
My very simple question : what is the best way to proceed ?
1. draining from the radiator( no problem with that )
2. ???
Is it necessary to remove the thermostat ? Then disconnect the upper hose and start the engine few minutes to let the coolant getting out ?
With coolant can I use ? Does it matter?
TY
2007 Mustang GT - Flexfuel - Steeda CAI - Xcal3 - Tokiko D-Spec - Steeda springs
My videos on YouTube (serach registo77 )
http://www.youtube.com/watch?v=zbIxAMjV6OE
Old June 28th, 2009, 11:14 PM   #2
UrbanRedneck's Avatar
2008 Mustang GT
13.124@105.52
UrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really nice
No you don't want to start the engine like that, running dry will kill the water pump or make it a bitch to bleed the system.
If you have access to a flushing machine, use it. If not, then the best you can really do is drain the radiator and refil. That won't change the coolant in the block, but if you do it regularly it will keep phasing out old coolant.
Hurst Crew Member #20
2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Old June 28th, 2009, 11:17 PM   #3
ModularSteed's Avatar
1997 Mustang GT
335rwhp/370rwtq
ModularSteed is on a distinguished road
+1 flush is usually about $100 at valvoline or a place similar
97 GT|Full PI Swap|BBK UDP|C&L Upper Plenum|Flowmaster Exhaust|O/R H|3:73|B&M|SCT X3|NOS 75|Eibach Pro Kit|99 SVT Wheels|
Originally Posted by 330CubeGt View Post
On a serious note i would try some vasoline and is should wiggle right in.
Old June 29th, 2009, 12:03 AM   #4
Made in U.S.A.
NastyFX4's Avatar
2011 F150 FX4
NastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant future
iTrader: 9 reviews
First of all, nice avatar 97stang. Awesome.
Draining it and filling it up should be fine. However if you want to get frisky, just drain it from the petcock on the bottom of the radiator, refill with distilled water, run it a little bit, and drain it again and than load it up with whatever you're planning on running in it.
Old June 29th, 2009, 12:08 AM   #5
1997 Mustang GT
335rwhp/370rwtq
thanks
Old June 29th, 2009, 12:10 AM   #6
silverstang's Avatar
2007 Mustang GT
silverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the roughsilverstang is a jewel in the rough
drain the radiator. Refill with water. Let it run up to operating temperature. Drain radiator again. this time, leave the petcock open. Stick a CLEAN water hose into the degas bottle and crack open the water until it is barely overflowing out of the degas bottle. MAKE SURE you are doing this while the car is still hot. Crank the car up and let it run with the water hose still running into the degas bottle. You might have to turn the water pressure up on the hose after you start it. Just let it barely overflow out of the degas bottle while doing this. That will get most everything out of the system. When you refill, it is recommended to run distilled water (you can get it in big jugs)..........Coolant? The only coolant I will run in my car is Motorcraft Premium gold coolant (don't use the old green stuff).......
Bassani Crew Member #3
Old June 29th, 2009, 12:14 AM   #7
2007 Mustang GT
07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of
Don't mean to hijack, but while we are discussing the cooling system, is the thermostat really located in the hose, between the engine and radiator, in front of the P/S pump? That's what my Chiltons says. I thought it was right there on top of the block, in front of the intake by the throttle body, in the domed housing where the upper radiator hose connects.
Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit
Old June 29th, 2009, 12:15 AM   #8
usafimj's Avatar
2007 Ford Mustang GT
12.847 @ 114.12mph
usafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of light
Send a message via Yahoo to usafimj
I believe its on top like you just described
07 GT-- Gone But Not Forgotten
Military Crew
E-5
Old June 29th, 2009, 12:15 AM   #9
1997 Mustang GT
335rwhp/370rwtq
follow the upper radiator hose its at the end oposite the radiator. im not to sure on the new ones tho
Old June 29th, 2009, 12:18 AM   #10
2007 Mustang GT
mine is inside the aluminum crossover under the front of the intake manifold.
Old June 29th, 2009, 12:28 AM   #11
2007 Mustang GT
So WTF is up with the Chiltons manual? Ok, now let me ask you this. The reason that I actually looked in the Chiltons was that I couldn't get to the bolt on the inside by the intake manifold, and I was wondering what the manual said. So How do you get to that bolt? Obviously the manual won't help 'cause it thinks the thermostat is somewhere else. Back to the bolt: There is not enough clearance between the intake manifold and that bolt for me to get a socket on it. And it looked like the only way I was going to get a wrench on it was to remove the throttle body and alternator bracket, or unbolt the whole intake. Has anyone changed their thermostat and have any insight to what I'm talking about? I feel like an idiot, it's just a thermostat. I thought I'd be in the garage for 25 minutes, It's like a 100 degrees in there, with the swamp cooler going.
Old June 29th, 2009, 12:40 AM   #12
2007 Mustang GT
I found this with the search button, an amazing thing that little button is. Anyways, is this right? That seems like an aweful lot to replace a thermostat. Why the F do we build engines this way? I just don't understand.
Disconnect the battery ground cable.
Remove the air cleaner outlet pipe.
Remove the accessory drive belt.
Disconnect the crankcase vent tube from the intake manifold and position it aside.
Remove the 2 generator support bracket outer bolts.
Remove the 2 lower generator nuts and position aside the generator and wiring harness.
NOTE: RH thermostat cover bolt has a slotted flange. Remove the LH thermostat cover bolt and loosen the RH bolt.
Position aside the thermostat cover and hose assembly.
Remove the thermostat O-ring seal and the thermostat.
Discard the thermostat O-ring seal.
Installation
NOTE: Lubricate the O-ring seal with clean engine coolant. Install the thermostat with the smaller plate facing upward and a new O-ring seal.
Position the thermostat cover and install the 2 bolts.
Tighten to 10 Nm (89 inch lbs.) .
Position the generator and wiring harness and install the 2 nuts.
Tighten to 25 Nm (18 ft. lbs.) .
Install the 2 outer generator support bracket bolts.
Connect the crankcase vent tube to the intake manifold.
Install the accessory drive belt.
Install the air cleaner outlet pipe.
Connect the battery ground cable.
Bleed the cooling system.
Old June 29th, 2009, 12:55 AM   #13
usafimj's Avatar
12.847 @ 114.12mph
Here's the Ford service manual. I'd find it for you but the net where I'm deployed to sucks and won't load crap for the manual. Hope this helps Ford Service Manuals - IN-VEHICLE REPAIR
Military Crew
E-5
Old June 30th, 2009, 03:04 PM   #14
2007 Mustang GT
Wow, what a PITA. It really wasn't that difficult but why the F should I have to take the alternator off in order to change the thermostat. That's stupid!
Threads Similar to: Cooling services
Powers out... again... stupid alabama services Fox2102 The Clubhouse 0 November 30th, 2008 07:58 PM
Cooling usafimj 2005 - 2010 4 June 25th, 2008 11:19 PM
Selective Services Drick The Clubhouse 30 September 29th, 2007 07:22 PM
Head Porting Services 98BlackBeast Modular Mustangs 1 August 13th, 2007 07:33 PM
cooling zhunter V6 Mustangs 2 January 25th, 2006 06:18 PM
